Arin@APR
GOLFMK7 Official Sponsor
- Auburn, Al
- B8 S4, MK7 GSW TDI
If you read between the lines in the booklet it says that you have to take it to an APR Plus dealer and are liable to get it there, no matter the distance, and there is nothing regarding the downtime for the vehicle. So if it takes them 5 days to process or get parts, you are on your own during that time.
Correct. You're on your own for getting it to a repair center. We don't include a rental at this price.
Also parts can be new, reman or "like condition and quality" which translates to a used turbo with similar or less miles is acceptable to replace a blown turbo covered under warranty.
We will not use used parts to repair a vehicle. This call out for “like condition or quality” refers to simpler parts that have aftermarket OEM replacements available. A great example is an oil filter. You can buy a VW oil filter or you can buy one of many OE replacements.
Using the term "Licensed Repair Facility" as a defined term is very misleading because there is a true definition of that in the automotive industry and it is not "APR Plus Dealer" .
Does that mean that not all APR dealers are APR Plus dealers? Is there a differentiation?
Per the warranty booklet:
“Licensed Repair Facility” – Any Authorized APR Plus Dealer is eligible to make repairs on a
vehicle with APR Plus
Also they will require proof of ALL service, including service outside the manufacturer recommendations. I.E. manual calls for oil changes every 10k, this booklet says 5k. Lots of little nuances in it, but anyone considering this, be forewarned that a loosely written 6 page booklet would not be something I would put full confidence in and drive freely thinking everything is covered without issue like the factory warranty on a stock car.
Yes, we put this in there to prevent neglect. Some people never change their oil. If you don't change you oil and something breaks, we're not covering it.
Keep in mind that the dealer/VW can void your entire powertrain warranty for modifying the ECU. That means that if any powertrain item fails, regardless of if it is caused by the ECU, VW can deny it.
You vehicle only comes with a limited powertrain warranty from vag, not an "entire powertrain warranty."
APR states they will only cover certain things, does that mean there is a gap in coverage between factory and what APR will cover?
The warranty booklet states all items we cover.
Exclusions such as "misuse or abuse"? What the hell does that mean?
Standing on a rev limiter for several minutes, over rev, things like that. Same goes for your factory warranty. They con't cover abuse and misuse.
Then it says it does not cover anything from an event, so if you track your car you and there is proof you can assume your claim would be denied.
Correct, just like the factory warranty.
I wouldn't be shocked if something like putting your car on a dyno would void this, and I believe the computers can tell if the front wheels were rolling for an extended period and the rears were not.
We don't void the limited powertrain warranty for putting your car on the dyno. If you put it on the dyno with no fans, and something breaks, well, yeah, that's on you.
Any Non-APR powertrain upgrades, I wonder if that includes and intake, or simple things like a DV.
Absolutely. We warranty our parts. We don't warranty parts we haven't tried. Just like your factory warranty.
