do you guys think i should test out the stock oem tune ?
Nope, it's not the tune. Wastegate is commanded closed and it's not hitting boost target.
I'd boost leak test it and if that's all good contact Dan and see if there's anything else he wants you to do before you pull the turbo off.
Forgot to mention i did boostleak test it through turbo inlet up to 30psi and had. no leaks
30psi boost test? Dang!
wanted to make 100% sure no leaks lol
That pressure started at the inlet?
https://datazap.me/u/amracer12/log-1556584441?log=0&data=1-3
ok guys did a quick little pull with eurodyne is38 91oct file with my max boost set @24 let me know what you guys think to me it felt like it pulled better
This to me doesn't look right. specified is supposed to be 0 but its going to 81%.
Am I right to think this a map that's for an IS38 on the GTI?
You really need to do a pull from 2000 - redline with turbo mode on and WOT if possible.
What gear is this? I can't imagine the vcds logging can't give data between 4400 and 5800 rpm. Try the turbo button.
See if you can get your upper and lower close to mine.
https://datazap.me/u/diggs24/log-1556484715?log=0&data=4-5
Spin out to 3.85v and run adaptation then run upper and lower stop. Start the engine and run adaptation again while running. It might abort the upper and lower you but that's ok, let it.
