Where's the support bracket to hold up the turbo? Did you remove it for the pic?
Look up under there and make sure there is nothing rubbing against rod. If nothing, disconnect rod and move flapper arm and see if there is any binding in it.
So, I just loosen the jam nut and turn the rod until it comes out, correct? Guess I will be tuning the wg actuator again... F!
Sent from my iPad using Tapatalk
Setting the WG again might be the least of your worries. If that flapper doesn't move freely the turbo needs to come back out, or at least the exhaust housing.
Probably slightly twisted the flapper arm inside the turbine housing and now the actuator is out of range, same shit my turbo did.
We've known the VTT flappers were junk for awhile. Same problem Littco had (briefly).
Always thought yours was external like the others. Interesting.
You should be able to just grab that sucker as it is and move the flapper in and out. If not binding, this should be easy to do without removing the rod yet.
Tony Vargas said the same thing when I emailed him. I can't move it with just my hand with the rod attached. I'm going to try to take the rod off tomorrow and see if I can move it.
Again, I'm assuming that I just loosen the jam nut and turn the rod until it comes out of the fork, correct?
FYI - I did put the e30 tune back on and logged it throwing the code and everything. Jon from 5150 says, "my guess is that the actuator rod has moved."
Pop off DP and look inside and see if flapper is bent/sealing hole completely.
