Spring & Shock/Damper Installation Reference Guide
Hammersticks
Bay Area, CA
'16 GTI, '18 e-Golf
I have the tools to do it manually so that’s the route I go, but I’m fully aware shops use an impact all the time...Personally, I just don’t want to think about it. Peace of mind based on what the instructions say.
odessa.filez
Roswell, GA
2016 GSW 1.8tsi auto
yep I get that peace of mind thing and people should do what they're comfortable with.
I've had zero issues doing it this way. If I had the stock mount, I'd tighten the nut with a torque wrench but there's no issue breaking it lose with an impact.
odessa.filez
Roswell, GA
Inprogress
TEXAS
2017 GTI SE
Would the list of required parts be less/different for coilover install? I'm having my local shop do it, but I don't understand what all would be applicable for coilovers. I'm getting the H&R Street Performance + coilovers that come with front camber plates. I've searched, read DYI articles, and watched videos on youtube but still unsure of what's required/suggested for coilovers specifically.
Some of the hardware kits from ECS are back-ordered till mid-August
What would be the suggested parts for coilovers?
Thank you in advance, and sorry if this has been covered and i'm just not comprehending
Raguvian
Bay Area, CA
2019 GSW 4MO 6MT
Not familiar with the H&R coilovers specifically, but on the front you'd want a pinch bolt, axle bolts (if the shop isn't doing the 2x4 method) and upper strut mount/strut tower bolts. If the coilovers don't come with top hats you'd need the nut that goes on the shock shaft as well if you're reusing your top hats. For the rear you'd need the two control arm bolts (one goes through the hub, the other goes through the lower shock mount). I think the upper shock mounting bolts can be reused.
Inprogress
TEXAS
2017 GTI SE
What about front strut bearings, are those applicable? And the rear shock mounts, do they need to be replaced?
Thank you!
DiscusInferno
Kalifornia
Per Side:
Pinch Bolt: N90954802 , $4.36
Nylok Nut: N10106402 , $1.25
Strut Mount Bolt: N10127707 , $2.54 x3 (might not need it)
End link Nylok nut: N0150816 , $1
Hub bolt: WHT005437 , $2.32
Ball Joint Nuts: N10332002 , $1 x3
Rear shock bolt: N10628301 , $4.68
Rear shock nylok nut, N10106402 , $1.25
Rear control arm bolt: N10640501 , $6.00
Rear control arm nylok nut: N10106402, $1.25
rear endlink nylok nut: N10286110 , $1.34
Rear shock mount, 5Q0513353G , $86.67
Rear bump stop, 5Q0511357J , $30.60
Rear dust cover, 5Q0513425J , $17.20
Shock mount cap, 1J0512135A , $2.54
Shock mount bolts, you can reuse.
using prices on parts.vw.com
NopeR
18 Golf R
Rear mounts usually don't need to be replaced. However, they're pretty cheap, so it wouldn't be a bad idea.
My car was new with 7,000 miles. I reused everything. If your car is a few years old and have 30k miles, replace.
Inprogress
TEXAS
2017 GTI SE
Per Side:
Thank you very much!
Yeah I think I will for peace of mind, mine is a 2017 with 60k on the odo, and i bought it last week
While you're at it, add the Eurosport camber kit.
