Wade_GT
- Los Angeles
- '17 GTI S 6M
Anyone else experience a “popping sound” from the front on low speed turns weeks after doing this job?
Whatif all you're doing is springs, why pull the strut from the knuckle?
Having done this job twice, I'm still unconvinced that bolting a 2x4 to the swaybar mount and using a jack to try to get the strut out of the knuckle is any easier or faster than unbolting the axle. With the right set of tools and extensions + an impact driver the axle is off the transmission in a minute, and you're not trying to fight against something that's compressed and trying to kill you.
What
I'd assume because most people don't have the right set of tools and extension and an impact. You can say "Well maybe they shouldn't be installing springs then", and maybe that's true, but it can still get done with mostly basic tools and a 2x4.
That's legit the worst advice I've ever read regarding this topic.
The strut has to come out of the knuckle to access the top mount/bearing which have to be removed to get the spring out and to re-torque the strut nut correctly.
Unless you like working with zero clearance, visibility or access. If that's the case, have a great time.
I assume he means a method like this, where you remove the brakes, unbolt the knuckle from everything, and remove it with it. Then just change the spring with the whole assembly off the car.
After fighting with the strut to get it out of the knuckle myself, I can see how that may be an easier method if you have a full garage of tools. But for your regular DIY enthusiast, I think the 2x4 may be the best way.
2 x 4 isn't bad if you have 2 people. I wouldn't do it by myself. It really helps to have someone handling the strut and someone working the jack that understands what's happening.
100% do not need 2 people for 2x4 method if you have the strut spreader. It comes out so easy.I can absolutely agree with that. The two things that would have made my install infinitely easier would have been an actual strut knuckle spreader (still waiting for it to get delivered, despite originally supposed to come last Friday), and a second set of competent hands.
