Rare Ara S3 Vortex XL build
Rare Ara S3
Michigan
2017 Audi S3, GTI
Have you already done a smoke test?
Aint nobody got time for that.
I’m going to do another leak test and then I might go to a friends shop to smoke test
Rare Ara S3
Michigan
2017 Audi S3, GTI
Nick said there is a leak between the two sensors
Rare Ara S3
Michigan
2017 Audi S3, GTI
Ram another boost leak test with the apr insert. The only air moving is coming out of the oil cap. If I put the cap on then air starts flowing from the pcv hose at the turbo inlet pipe connection. I’ve sprayed the connections with soapy water. My boost tap is not leaking. I can hear air flowing in the manifold.
So with that amount of airflow, will there be enough pressure to even find the leak ?
Rare Ara S3
Michigan
2017 Audi S3, GTI
Ok so I found one. Just not where it I thought. IC inlet
Rare Ara S3
Michigan
2017 Audi S3, GTI
Sourcing t bolt clamps to replace the worm ones. Plus I broke one today. Found that one leak on the IC inlet. When I pulled the hose I saw the aluminum had corrosion where the leak was. A scotchbrite pad has it looking new and leak free now. Also found a leak where the EQT hose and solid pipe meet. It’s interesting seeing how far hoses move when you put 30psi in them
Rare Ara S3
Michigan
2017 Audi S3, GTI
Went ahead and ordered a Bosch 4 bar and EQTs new 5 bar map. So I know that’ll make a few people in here happy. 🤣
Rare Ara S3
Michigan
2017 Audi S3, GTI
Did you ever fix the boost leak or the deviating PUT vs MAP in the logs?
Got new clamps. Haven’t had a spare minute to install and retest. Been working a bunch of overtime
Rare Ara S3
Michigan
2017 Audi S3, GTI
Been working on boost leaks. Got t bolt clamps for all the pipes and got those leaks taken care of. But I found two at the port injectors. On is coming out of the harness connector which I found odd. But the seal was pushed out. I push it back in and when I pressure test it pushes back out. See the pics. The other leak is around the seal at the rail. Somehow I doubt I should have leaks through the injectors electrical connection
daconchslop
SC
ACS SE/Tech
Yea. That’s not right. It’s leaking boost or fuel, or both?
Rare Ara S3
Michigan
2017 Audi S3, GTI
Rare Ara S3
Michigan
2017 Audi S3, GTI
I’ve reached out to EQT and Precision Raceworks
