JerseyDrew's 2016 GTI S build, a.k.a. Jersey Devil
JerseyDrew77
Jersey Devil
Straight to the damn point, my mod list...
Brakes
VTT Ultimate Drag Brake Kit w/6 POT Wilwood Calipers, Wilwood Pads and SS Brake Lines (Front)
Stoptech Slotted Sport Rotors w/Hawk HPS 5.0 Pads and USP SS Brake Lines (Rear)
Engine
AEM 5 Bar (Intake Manifold)
APR Oil Catch Can
Bosch 4 Bar (Charge Pipe)
Braille Green-Lite G30 Battery
DBV2 3.5" Air Intake
DBV2 3.5" Dump Tube
DBV2 Big FMIC (1000 WHP CSF Core)
DBV2 G30-900 Turbo Kit
Fluidampr
Galano Engineering Intake Manifold
iABED Throttle Body
NGK Racing Plugs (Heat Range 9)
SuperPro Engine Mount Kit
Exterior
Aerofabb Competition Series Rear Diffuser
Aerofabb Rear Spoiler
Aerofabb Side Splitters
Black GTI Fender Emblems
DBV2 Headlight Duct
Debagged Rear
ECS Rear Diffuser
Ed’s Replicas Headlights with Morimoto Elite 5500K HID’s
Ed’s Replicas MK 7.5 Taillights (Dynamic Turns)
EmK Lighting Smoked Dynamic Turn Signals (Side Mirrors)
Gloss Black Front & Rear Emblems
Gloss Black Side Mirror Caps
Plastics 4 Performance Lexan Polycarbonate 7 Window Kit
Premium Deutsch Carbon Level 2 Vented Hood
Premium Deutsch Carbon Level 3 Rear Hatch
Rear Wiper Delete
Fluids
Motul Competition Gear Oil 75W140 (Transmission Fluid)
Motul RBF 660 (Brake Fluid)
Motul 300V Racing Oil 5w50 (Summer) and 5w40 (Winter)
Fueling
Fore F2i Fuel Pressure Regulator
Galano Engineering Flex Fuel
Galano Engineering MPI Fuel Rail
Nuke Performance Full Flow Flex Fuel Sensor Adapter
Precision Raceworks 1300cc MPI Fuel Injectors
Precision Raceworks Stage 4 LPFP (Dual Walbro 450's)
Radium Engineering Fuel Pulse Damper
RedHorse -8AN Fuel Lines
RedHorse Inline Fuel Filter (10 Micron)
Torqbyte PM4
Suspension
Fortune Auto 510 Coilovers w/Swift Springs (8K/12K) & Higher Rebound Force (Custom Made)
H&R 26mm Front Sway Bar w/SuperPro Adjustable End Links
H&R 24mm Rear Sway Bar w/SuperPro End Links
SuperPro LCAs
TyrolSport Deadset Kit Front & Rear
Verkline Spherical Adjustable Rear Trailing Arm Kit
Tires
Front = Mickey Thompson Slicks (26/8.5 - 15)
Rear = Toyo Proxes R888R (235/40/ZR18)
Transmission
Built Transmission by FFE Racing with Dog Gears Set, Steel Shifting Forks with Bronze Sliders, and a Wavetrac Differential
CAE Ultra Race Shifter
iABED Billet RMS
SPEC Mini Twin Drag Clutch w/Lightweight Steel Flywheel (Single Mass)
Spulen High-Flow Bleeder Block
Torque Solution Shifter Cable Mount Bushings
USP Motorsports SS Clutch Line
Tuning
Chris Doumbos at Galano Engineering
Wheels
Apex Stud Kit
Front = Belak Industries Series 2 Wheels (15x9 Three Piece, Single Beadlock w/ARP Beadlock Hardware)
Rear = Enkei Racing RS05RR 18x8.5 ET45 (Matte Dark Gun-metallic)
Engine was built (2nd time) by FFE Racing with the following parts:
ACL Race Coated Rod Bearings
ACL Race Coated Main Bearings
ARP 12mm Head Stud Kit
Cylinder Head Max Flow Port Job by BBT
Ferrea Super Alloy Intake & Exhaust Valves (1st Build)
Ferrea Valve Spring & Retainer Kit (1st Build)
FFE Racing 82mm HD Pistons with 23mm Wrist Pins (Custom Made)
FFE Racing Sleeves (Custom Made)
FFE Racing 360 Degrees Thrust Washers (Custom Made)
Forge Silicone Coolant Hose Kit (1st Build)
OEM Cam Timing Chain, Rails, and Tensioner
OEM Head Gasket
OEM MK7 R Oil Pump
OEM Oil Cooler Gasket
OEM Oil Pan Gasket
OEM Timing Cover Gasket
OEM Valve Cover Sealant
OEM (TRW) Valve Keepers 6mm Triple Groove
OEM (Elring) Valve Stem Seals 6mm
Pauter Severe Heavy Duty Rods (Custom Made)
Supertech Bronze Valve Guides
In possession but not yet installed:
Belak Industries Series 2 Wheels 15x3.5 one piece skinnies for the rear
Racetech RT4119 Series Race Seat
S&W Race Cars 10 point Sportsman Roll Cage
JerseyDrew77
Jersey Devil
Here's my very first dyno run back on March 09, 2018. My car was not tuned at the time but had the following mods: CTS direct fit IC, COBB intake, MAP downpipe, and AWE track cbe.
JerseyDrew77
Jersey Devil
Bought some new summer wheels this past Thursday. Picked up the Enkei RS05RR wheels in a Matte Dark Gun-Metallic color but they are currently out of stock so it will take 2 - 3 weeks for them to come in. So now my VMR wheels will be my winter wheels and the Enkei's my summer wheels.
Next will be some Belak wheels with slicks for the dragstrip.
Enkei Racing RS05RR wheels
