JerseyDrew77
- Virginia & NC
- 2016 TR GTI S 6MT
Get yourself a springs and retainers kit.Which ones
did you do any other head work, or just springs/valves?My car seems to rev a bit better above 6000 with the Ferrea kit, worth the cost IMO while you’re in there
Just springs and retainers, didn’t oversize the valves or port. I thought it would be overkill for a hybrid setupdid you do any other head work, or just springs/valves?
15k. Only the main bearings at the end by cylinder four and rod bearing 4 were damaged. Others looked fineWow those bearings are trashed. How many miles was on the engine build?
any idea what the cause was? machining/parts failure?15k. Only the main bearings at the end by cylinder four and rod bearing 4 were damaged. Others looked fine
No clue. Already installedany idea what the cause was? machining/parts failure?
suggest looking into a fluidampr while you're there.
