ShagginGSW
- MD
I went through and upped my log rate and something else, essentially doubling the Hz. As for the resetting I was driving and switching between tabs had and watched it reset the min max values, couldn't see anything in the Settings to manage the behavior.Set your max logging rate to max, that should smooth out any lag or stuttering unless it's device driven.
As for resetting, should only reset on long press of the screen or if you let the screen turn off or move to another screen IIRC. If the screen is on and not allowed to turn off it should keep values until long press or ignition cycle.
