LITTCO is38x - who actually runs one?
Predatorbird
As long as nothing looks damaged on the turbo I wouldn't worry about it.
Mine was banged up way worse than that (had a hole about the size of a softball in the side).
I just spoke to Dan and he confirmed it looks like paint, which is normal. The turbine spins freely and doesn't make any noises. I think the turbo is fine. I just freaked out when I saw the holes in the box. The overall packaging could have been a little better.
Predatorbird
Install kit and Cobb accessport will be here later this week. I have an appointment on March 13th for install. :D
billbadass
your moms house
looks like nothing in the picture but Dan should clearly be packaging these better for international shipping if multiple of them are having the boxes get busted to the point of stuff hitting the turbos.
Hoon
Rhode Island
He's using a decent carton and inner packing material, but things moving via air usually see rough handling (especially international).
It should probably be double boxed for international shipping.
Predatorbird
I've come to the conclusion that the turbo is fine by talking to Dan and the feedback from you guys. I can't wait to get this installed and start the tuning process.
SugarMouth
Nevada
Right there with ya!
How do you talk to Dan? Can you share a number? I have a hard time getting him to respond to email.
Predatorbird
It's been all through FB messenger. I haven't been able to converse back and forth with him. He usually takes a little while to respond, but he does get back to me.
Hoon
Rhode Island
Predator - you going to get it dynoed after install? Also recommend an e30+torco unleaded tune to let er rip!
You definitely need a HPFP to run E30, probably a LPFP also. At that point you might be able to run closer to E50 on stock injectors, which would give you more power than Torco without the nasty deposits.
Predatorbird
I’m just doing a 93 tune. I will definitely dyno it after I’m done tuning. I was trying to get my car on the dyno before install, but I don’t have time.
