Acadia18
- The Greater Boston Metropolitan Area
- 2019 Golf R
Hoon have you considered coatings? I saw that a few of the parts that you're using are coated. I built a Nissan engine once a long time ago and literally had everything friction coated and thermal coated that was possible. I ended up putting 265,000 miles on that car. It was a 99 Maxima that I supercharged. Still ran good but it was getting tired.
Compression is down on cyl 4 for me and it is burning some oil. I also toasted the clutches in the transmission so I got a whole new trans (which is cheaper than clutch packs, btw).
Best of luck, keep us updated
I am switching to a TVS dsg though so I can add 3-4bar of pressure on the clutch packs.
Would be nice paying attention on the WOT clamping pressure when shifting, mine (TVS DQ381 stage3 file) was dropping pressure when shifting which cause clutch temps high. I got my car on the dyno to run 2 > 3 > 4 gear to see torque loss when gear shifting and it dropped a LOT. See dyno below red line:
Blue line is another file I am running now but not TVS as they told me they could not fix the torque loss I was having at that time.
My DI are brand new, the mpi ones have probably 10k on themIs anyone going to get the injectors cleaned and flow tested?
If you're referring to the dips between gears, why would dropping torque during shifts be considered a problem? There must be torque reduction during shifts for effective gearshift.Would be nice paying attention on the WOT clamping pressure when shifting, mine (TVS DQ381 stage3 file) was dropping pressure when shifting which cause clutch temps high. I got my car on the dyno to run 2 > 3 > 4 gear to see torque loss when gear shifting and it dropped a LOT. See dyno below red line:
If you were getting overheating issues it was probably because of excessive clutch slip.
I see what you're saying, an issue with the rate and level at which clamping load is reapplied after a shift. Which DSG software do you have at the moment?
Sent from my CLT-L29 using Tapatalk
Tvs engineering from netherlands. Dsg stg3 specifically.
