Went back into OBD11. This is what I believe is the abs bleed function. Was talking to an Audi tech at the dealership and they say that they step through this during a brake bleed and it cycles the pump
I also found this which lets you change the size of both the front and rear rotors. No idea if it changes anything
And finally, if there is anyone who is annoyed with the brake pad indicator light, cause they no longer have pad sensors. It can be disabled via OBD11/Vagcom
Control Unit 09 Central Electrics
Long Coding
Byte 04, Bit 7 – Brake pad wear sensor – Installed/Not Installed
The piston seals that came in the caliper are fine, but my dust boots were dust after 1 or 2 track days.Finally ordered the calipers. Are the high-temp caliper rebuilt kit recommended if I plan on tracking my car? and do I need to buy the brake lines? Are there any benefits of upgrading to techna-fits?
Thanks just ordered the brake lines. Will these boots fit? I just searched for 42mm which were on the kit listed on front page https://racingbrake.com/db-42htThe piston seals that came in the caliper are fine, but my dust boots were dust after 1 or 2 track days.
Yes, you need to buy some sort of brake line, be it the stock Macan ones or the Techna-Fit. The MK7 brake lines are not in the same style and will not work for these calipers.
yesThanks just ordered the brake lines. Will these boots fit? I just searched for 42mm which were on the kit listed on front page https://racingbrake.com/db-42ht
Bah I knew there was more money i needed to spend.Thanks just ordered the brake lines. Will these boots fit? I just searched for 42mm which were on the kit listed on front page https://racingbrake.com/db-42ht
are you looking for the calipers?I’ve been following this thread and was about to do it until I contacted the Porsche dealerships and they gave me a 3 week shipping time. If anybody let’s go of their set, shoot me a PM. By chance did anyone take a picture of their cut up dust shield with air duct?
Why thank you. Not bad for $30 and a few hours of time if I say so myself.
I put it on after paint, and they have held on.Question for your (or anyone, really). Did you put on the decals once completely finished, or did you go primer > paint > decals > clear, and do the clear coat over the decals?
I believe I did primer-> paint -> decals ->clear. Two coats of each.Question for your (or anyone, really). Did you put on the decals once completely finished, or did you go primer > paint > decals > clear, and do the clear coat over the decals?
At 50 mph, there no difference.I did a horrible paint job but I don't care that much. Maybe i'll get them sandblasted and powder coated in the future.
