Raguvian
- Bay Area, CA
- 2019 GSW 4MO 6MT
At 50 mph, there no difference.
My whole car is following the "good from far but far from good" theme.
Anyone know what's needed to swap the calipers? I read I might need a torx 45 or 55 and just want to make sure I have everything I need.
Just 21 mm socket, torque wrench (200 Nm) and 11 mm wrench for bleeding. And line removal..I don't remember if it's also a 11Anyone know what's needed to swap the calipers? I read I might need a torx 45 or 55 and just want to make sure I have everything I need.
Looks good! Going to be my first time using the motive bleeder for doing my brakes as well when it arrives in the next few days. All the Youtube I've seen where they used it, they seemed to continue to let the fluid come out regardless of if it stopped bubbling until they saw the new lighter color fluid coming out. Wondering if after I finish if I will have a firm pedal like I want or if it will just be "ok" as you described.I finished installing the brakes today. Keeping the brake pedal depressed the whole time was a great tip (and is actually mentioned in the Erwin manual) and didn't leak a drop for me.
I'm not sure if I did a good enough job bleeding the brakes. It was my first time really using the Motive Power Bleeder, and it seemed to take no time at all before bubbles stopped coming out. I thought I was doing something wrong till I saw my (fairly big) bleeder bottle was full. I guess it just makes things much faster instead of the pedal method as it continuously forces fluid out instead of just 1 pump worth of fluid?
I did the FL, FR, RL, RR order and did it twice to double check, then did the VCDS adaptations as from the 1st post. The pedal feels OK with the car off, but unfortunately I wasn't able to drive the car as I ceramic coated it yesterday and it started snowing today (can't get the car wet for ~72 hours). I'm hoping while bedding in the brakes I can cycle the ABS a few times and rebleed next weekend. Whether or not I need to re bleed I'll take the wheels off anyway to check for any leaks, and also to do some wheel well cleaning behind the fender liners.
I absolutely love the way the brakes fill out the 17" Motegi's. Thanks all for your help, and I'm sure I'll have more questions as I bed and break in the pads.
Gotcha, I plan on using Pentosin DOT 4 which should work fine from what I hear.The Motul RBF600 looks the same as the factory stuff so it's hard to tell when the new stuff comes out. I used to switch between ATE Typ 200 and ATE Super Blue but Super Blue was banned for being dyed...
Looks great! Thanks for the tip on keeping the brake pedal depressed. Guessing you did it so fluid doesn't come out while replacing the caliper and lines? I also bought the motive brake bleeder. 50 bucks for something I'll probably use more than once. Will probably make me want to flush out my fluid moreI finished installing the brakes today. Keeping the brake pedal depressed the whole time was a great tip (and is actually mentioned in the Erwin manual) and didn't leak a drop for me.
I remember you had clearance issues with your studs and lug nuts with the Motegis. What did you end up doing to get them to fit? Did you go down to 17mm nuts?I absolutely love the way the brakes fill out the 17" Motegi's. Thanks all for your help, and I'm sure I'll have more questions as I bed and break in the pads.
Yep, the manual says to open the bleeder on a caliper (I did drivers front), then depress the pedal and keep it down. I used a jack handle wedged onto the seat. Then close the bleeder valve and you're good to go.Looks great! Thanks for the tip on keeping the brake pedal depressed. Guessing you did it so fluid doesn't come out while replacing the caliper and lines? I also bought the motive brake bleeder. 50 bucks for something I'll probably use more than once. Will probably make me want to flush out my fluid more
