odessa.filez
- Roswell, GA
- 2016 GSW 1.8tsi auto
My car is not stock otherwise but I'll try and give you an idea..alignment specs below were with 20mm spacers up front, camber plates set to zero camber change, +1 caster change, and tt arms set to min camber. GSW lowered roughly an inch (or roughly GTI minus 3/8”).i read all the pages and i am still a bit confused. can someone answer the following questions
How much camber adjustment do these arms/balljoints give?
How much does the caster change?
Are these arms longer ( wider track) than the gti arms?
thanks
I think it added a slight amt of caster, maybe as much as a half degree. Lined up against stock arms, the bolt triangle appears to be rotated forward slightly.
Camber, I'm guessing around 1.5 to 1.75 more (negative).
Front Track - my recall is it looked about an inch wider, measuring toe. Add another 12mm (6mm each side) when max'ing out the ball joints.
Beyond the printout below....With my camber plates at 4.5 out of 5 notches inward and arms fully extended, I see ~ -5 degrees of camber. See pics
