Audi TT (8S) Control Arms
yakev724
NYC
2015 S3
spacing for the studs is different between TT and mk7 arms. Not 100% sure if cupra runs mk7 LCAs, but seems that way.
If you want more camber get eurosport top mount inserts and CSS swivels (again, if compatible with your cupra), that's good for a touch over -3 deg.
scrllock
MI
cupra is basically GTI CSS with Mk2 TTRS brakes as a factory option IIRC. (sub 8 package).
what are you trying to solve with the TT ball joints? if it's extra camber, get camber mounts.
snox
belgium
leon cupra 300
In fact, many parts of VW MK7 GTI CS come from the cupra, few people know it. the "performance" brakes do not come from a ttrs there are small changes :)
ball joints cost less than camber mounts, so i want to know if it would fit on my control arms.
i want a little bit more camber for PS4S or CUP2 for the track
scrllock
MI
what are the small changes?
odessa.filez
Roswell, GA
2016 GSW 1.8tsi auto
DerHase
Hampton Roads, VA
2019 GTI Rabbit
PSA: for anybody in need of all the camber and concerned about tie rod engagement: Confirmed that Arteon inner tie rods are 20mm longer.
This is a Delphi part number TA2903 purchased from Rockauto in the name of science.
It SHOULD cross reference to this as an OEM VW part:
561-423-810​
https://vw.oempartsonline.com/oem-parts/volkswagen-inner-tie-rod-561423810?c=Zz1zdGVlcmluZyZzPXN0ZWVyaW5nLWdlYXItYW5kLWxpbmthZ2UmbD0zJm49QXNzZW1ibGllcyBQYWdlJmE9dm9sa3N3YWdlbiZvPWFydGVvbiZ5PTIwMTkmdD1zZWwmZT0yLTBsLWw0LWdhcw==
Or this from FCP for a more reasonable price:
https://www.fcpeuro.com/products/vw...tTML5hsJyIcmB0-HysY167CbIH2FOAhoaAvI6EALw_wcB
00Zero
Pittsburgh, Pa
561-423-810​
What are the odds an arteron front control arm fit and adds negative camber?
i uses the same ball joint so that end will fit
odessa.filez
Roswell, GA
Parts.vw.com shows the arteon LCA as only fitting arteons, so perhaps you are on to something. OEM can be had at rockauto for cheap if you wish to explore.
