What is the most stealth hitch?
virpacalis
near Philly
'17 R DSG
No regrets with my Torklift EcoHitch.
bcgti
BC
I just went through this and got the Drawtite hitch which is a cheaper version of the ecohitch. Curt doesn't list a compatible hitch for 2016 but there is one for the 2017 model - I thought there wasn't a difference between 2016 and 2017 but there is and it doesn't fit as I tried!
So the only options for the 2016 model is the Ecohitch and Drawtite which are both similar setups that look as stealth as you can get.
IDontLikeSpam
Denver CO
Ecohitch on a 2016.
Hard to say how to make it stealthier without compromising usability.
shep13
North Pole
Thanks guys. I decided to go with a curt hitch https://www.curtmfg.com/part/11564. It's less expensive but similar to the eco hitch. Also using curt t-connector for 2017 golf R. I have a 2016 but they are the same so I dont know why 2016 isnt listed.
I plan on towing a couple dirt bikes on a trailer, aprox 1200lbs total max.
southpawboston
Somerville, MA
I've got the curt + curt T-connector for the lights. Totally happy with the fitment and stealthiness.
Tomorrow I'm pulling a u-haul with 700 lbs of slate paving stones 230 miles. That's its shakedown test!
shep13
North Pole
Curt hitch installed. Fit great and easy install.
quality_sound
hmm.......
Shaw AFB, South Carolina
'21 GTI S DSG
Do all of these require the bumper cover to be cut? I'm not going to leave my hitch on all the time and I definitely do not want to cut the bumper cover on a 2-day old car.
Thanks!
krisprz
Yorba Linda, CA
2018 Golf R 6spd
What’s the towing capacity for the Golf R?
shep13
North Pole
Thanks!
Yes, all the hitches with the hidden cross member bar required you to remove a section of 3.5"x2.5" from the rear valance. I used a dremel to cut it and a piece of rubber hose for trim.
