What is the most stealth hitch?
avenali312
Mableton, GA
2015 GTI
I've had the Ecohitch installed for a couple a years now, no complaints. It has a stealth look, all that is visible is the receiver. And I was able to install it myself with some cursing and a prayer!
After browsing the comments, just want to note the crash bar is not removed, at least not with the Ecohitch. You had to remove the foam padding, so the hitch mount could mate up with the rear bumper, but I don't see how this will compromise safety.
I was able to retain my foam on my GTI with the EcoHitch.
https://www.golfmk7.com/forums/inde...venali312s-oem-gti.343666/page-3#post-7027103
santib
Suwanee, GA
Golf R
Is this the hitch you installed?
https://stealthhitches.com/products/volkswagen-hitch-shr34003
They say it only fits the 2018/2019 year R because of rear fascia changes, but in an installation video I found on YouTube, their box was labelled as fitting 2016 to 2019 R models!
i’ve got a 2016…
I had StealthHitch install it and they said it fit but just had to trim the lower diffuser plastic a little different that on the ‘18-‘19 R’s. I have had it on the car now for three years without any issues. My favorite part is that when I remove the receiver you cant tell it has a hitch at all.
speeding_ant
NZ
For those of you with a Curt hitch, any issues with driveway clearance or scraping? The StealthHitch looks like it sits a bit higher, which I'd prefer but I can't find anyone to ship the StealthHitch to New Zealand...
southpawboston
Somerville, MA
I've got a Curt, and never had any driveway clearance issue. The lower valence is lower than any part of the hitch, so if anything were to hit first, it would be the valence. The only thing that's every hit the ground during a driveway approach is my rear mudflap.
https://drive.google.com/file/d/1lbTS2i7YhZY4W9dGa2l_eS_uk548iPGP/view?usp=share_link
speeding_ant
NZ
Thanks for that. Looks like yours is a bit higher. Looking at the hitch for the R Hatchback it seems to sit lower than the valance.
Anthony3o55
South FL
I have the curt hitch on my GTI. I'm on air suspension and I ride with the car very low with the rear tire tucking. The only issue there is going over a speed bump to quickly and the energy of coming back down. The hitch definitely hits the speed bump. When it hits. It hits hard. I go slow and never have an issue since. If your rear isn't tucked like mine you'll clear it.
