I swear somebody on the forum has done both open diffs in an "R".....can't remember who but I've seen it...or its a different forum..either a UK or European one...
Anyway the only stuff I've written on the Wavetrack is from my big post on the GTI-PP VAQ unit here
How the VW Golf GTI Performance Pack (PP) “Front Differential Lock” (VAQ) works. | GOLFMK7 - VW GTI MKVII Forum / VW Golf R Forum / VW Golf MKVII Forum
QUOTE:-
Wavetrac LSDs have a device in the centre of the diff which responds in zero load situations, quote:-
"Precisely engineered wave profiles are placed on one side gear and its mating preload hub. As the two side gears rotate relative to each other, each wave surface climbs the other, causing them to move apart. Very quickly, this creates enough internal load within the LSD to stop the zero axle-load condition." The amount of preload can be adjusted by changing the standard carbon fibre bias plates for ones made from a different material & thus having a different friction coefficient, quote:-
"These bias plates provide a mechanism to tune the response of the differential as a function of applied torque load. The applied torque load manifests itself as an axial load from the differential pinions into the housing. This axial force is then considered a normal force into the bias plate, and as a function of the effective coefficient of friction, provide a resistive torque to the rotational motion of the differential pinions. The resistive torque will add to the resistance of relative rotation of all components within the differential. The resistive force, however, is non-uniform since it is a function of the axial load from the differential pinions. The unbalance of the resistive torque will manifest as non-uniform energy absorption within the differential causing a bias ratio.".
I also found a report by someone who had a Quaife LSD in a FWD car & worked with Wavetrac to develop an LSD for his make of car (i.e. used his as a test car). He found that the Quaife was more "on -off" in its transitions whereas the Wavetrac was more neutral/smoother in its transitions.
