Looks like the outer right connector is pinned correctly. In your coding Lasttyp27 is set to not active but the right turn signals turn on solid with the headlights.
2015 NA GTI? If it is a very early car VW might have used Leuchte26 instead of Leuchte27 for the grey wire that you have relocated from Pin4 to Pin3. Please replace the coding that is in Leuchte26 line by line with the values of my pdf for Leuchte27.
Does that make sense?
As @gixxerfool mentioned please revisit the whole coding list and check every line.
Big shout out to @zero815 you were absolutely right VW did use leuchte26 on my car.
after coding leuchte 26 my right turn signal worked perfectly and so does everything else..Thank you @ZERO815 also @gixxerfool you guys really helped out big time![]()
