I not sure if i missed anythingHy mate so I finally moved the wires around the driver side everything seems to work only the right side Passenger that won’t work except for reverse the blinker lights acts as reverse
Thanks
In the wiring diagram I listed earlier, are the wire colors matching to the ones in the car? Is all of your coding correct?I not sure if i missed anything
Thanks
Mate you mentionedSorry for the delay.
You will need a terminal for inner-left body side tail lamp harness. you can source these from TE Connectivity or a supplier of their parts. Here is the VW part number 000-979-025-E for the actual wire. It’s really expensive for one wire, but it’s crimped with the correct terminals already and you can order from whatever VW stockist you would like.
Another option, since you need to remove pin 4 from the outer-left body side harness anyways is to snip it and reuse it for the third wire. if you go this route, I highly recommend you leave enough length in order to splice it back to stock if you want.
On the hatch side of the harness, you will need to locate the inner-right tail lamp harness connector. Pin 4 should be a black and blue wire. You will splice the third wire into this. You don’t disconnect it from the connector, just add on the third wire to it.
Run your new wire in whatever fashion you choose across the hatch to the inner-left body side harness connector. Plug the precrimped terminal end into space 4 which, if you followed the rest of the same guide should be vacant now as that wire is in spot three. So the new order from 1-5 on the inner-left should be:
1-gray black
2-red
3-blue black
4- new third wire from the inner-right
5-empty
This is Zero815’s guide, not mine, but it was the only information I needed to get this done. Mind my scribbling at the top.
hope this helps
The new wire is spliced to pin on inner right. Then the remaining end on the new wire goes to pin 4 on the inner left.Mate you mentioned
On the hatch side of the harness inner right i need to join together the black and blue wire with new reverse wire that goes to pin 4 ?
Is this what you meant
Basically pin 3 and 4 on the inner right is joined by splicing?
Mmh thats where it gets confusing do you by any chance got any picture of this i was looking at the diagram you sent yesterday i dont see this ?The new wire is spliced to pin on inner right. Then the remaining end on the new wire goes to pin 4 on the inner left
Mm
I think thats where the problem is
Ty Mate
I think I might have moved the inner right to 3 whereas it should have remained just spliced with the new wire from inner left pin 4View attachment 241106
Red circle is spliced. Blue is where the other end goes.
Ah. That would do it.I think I might have moved the inner right to 3 whereas it should have remained just spliced with the new wire from inner left pin 4
3 right 2 leftHy mate everything works just fine except for the right blinker mate i have 3 Wires on the right blinker or is it supposed to be 2 like the left side?
It seems to more wiring. On the right there’s a wire in spot 1,2, and 3?i have this light when i turn my headlight on could it be to coding?
you think it could be coding? I tired the dap coding before the zero815 coding guide .3 right 2 left
It could be coding. Be sure to check all parameters closely. If you had any other coding in there before these tails then you need to revert those settings back to stock.
No. Just revert the coding. The lights can stay. If you have the Zero815 list of parameters then it will have both the factory and new parameters.you think it could be coding? I tired the dap coding before the zero815 coding guide .
to revert back to stock do I need to connect my halogen tail light and code back to stock?
