vland mk7.5 Sequential taillight
JTM88
Broken Arrow, OK
2016 GTI
What is everyone using for the jumper/repair wire? It’s listed as the yellow wire, part number 000979025E . VW sells it for $55 but I wasn’t sure if others were making this wire manually? Trying to avoid spending that much $ if possible.
I bought mine off of Ali Express.
https://a.aliexpress.com/_mOePBK2
Frag
Tennessee
2016 MK7 GTI
I replaced the terminal pin, turn signals work now. The fog lights are acting as the reverse lights. Wiring issue again?
Kart17
SE Michigan
'17 VW GTI Sport
Got these running fine with the instructions. Now here's a question is there a way to get the rear fog to work? Obviously need a switch at the front too.
gixxerfool
New Jersey
2016 Golf R
I would like to do this too. I can’t find any definitive guide but the Vlands do seem to have a wire broken out for the rear fog. I already have the switch just need the final piece of the puzzle.
EpicTech
Houston
MK7 GTI 6sp w/PP
VLAND Wiring diagram. I have these tailights myself with the euro switch
  • 20230501_H_70NH70RL_mod.pdf
EpicTech
Houston
MK7 GTI 6sp w/PP
Do you mean the coding instructions?
ZERO815
Köln Germany
2017 GTI SE DSG
Shouldn't be a big challenge to activate the rear fog(s) if you have followed my DIY for Vlands. Can make a drawing for it tomorrow.
EpicTech
Houston
MK7 GTI 6sp w/PP
I have your instructions I can send him on my pc at home.
EpicTech
Houston
MK7 GTI 6sp w/PP
I was going to try and find that link on this forum where he posted that instead of waiting until I got home, but I'm at work and got busy lol. Glad you found it.
Kart17
SE Michigan
'17 VW GTI Sport
That would be appreciated. Wired and coded exactly how your guide said works perfectly. Just want fog lights.
ZERO815
Köln Germany
2017 GTI SE DSG
If you have the lights wired and coded as in my earlier instructions it is as simple as the following:
- Re-locate the Grey/Black wire from Inner-Left Pin1 to Pin5
- Add a repair wire from Inner-Right Grey/Red wire to Inner-Left Pin1
- Get a proper light switch. If necessary, get fog light trigger wire (VW part# 000 979 009 E) and install it between
BodyControlModule Connector A Pin 29 and headlight switch Pin 5
- Coding of Leuchte23 and headlight switch
Coding rear fog light:
Coding fog light switch:
Otherwise attached you'll find the DIY instructions if you start from scratch.
GL
  • DIY_NA_MK7-VLand_MK7.5style_wFog_ZERO815.pdf
gixxerfool
New Jersey
2016 Golf R
GL
Thanks so much for this! Time to source some wiring for the BCM.
