So is the noise gone now?
Yes it is. No more noise.
I need to look at the stock mount again but it actually seemed okay when I took it off. There was some play in the bearing but nothing major. Maybe the mount and bearing separated and became unseated. Just a theory. Unfortunately it was late and I didn't think to check that before I took the strut apart.
Btw, does it matter how the end of the spring is positioned against the bearing?
On the reinstall I positioned the end of the spring against the thin side of the bearing to make it as level as possible. Not sure if that matters but figured it couldn't hurt.
