Ed @ EQT
GOLFMK7 Official Sponsor
- Fairfield, CA
- MK8 Golf R
Stock plugs gapped down work fine for most stock turbo setups.
Reading between the lines, it really seems like EQT's recommendation is the "cover your ass" recommendation after their facebook group started obsessing about spark plugs. There were incidents where ground straps were cracking off in the cylinder, generally RS7 plugs, and various unverified anecdotes where this or that spark plug made all of somebody's knock go away.
Are the non-projected racing plugs the choice that is the least likely to give you problems when you're thrashing your car at high boost over and over? Possibly. Is a colder heat rating optimal for combustion under normal driving conditions? No. Is it economical to run an expensive racing plug with a short service interval on your daily? Also no. It's all tradeoffs that each owner must weigh. The most important thing is to inspect your plugs every now and then, if you gap em gap em correctly, and probably do steer clear of the RS7 plugs.
The EQT Farcebook page is a huge poop show of bad information. I've been in that group long before getting my EQT tune...and I've never seen so many people have so many issues with spark plugs.
This is what happens when companies decide to use FB as the main platform for customer service, marketing, and sales... It ends up being a mess!The EQT Farcebook page is a huge poop show of bad information. I've been in that group long before getting my EQT tune...and I've never seen so many people have so many issues with spark plugs.
Here's a table of plugs I put together. For stock heat range plugs, the Rutheniums are v. good.
No, they're fun. Post pics of your used plugs so I can talk shit about them.
haha...doesn't matter, I've posted this hear numerous times and in big spark plug thread we already have going. I found it in another thread just now searching "spark plug table".Can we pin this somewhere? Or maybe someone could create a Master Spark Plug thread to try and put a damper on all these spark plug questions.
Will add. Thank you.you should add denso 5347, their projected 2 heat range colder plug
Spark plug anxiety is at level 11 in the MK7 community for whatever reason.
Did you tune it yourself? horrible
next!
