Raguvian
- Bay Area, CA
- 2019 GSW 4MO 6MT
I think it will need a bigger hole to access each of the four hex screws from the top, however, obviously plenty of room for the piston/adjuster. I don't think you want to get TOO crazy with the hole diameter though, but that's just me.
That said, you may be able to just undo the strut mount nuts on top and drop the whole unit down while it's still in the knuckle. Worst case, the whole unit comes out which is straight forward given their overall length (shorter than stock, and can obviously be adjusted).
@Will_, looking forward to hearing what the front camber ends up being!
Only issue is those bolts are one time use so it would suck to keep replacing them every time you want to change camber.
