Hey guys, I was just reading through your thread. I’ve driven performance single mass flywheel clutch systems for a long time, my experience is that the chatter stops once you have engaged the clutch. If you are hearing other transmission noises perhaps you have something else going on? I was doing a ton of reading the past two weeks trying to find the right fluid for our R’s manual transmission. I was only able to find two fluids that reference our actual OEM spec number of “G052527A2”, the actual VW fluid and Redline’s new MT-LV 70W/75W. I’ve just finished installing a stage 2 clutch and single mass flywheel, my Redline fluid is arriving Tuesday so I’ll be able to report transmission noise levels shortly after. If possible, I’d suggest trying to use a fluid that states its compatibility with our spec number. Don’t use any GL5 fluids or fluids that are GL4/GL5 compatible either. From what I’ve learned, anything that complies with GL5 performance standards will have the wrong coefficient of friction and the fluid will likely not compress enough under load, possibly resulting in gears not engaging fully. In the long run that could cause excessive wear and tear. I’ll let you know how the Redline fluid sounds in my R.
