Rare Ara S3 Vortex XL build
Rare Ara S3
Michigan
2017 Audi S3, GTI
What size pistons did you go with and what's your P2W clearance?
Sorry to leave you hanging. Theyre 83mm but I don’t know the p2w specs as it hasn’t come back from the machine shop. This place has built several so I trust they know what they’re doing. Between machining and waiting an eternity on parts I’m not one to keep bugging them.
Rare Ara S3
Michigan
2017 Audi S3, GTI
Just realized it’s been 2 months since I last updated. I finally got the assembled engine back yesterday. I got right to putting it back in. Mated with the trans and installed the wire harness.
Rare Ara S3
Michigan
2017 Audi S3, GTI
Today it pretty much looks the same but I checked off several items. Axles. Driveshaft. Heat shields. Water pump. AC and alternator. Most of the electrical connectors. MST inlet is on along with the EQT turbo muffler delete and discharge piping.
Rare Ara S3
Michigan
2017 Audi S3, GTI
Manifold with MPI is in. Need to make some fuel line and decide where I want the ethanol sensor.
Rare Ara S3
Michigan
2017 Audi S3, GTI
So before I fire this thing I have a question that no doubt has been asked before. Since I’ve completely removed the engine I’m trying to reduce the number of variables that could go wrong. Obviously it was easier to bolt up the XL while the engine was out. Before I flash the EQT tune that’s set up for MPI and the RS3 pump, I’d like to make sure it runs so I’m not swapping the pump and I’m leaving the IE stage 2 tune. Does anyone see any issue with idle or driving the car around the shop like that ? At least I’ll know it runs before I dig into the fuel pump.
Acadia18
2019 Golf R
Rare Ara S3
Michigan
2017 Audi S3, GTI
Well it’s running. No errors there. I primed it by cranking several times. Checked the oil filter and it was full. Fire it up and it runs smooth but there is rocker or lifter noise that sounds bad.
PowerDemon
Richmond, VA
Golf GTI, Camaro ZL1
Good news is EA888s don't have rockers or lifters so I don't think it's that. Is it a tick? Got a video?
Rare Ara S3
Michigan
2017 Audi S3, GTI
Yes. Will a video post directly to this forum?
Rare Ara S3
Michigan
2017 Audi S3, GTI
this doesn’t quite get the noise on video
