Well boys and girls, I threw on the CTS PCV plate and put on the Spulen line to the N80 that has the checkvalve because I wanted to see if my catch can would still fill with oil after a few pulls.
Welp, sure enough, it still does. So that sucks. I guess I either just have too much blowby or perhaps oil isn't draining properly from the head, though I doubt that's the case. In my leakdown tests, cyl 1 is a little leakier than 2,3,4 (which are perfect) so maybe that's the culprit. Regardless motor still seems very healthy otherwise and still makes good power. I will just stick with stock PCV, which doesn't ever give me issues, except at the track. And at the track, I guess I will just have to smoke around the corners. lmao
So couple things, Spulen isn't to blame after all, and I can also take what their tech was telling me more seriously. I'll leave this here:
"Please keep in mind we have extensive experience with these exact builds, we currently have 2 Golf R's in the shop that had this same issue as they were built at another shop and kept eating up the blades on the APR stage 3 kit. After spending some time investigating, we've come to find out no matter what catch can plate we put on the build, it would blow raw oil into the turbo. We decided to pull the engine apart and inspect, as the blow-by was just too excessive to be normal."
"Through further digging, we end up finding the pistons were dragging on the walls from the incorrect piston to wall clearance. We rebuilt the engine with new pistons (83mm) and set piston to wall clearance to the correct specs. After completion, we performed the same test on the dyno with clear tubes running to the can and plate and no more raw oil."
FWIW I scoped my walls and they look pretty clean. But like I said, maybe that extra 5-7% leakiness from cyl1 where 2,3,4 are practically 0%, is the culprit? Seems plausible.
I have a track day tomorrow. #sendit
