Quebster
- Dallas, Tx
*No longer IS38*
Hello all! I have finally reached too many mods to contain in my signature, so I suppose it's time to start a build thread! This will be for those curious about my build, as well as myself to keep records on my car.
Instagram: @thequebster
This is the first car that I have actually bought, my first VW, and the first time I've delved into the whole car scene and modding. Wow, what have I gotten myself into? It has been an awesome few years of modding and learning so far. What a great car! I bought it in August 2014, and never touched it as far as mods until August of 2015. I then went with Stage 1.5 Eurodyne (birthday gift from wifey!), and after that I caught the mod bug, and have been upgrading ever since. It still blows me away how much power we gain with a simple tune in these cars.
My goal for this car is to be comfortable enough to daily, but mean enough to get out on the track (with turns) and *reliably* do some good work. I do enjoy the occasional Mexico run as well, so I am constantly trying to find the right balance. I likely will never mess with 1/4 mile shenanigans, not really my thing. I realize trying to be a jack of all trades makes you a master of none, but I'm ok with that, as long as I'm having fun!
So far I love it, and it has been a blast on the track! My money has first and foremost gone to (mostly) performance/supporting mods. I don't want to do anything too irreversible as I will want to strip it down and trade it in around when the Mk8's come out (EDIT: Maybe, thinking may hang on to it longer now) (EDIT AGAIN: Yeah, I'm way past this point now
) (EDIT AGAIN AGAIN: The Mk8's are fugly!!)
So that's the backstory. Anyway, here's the list, which I will edit, add pics, and make everything look pretty as time goes on!
2015 GTI S 6MT Deep Black Pearl - Non-PP, non-LP, base as base can be, then modded to glory!
Current Performance Modifications:
Cheers!
I will add more pics as I take them here:
Phone Charger:
Brakes before and after:
LED Floor Lights:
Bass Level Knob (Before I installed my other phone charger):
One of my favorites. During this session, shop installed IS38, Clutch, Intercooler, Wavetrac, CTS DV, Charge Pipes, flushed out/cleaned engine, and more:
New CircuitWerks Exhaust:
- DBV2 V3 TBB w/ DBV2 TIP
- Eurodyne Maestro Tuned by Wy2Sl0
- Wavetrac LSD
- Precision Raceworks Stage 4 LPFP & MPI (Dual Walbro 450's)
- Fluidampr Engine Damper
- CTS Cold Air Intake
- APR Intercooler
- DBV2 3.5" Down/mid pipe
- CircuitWerks V2 Axle-back Exhaust
- CTS Throttle Pipe
- Devil's Own DVC-30 Meth Kit w/ DO3 Nozzle (For IATs, controlled by Snow Performance VC-50 Boost gauge/Meth Controller)
- Spulen V2 Catch Can System
- Southbend Stage III Endurance Clutch w/ Flywheel
- Diesel Geek Sigma 6 Short Shifter (replaces shifter bushings as well)
- BFI Heavy Weight Shift Knob SCHWARZ - Golf Ball
- 034 Motorsport Shifter Bracket Bushing Kit
- HPA Full Dogbone Mount & Arm
- TyrolSport DeadSet Rigid Subframe Kit
- ST XTA Coilovers (DAP version)
- SuperPro Front and Rear Endlinks
- 034 Rear Sway Bar
- 034 Density Line Engine/Trans mounts
- 034Spherical Rear Trailing Arms
- Eurocode Front & Rear Chassis Brace
- Unibrace UBQ Tunnel Brace
- Stillen APRacing Radi-CAL BBK w/ J-Hooks
- OEM PP Rear Brakes w/ Matching J-Hooks
- ECS Stainless Rear Brake Lines
- Hankook Ventus R-S4's - 255/35/18
- Neuspeed RSe10's 18x8.5 et45 in Satin Bronze
- Neuspeed Hi-Flo Discharge Pipe
- CTS Throttle Pipe
- IE Tuscan Rods (rifle drilled)
- IE/Mahle Piston Set
- IE/Mahle Rod Bearing Set
- Ferrea Valve Spring Kit
- Ferrea Intake/Exhaust Valves
- Head Ported/Polished/Flow benched by Precision Raceworks
- ARP Head stud kit
- OEM GTI Clubsport bumper imported from the motherland
- TAW Chicago Carbon Fiber/Perforated Leather Steering Wheel (Sexy AF and feels oh so good...)
- RFB Headlight Replicas w/ Animated Turn Signal
- RFB 6000k HID Bulbs
- RFB License Plate LEDs
- RFB Automatic Headlight Conversion Kit w/ Euro Switch
- LLumar CTX Tint, 30% Front (Including the small triangle windows), 15% Rear, AIR 80% Windshield (Legal for Tx)
- OEM Euro GTI LED Tail Lights w/ Wiring Harness for Amber Turn Signal
- deAutoKey Color Changing LED Floor Lights (Love me some Ambiance, Set to Dark Blue, think it looks better than red)
- deAutoKey Reverse LEDs
- "Oettinger" Grille w/ Normal VW emblem w/ glossy black badgeskin (it's Chinese, not gonna lie)
- Badgeskins for all VW and GTI emblems, including sides
- EscortMax 360 Radar/Laser Detector
- Installed dedicated power wire
- Snow Performance VC-50 Boost Gauge / Meth Controller (good to 50PSI)
- Fuel-It! E85 sensor & Bluetooth transmitter
- ECS Throttle Body Boost Tap Kit
- Wireless OBDII Transmitter used with Dash Command iPhone App
- OEM Clutch Bleeder Mod & "Pedal Spring Delete"
- Alpine MRV-M500 Mono V-Power Digital Amplifier
- Image Dynamics IDQ10 10" Sub
- Installed a bass level control knob right under parking brake lever
- Installed a phone charger that comes out near the driver side vent
- Installed Soundskins sound-deadening material on all doors and spare tire area. Amazing stuff, review HERE
- Installed Soumatrix Xtase plug and play replacement speakers. Also good, but wait for a good sale
- Soundaktor off
- Windows up/down with key fob
- ECS off with long hold of button
- Disabled lighting restriction so fogs stay on with high beams
- Euro LED tails amber turn signal light programming
- Carbon look on MFD
- Side mirror dip on reverse
- Changed comfort blinking to 4
- XDS off due to Wavetrac
Cheers!
Phone Charger:
LED Floor Lights:
