TheJokker
- jacksonville
Do they jitter?
Do they jitter?
I did run into an issue with passenger side blinker. It would freak out as if it was an over voltage issue. I ended up using OBDeleven to code it out.
I ended up coding: Central Electronics > Adaptation > Light configuration >
Lasttyp 0 = 38 - LED Blinkleuchten (left turn signal)
Lasttyp 1 = 38 - LED Blinkleuchten (right turn signal)
Thanks for the report.
I'm doing mine this weekend but this blinker issue ^ scares me and I have no OBDeleven nor am I competent with VCDS.
What do you suggest I do?
Thanks.
Finished mine last night before I ordered the OBDeleven. All went without a glitch and it did not require coding the turn signals.
Took it out for a drive, great throw, great pattern and great daylight LED color temp.
The delivery from Germany took less than one week and DHL did a good job of collecting the customs fee without slowing down the process, something that UPS is not so good at.
Thanks go to both you guys, fredo and chunco, I wouldn't have done it without you.
Ahhh, you guys are making the wait for mine so difficult.
