Did the oil change last week. Dead easy, and I reused the 'O' ring sealed plastic sump plug.
5.5 litres 5w-30 507 VW spec longlife fully syn oil
Filter design is same as Mk5 GTi onwards, albeit its location on engine has changed.
Morning.
The 507 VW spec is for diesels only ,if your golf is a gti it should be 504 VW or
502 VW spec.
Hopefully it meets both specs.
VW does recommend pulling the oil from the top. I used a vacuum oil change device, no muss no fuss without crawling under the car. The whole process took 15 minutes.Does VW not recommend extracting the oil from top?
Which pump do you use? Some work better than othersVW does recommend pulling the oil from the top. I used a vacuum oil change device, no muss no fuss without crawling under the car. The whole process took 15 minutes.
I used the KTC tools CJ-169-S oil extractor. The tank hold 6.5 liters and seems to be well made. Not cheap, but it sure makes oil changes a snap. Also the tech's at the dealer say you get more old oil out from the top vs draining. I removed 5 quarts into the tank (I was a quart low at 4500 miles) and it took 6 full quarts to top off the reading on the dipstick. Works for me.Which pump do you use? Some work better than others
What pump do you use?Wow! After looking at the pictures and then under the hood of my car, this looks like the easiest oil change ever! one more pleasant surprise from my new Golf.
For years I have routinely used an oil suction pump with a tube down the dipstick pipe, the type used on marine engines where you can't get at the oil pan drain plug. How clever of VW to put the oil filter in such a convenient spot. It looks like my biggest challenge is not spilling oil when I try to put it in the filler hole (sic)!
I'm planning on my first oil change at 5,000 mi., then the free one from the dealer.
