ZERO815
- Köln Germany
- 2017 GTI SE DSG
That should be easy.
Try to post in the VCDS tweaks thread:Hey there,
Running into an issue with the Helix Mk7 Facelift Euro lights. Harness installed and VCDS coded using these instructions.
Left turn signal = Both sequential turn lights flash on and off (like emergency lights)
Right turn signal = Fine
Any ideas or help would be appreciated!
That coding varies depending on what harness you used and weather or not you coded for rear fogs.Does anyone have the original coding for factory mk7 tails? I’m removing the 7.5 tail lights and need to code back to factory settings.
Need more information.
Thanks, and which is the left? 28?Leuchte29 is right reverse light
