MK7.5 OEM LED Tails
ZERO815
Köln Germany
2017 GTI SE DSG
That should be easy.
gillbates
Hey there,
Running into an issue with the Helix Mk7 Facelift Euro lights. Harness installed and VCDS coded using these instructions.
Left turn signal = Both sequential turn lights flash on and off (like emergency lights)
Right turn signal = Fine
Any ideas or help would be appreciated!
ATR
Baltimore
'17 Golf R 6mt
murtaza911
Ontario Canada
Does anyone have the original coding for factory mk7 tails? I’m removing the 7.5 tail lights and need to code back to factory settings.
ATR
Baltimore
'17 Golf R 6mt
That coding varies depending on what harness you used and weather or not you coded for rear fogs.
Need more information.
murtaza911
Ontario Canada
So I was able to find my stock coding in the obd11 history.
But I’m having an issue where the car says there is an issue with my right reverse light.
Which adaptation is for the left and right tail lights?
Since the left side works I’m guessing I can just copy the settings.
ZERO815
Köln Germany
2017 GTI SE DSG
Leuchte29 is right reverse light
ZERO815
Köln Germany
2017 GTI SE DSG
Yes, 28.
amritdesai
New Mexico
GTI
Finally ?
Installed the OEM Tails this afternoon. Compares to the BEC replicas they are twice as bright and fitment was perfect!
Shout out to ZERO815 for an excellent harness. The install was so much easier than the BEC one - not ever close!!!
ZERO815
Köln Germany
2017 GTI SE DSG
For your MK7.5 you need to re-pin Inner-Left Pin7 (left reverse) to Pin6, and code Leuchte28 as rear fog light. For the missing left reverse light grab the signal from the right reverse light. Get yourself a repair wire, connect one end to Inner-Left Pin7, solder/crimp/butt-connect the other end to wire of Inner-Right Pin7.
Don't forget the European headlight switch and the coding for the switch.
littlejoe1
Chicago, IL
2021 ID.4 😲
Hello!
I just installed a set of 7.5 Dynamic LEDs with the DAP harness. 2019 NAR GTI Rabbit Edition. I double checked all the wiring and coding they provided, but I'm still running into an issue:
Brake Lights Work, Turn Signals Work...
But I've got no running lights
Any ideas?
