Installed a few parts over the Thanksgiving weekend. Ended up installing my Verkline rear trailing arms and my Plastics 4 Performance Lexan Polycarbonate windows in all the doors except for the two small 1/4 windows, because those were a bitch to try and remove the trim. The trim is glued on to those little windows and decided to just leave it for the professionals to deal with it since I would have destroyed it if I kept trying. Also didn't do the rear hatch because I will install that window in my new hatch, that is carbon fiber, once it arrives which I was told would either be by the end of November or December.
The OEM bolts on the knuckle were a PITA to get off. I had to use the bar to my floor jack and attach it to my ratchet for leverage and spray some WD-40 on the bolt to help loosen it up.
As you can see, the polycarbonate window is grey but not as dark as the tint on my windows. Next up is my RaceTech seat with a 5 point harness.
