That is really strange that timing advances to 9.5 in midrange and then creeps back to 7.5 on map 2 with no knock sensor or IAT interference.Hello
So I changed my spark plugs and my ignition coils
I redid some logs and it doesn't change anything. i will try the sp98 + e85
if no improvement d or could the problem come from?
https://datazap.me/u/gomze/log-1614860823?log=0&data=1-11&zoom=103-200&mark=95-137
Return the new coils if you can since your old are fine, also do a 4th gear pull or uphill if you can to get a higher load for a datalog.
