Looking for more advice please.
I am currently running on map6 with these numbers (same numbers I have been using, advice from George):
1500 0
2000 2
2500 3
3000 3
3500 3.5
4000 4.5
4500 5.5
5000 6.5
5500 7
6000 7
6500 6
7000 6
The FOL is set at: 45 (I never touched it)
I ran logs in the past with these same numbers and the logs were very clean (only engine mod was intercooler). However, since then, I have added a few mods:
- I replaced the sparkplugs with the NGK 95125 gapped at .024.,
- put on an 034 inlet tube, and smooth hose
- put on a Ultimate Racing 400 cell ceramic catted downpipe.
I did 3 data logs today, I always run 93 octane, and I was getting very consistent timing pull on Cyl#2 (ign 3). (1.2 down to .7, then down to .3 at ~6,000 - 6,500 RPM on 2 data logs, and similar pull pattern, but less at ~3,500 - 4,500 RPM on one log)
I find it strange that the timing pull curve is the same exact pull on 2 charts, then it was the same pattern of pull on the other chart, but at lower RPM's.
The car felt strong, and I didn't notice anything wrong, but I would really like to have no timing pull at all (I want a safety cushion)
To all the experts here, what should be my next move? I was thinking (based on the higher end of the Trims >40) that my FOL should be increased to 50.
If I do that, will it fix the timing pull issue? Being that the timing pull was at the same RPM's and on the same cylinder on 2 of the runs, is it possible that there is an issue with one of the sparkplugs or coils (#2 cyl)?
Or should I just lower the boost a little in the RPM range where it was pulling timing?
Here are the data logs:
https://datazap.me/u/up4speed/log-1614138010?log=0&data=1-4-25-26-27-28
https://datazap.me/u/up4speed/log-1614138180?log=0&data=1-4-25-26-27-28
https://datazap.me/u/up4speed/log-1614138263?log=0&data=1-4-11-14-18-25-26-27-28
I decided to do 3 more logs with the FOL set to 50. Here are the results:
https://datazap.me/u/up4speed/log-1614189903?log=0&data=1-4-5-14-25-26-27-28
https://datazap.me/u/up4speed/log-1614189947?log=0&data=1-4-14-25-26-27-28
https://datazap.me/u/up4speed/log-1614189987?log=0&data=1-4-14-25-26-27-28
The Trims went down to a max of 42 (I'm not sure if that's still to high). I'm thinking that I should maybe subtract .5 from the boost at every RPM range?
The first 2 runs seemed very good to me regarding timing, but the 3rd one had timing pull in two spots, and I'm not sure why.
Please give thoughts...Thanks!!
