Cynical
Newfoundland
16 gti autobahn m6
hey guys started running a jb4 last week. after fixing bad coil packs im now rdy to dial in a map6 for the gti. mod are intake, inlet elbow and turbo muffler delete, cat back from awe running on 91oct cause newfoundland suuuccckkkkkss. here are my map1 and map6 logs i did today, any suggestions would be great still learning the minute details on reading these things.
there are 2 runs for each map as well as a single run on default map6
https://datazap.me/u/cynical/map1-runs?log=0&data=1-4
https://datazap.me/u/cynical/map6-runs?log=0&data=1-4
goodvibes
IL
I'd probably run map1 and call it a day. You're getting better overall advance and at the limit.
sloopercat
Knoxville
I had a JB1 hooked up. When gas got more excited I pulled it off and went back to regular. I did not boost much down low in the rpm range, clutch concerns (stock) and it really does not need much help down low. It definitely runs out of oomph near redline. I am not wanting to use 92 octane. I am not an expert in tuning.
Long story short, can I just add some boost up top and still run regular? How much boost?
rasonline
Dubai
Mk7 GTi
Hi guys - need some help (and a lot of guidance) with my custom JB4 map please.
First time I'm attempting to use map 6 -
MK7 GTi MY2016, DSG transmission
ECS intake pipe with BMS cone filter
3.5inch exhaust downpipe (fitted small fake catalytic converter)
Resonator delete
JB4 fitted with wire tap (bought 2nd hand, so no support from burgertuning)
I did a datalog with 2 WOT runs in 3rd gear. Here is the log
https://datazap.me/u/rasonline/jb4-map-gti-mk7?log=0&data=1-4
I basically copied another user's settings on this same thread at pg26 (see the screenshot uploaded) and made some minor adjustments.
Using absolute boost (not additive)
I been browsing the forum for a while but haven't posted yet (couldn't figure out how to activate my account with gmail :-( SOmehow it works with yahoo mail though)
rasonline
Dubai
Mk7 GTi
You mean something like this?
Hey all, ever since I got the JB4 and started recording logs I was itching for a way to analyze them side by side and figure out how to make maximize power in map 6. I wrote up some macros in excel to import CSV logs and analyze them for some parameters George has mentioned we need to watch. It will show those parameters on the summary sheet and it will highlight things to look out for. You can import as many logs as you want and view them side by side. I also have explanations of each parameter and a quote from George about them.
I recommend making one workbook for each map 6 profile you get logs for. Right now you can't compare logs with different profiles. Just use the "import logs" button at the top left. You can also clear all the imported logs.
KEEP IN MIND THIS IS A WORK IN PROGRESS. I am open to any and all suggestions. I just threw this together in a few hours. Let me know what you guys think!
https://www.dropbox.com/s/b5stwyn6z0v83ub/JB4LogsSummary.xlsm?dl=1
This is my first time using a public dropbox folder. Let me know if it doesn't work.
Does anybody still have this Excel file available for download?
The original poster "nathan16mk7R" is unreachable :-(
forum status shows that wasn't seen since 2017 (not sure if there's an incognito mode that would hide status)
