Are you looking to do boost targeting or additive?
If you're looking for boost targeting, check out your logs and at the RPM points, write down your above log values (for example you're at about 22-23psi at 4500rpm) and try adding 1psi. Most power will be up top, so I'd start by adding about 1 psi from 5000rpm-redline and then working below that. You'll have less room to increase from 3500-4500 usually.
For additive, I'd recommend exporting the log to a CSV (I look at all my logs in CSV) and check the target value. Go off these values in the designated RPM points and just increase them a bit, starting at 5000rpm.
For both, I would stop increasing until you start getting knock, your turbo can't flow your requested boost, or you don't want to push your turbo any harder
Thanks very much - will follow your instructions to set up an absolute map for the warmer months. When you say “start getting knock“ - is lots of timing pull the main way to identify knock from these logs - or are there other indicators of knock i should look for?
