We are just trying to help him with his fueling issue, if you are good and happy with your current there is no need to try a different.Any particular reason to switch to an older firmware?
I’m glad I just saw this. I recently attempted to do a dragy on map 2 and the launch control was not a fan. Are you fbo as well?Happy with the 6B firmware, think I'll keep it a while longer, trims look fine and AFR is adjusting nicely.
Been playing a bit trying to dial in Launch Control with map 6. As you may know, with the DSG 7 speed you need to limit the boost up top else LC will act funky which is why map 4 (on later FWs only) was developed.
What I did on this run was to set the Max Boost 1st and 2nd gear to 5.0 while I kept the other values in my map 6. I've seen similar 1/4 and 0-100 km/h results but slighly slower times lowering boost at 6k and up. This one was 3.91s to 100 km/h. 100-200 km/h runs are low 10s on my current map and fuel on a flat road, I bet I could run high 9s if it was slightly (but still valid) downhill.
Not bad for a heavy AWD with so few mods. I think I'm at the edge of what's possible without an ECU tune.
Hi!Happy with the 6B firmware, think I'll keep it a while longer, trims look fine and AFR is adjusting nicely.
Hi!
It's pretty fast for an AWD
How can I get the 6B firmware?
Thank you
Need help. Working with a friend to stack over his uni tunes. Ran a log in map 0 and then made a very conservative map 6 raising fol to 10 and mild boost increase.
With this setting he is saying he is getting cut out/sputtering while doing a pull.
Here is the log... I am running this without any issues. Both running is38. Any help would be appreciated!!!
https://datazap.me/u/fowvaydriver/r...g=0&data=1-2-3-4-14-15-25-26-27-28-34&mark=72
He is a 1.8 also. Alltrack. Just had him replace his plugs with ngk ruthenium.Is the attached your car, or his car? Your car is a 1.8, is his a 2.0? I'd check the spark plugs first. I don't see the sputtering on the logs.
log was just car. Yeah I didn’t see it either. looks Like uni is running a lot of timing advance compared to my apr tune. I am surprised.
he is going to do another pull tomorrow in map 0 and map 6. I will post up. Thank you!!
My bad! Will do !Wouldn't hurt to gap them to .024. I've been running mine at .024 for a while now with no issues. Throw this over to the 1.8 JB4 thread!
Post a few logs to datazap so we can see what it is doing.
