Diggs24
- de plains! de plains!
- 2015 GTI
IE is bar and plate. Cheaper than Wagner too.
Wagner is tube and fin.... the only other one I'm aware of is one of the ebay direct fit ones is tube/fin as well. The more popular option that's talked about most is bar/plate though. I've only really seen one other example of an aftermarket IC that was tube and fin and it was to save weight and not block as much flow to the radiator to not hurt cooling for track performance....or at least that's what they said.
edit: and I just checked said product...and it looks like they have now moved to a Bar and plate intercooler. The part in question was intercooler for Focus ST made my Mountune.
Almost all of the aftermarket IC's are tube and fin.
Too expensive to try, just in case they didnt fit my setup.. but you can find just twintercooler hoses a few places.. my hoses sizes might not even match up.. (Treadstone FMIC with stock intercooler un-used in place.)
if i wanted to CUT my nice Treadstone hoses in the middle, and insert a aluminum "T", maybe i could run a hose to my oem intercooler also.. but an expensive test to ruin nice hoses and possibly gain nothing.
Nice find. The very seller that told me that they don't sell them separate from the FMIC is selling them separate from the FMIC.
Does anyone have this kit by chance? If I could confirm the length of that IC, as well as the outlet size, I could determine if those hoses might fit my own FMIC setup, which has 2.5" outlets I believe. (Confirmed my Treadstone has 2.5" inlet/outlet, 24" core with 28" total width.) Also found this, but don't know if its Core length, or total length: 25.2″ (Majesty)
I do and I tried what you are describing. The problem is that the Majesty FMIC hoses attach at the top of the core and the Treadstone at the bottom. Trying to push the hoses down to fit kinks them which I didn't think would be great for airflow, so I didn't do this.
But what does it all mean? The flow through an IC is only one small factor in the overall function. The Neuspeed IC for example, it still makes an improvement cooling the air over the stock IC regardless of what it looks like on that chart.
