The top number correctly read is 87 (R+M)/2,
From
https://en.wikipedia.org/wiki/Octane_rating
QUOTE:-
Anti-Knock Index (AKI) or (R+M)/2
In most countries in Europe and also Australia and New Zealand, the "headline" octane rating shown on the pump is the RON, but in Canada, the United States, and Mexico, the headline number is the simple mean or average of the RON and the MON, called the Anti-Knock Index (AKI), and often written on pumps as (R+M)/2. AKI is also sometimes called PON (Pump Octane Number).
END QUOTE
The bottom number correctly read is 91 RON
QUOTE:-
Research Octane Number (RON)
The most common type of octane rating worldwide is the Research Octane Number (RON). RON is determined by running the fuel in a test engine with a variable compression ratio under controlled conditions, and comparing the results with those for mixtures of iso-octane and n-heptane.[7] The compression ratio is varied during the test to challenge the fuel's antiknocking tendency, as an increase in the compression ratio will increase the chances of knocking.
END QUOTE
Basically that sticker is saying the same basic minimum fuel type in two different standards...it is the same fuel!
My German built car (1.4lt engine) stated 91RON minimum....with 95RON stated above it as a normal fuel. Basically use 95RON all the time, but if you have to use 91RON you can do, but with reduced power etc.... Now in the UK we don't have 91RON, the lowest we get is 95RON (standard unleaded in UK), but 91RON is a cheap grade fuel which shows up in certain European countries, so the car is factory tuned for all the fuels.
I always used 98RON (Super unleaded Shell Vpower/Optimax) & had the car Revo stage 1-B tuned. The "B" representing the timing has been advanced for the car to run on 98RON all the time, but can run as an emergency on 95RON fuel...This is how the Golf "R" is tuned from factory....
Shell Vpower/Optimax is actually 99RON in UK which is 93AKI(R+M)/2 or 87MON....
