Eurodyne Updates
Warfe-Motorsports
2016 Audi A3 MQB
I may have went extreme on the changes trying to get results. I noticed it did spool better but after one pull i got a 4k rpm limiter and crank cam correlation code.
nicalibre
California
S3
Thanks Diggs, I will probably not play around with it for now (or get a tuner in the future to update those).
By the way, I see the BT maestro file have "Accelerator pedal" and "Timing correction for intake air temperature" maps available but not on regular stage 1 and 2 files. I sent an e-mail today to ED asking if he will add those soon.
ITGUY
PA
Does Eurodyne have a way of seeing the turbo shaft speed data if there is a sensor for one and it's pinned to the ECU? I did try to look it up but didn't find any information about this.
joedubs
Negative.
If you have an R/S3, then you could at least use opensource logging to see the ecus MODELED shaft speed. Which won't even be remotely accurate if you've switched turbos.
Haven't had a chance to see if we can wire one in or not.
marc5800
Ottawa
I looked at the cam timing tables and was a little overwhelmed so didn’t touch anything
marc5800
Ottawa
I’d suggest Railroader, he picked up 16whp by just the cam adjustments.
Yea I talked to him. The S3 tables are different than the A3 / GTI tables tho. We have 3 tables.
marc5800
Ottawa
Anyone look at the new Maestro tables added in 6.5.2?
(timing correction for IAT, accelerator pedal map, cam timing, injection correction, etc.)
arob157
I will update tonight. Been waiting on those pedal maps for A3/GTI. Excited to experiment with them.
marc5800
Ottawa
Ya seem pretty cool
Not sure where to start or what the impacts are.
Keep us posted!
