SugarMouth
- Nevada
BTW, I love that 11.7:1 is considered rich on pump gas with 28psi of boost
Thanks
-- Ed
He might have flip flopped the graph.
Thanks
-- Ed
oops. thats my bad. i was looking at the boost line. i thought you were in the single digit afr up top.
So a kit like this:
http://www.precisionraceworks.com/index.php?route=product/product&product_id=67
Shouldn't be any different on install than replacing a fuel pump/sender in most cars with in tank pumps? Looks easy enough anyway.
edit; read the how-to they have. A little more work than a direct swap, but still pretty simple. hmm.... If I'm in this far, why not go all the way? le sigh. I've gotta think about this.
Turbo is installed. Went with the actuator from my is20. It passed the test on vcds, but the voltage read 2.8. Anyone know if that’s okay, or if I should keep adjusting to get it to 3.6?
We went ahead and got it to 3.623.
Fully closed
Full fueling here I come, just ordered a PR 925cc mpi kit
Sent from my SM-G950U1 using Tapatalk
Keep the torque low in the mid range and you will be goodDamn....I'd order if I wasn't afraid of blowing up the motor
