@billbadass -- Thanks for chiming in. I watched the install saga unfold with your L380. My impression was that on pump gas, you weren't overly satisfied with it and felt that the torque was unexplainably low? On Ed's dyno, most IS20/IS38 turbos are in the 400-420 wtq range. I totally get the "wanting more" though...smarter up front to make a "future proof" decision. I like the Vortex (a lot) but LPFP + MPI seems to be "the way" now? Awhile back Ed said that to run the EQT, all you need (besides the turbo itself) was the HPFP upgrade (which to me seems a shit ton easier AND cheaper than the LPFP + MPI conversion).
$ per HP though the IS38 is still the clear winner (if your goal is 380-400 whp). If your goal is 500 whp, obviously the IS38 can't compete.
the is38 dynos you will see have this torque spike around 3k rpm that makes the torque look higher than it actually is. I'm not unhappy with this L380x turbo, but it has the slower response of an EQT turbo but it doesn't have the 550whp potential so if I was doing it again I'd just do an EQT. The L380x was maybe 15lbs of mid range lower on the torque than I expected also, but on the street I don't ever think it's lacking in torque and I drive it on E50 full time.
I think if you did just an EQT and just put HPFP only in it you would be super happy. you don't need to spin the EQT turbo to its max to be super happy with how the car is, and my own personal opinion is that an EQT turbo will be more reliable than an is38 anyway. I believe Ed has done plenty of EQT turbo installs that did not have MPI + LPFP so I think those are only necessary if you want to push big power or want stronger ethanol blends.
I personally have found over all my "built" cars that the less you can change and the more simple you can keep it the more reliable the car will be, so I personally just wanted to stick with HPFP only to keep it as simple and cheap and reliable as possible, and it's nice my car looks totally stock under the hood to the untrained eye if I put the stock intake on
on p4s michelin tires my car puts down 468whp easily on the street also and that is with an open differential. Ed's COBB traction control is amazing also. I don't think 3rd gear would hook up with too much more power but 468whp hooks up third great, and 1st/2nd COBB traction control keeps it very well controlled. I've actually been super surprised how smooth, controllable and easily this chassis took this power level and I'm on stock suspension
