DIY MIB1 to MIB2 Infotainment Conversion (Part 1)
madwazzabi
Toronto, Canada
2015 GTI Atbhn PP
Been reading through this monster thread and wanted to say thanks for posting this (among others in here with incredible advice), I know it was a while ago but it helped me with looking for parts. I also have a 2015 Canadian Autobahn but no fender audio, just whatever the default sound system was. How do I know what amplifier I have (if at all) to make sure the MIB unit is compatible? Is the 3G0 035 047 your recommendation for our region? I've also seen 3Q0 035 876B as another option as well. Thanks in advance.
Just to add, you mentioned you managed to maintain an accessory mode and forgive me if I'm reading it wrong, but what part of your troubleshooting helped you solve it?
If its a Canadian 2015 Golf GTI Autobahn, it's supposed to have fender sound package. That year I recall you only had two adder options, the PP and the comfort package (leather seats) and regardless of what options you choose it should have fender as standard.
Regardless, if you do not have the Fender sound system for whatever reason, the sound output would have been analog direct from the head unit from the A multipin connector in lieu of the Fender Amp located under the Driver's seat.
If you want as close to OEM and region correct for MIB2 Discover Pro then 3G0 035 047 is your only choice. MIB2.5 Discover Pro gives you one more part number (5NA035026#) but it is just as scarce and it will not work with the screen you just picked up. If you can live without the benefits of Discover Pro (faster processor, AID map on both center console and cluster, internal storage) you can look for a discover media headunit (3G0 035 8##) or if you don't care for Sirius XM radio for satellite radio or traffic then you can go for any 3G0 035 0## ROW discover pro headunit both of which will work with the screen you just picked up.
EDIT: I forgot to answer the last point, there is no true accessory mode. MIB2/2.5 does give you continued radio/bluetooth after ignition is shut off until the driver's side door is opened. But if you want to run the radio when you first get in the car you either have to push the radio power button and remember to shut it off before you leave (which leaves your radio off on next start) or run your car stalled and shut off your AC and headlights so you don't kill your battery just to listen to some tunes. -_-"
aegis
Ontario
MK7 GTI
Thanks for the detailed response. That's odd, I confirmed with the dealership using my VIN that it's an Autobahn package for 2015, but none of the pillars or doors have the fender badge. Is this normal? I'll check under the seat but is there any other way to know? My current MIB splash screen doesn't show the Fender logo either.
Will a 3G0 035 047 or 5NA work with the screen I just picked up, or if I want to use it are my only options an 8## or the ROW model you noted. Sorry I just re-read what you wrote, 3G0 035 047 seems to be what I should aim for.
I will double check this tonight, I can't remember if my calls and radio cut off when I turn the car off, but now that you mention it I know they do when I open the door. Maybe I didn't test for long enough. I always ran into this problem when I went to the drive-in theatre. I don't use the ignition at all, I just press the power button on the radio. I'll give it a test again after work, it's been a while since I've been. Thanks again for answering these questions, I'm sure I'll have more when I get into the thick of it.
EDIT; Yeah my radio and calls cut right when I turn off the car. However when the car is off I press the power button on the radio and it plays until I press power again. It even stays on when I open the door.
Cuzoe
Is that a thing now? Bluetooth microphone staying on after ignition is off? I've had that "issue" for the life of my car... MIB I (I think, that was years ago, haha), MIB II without, MIB II with nav, and still with MIB 2.5.
In my non-Kessy car it's trivial to turn the ignition back on if I want to stay on the phone. The radio doesn't turn off when I turn off the engine. It will stay on as long as the key is in the cylinder, even if the door is open. Phone stays paired so Bluetooth (and any other) audio still good whether it's music playing or being able to hear the person on the phone. It's only the microphone that turns off after a short bit.
MIB II can use the 6.5" or 8" (matte or glass) display. Resolution is the same for either size. By default only MIB 2.5 can use the 9.2" glass display.
MIB II can be modified to use the 9.2" screen. But you'll have to find someone with expertise in that area.
aegis
Ontario
MK7 GTI
Thanks for the response Cuzoe, I saw some comments swirling around about this and I couldn't recall how my MIB1 behaved. Calls and radio cut out as soon as I cut the engine, but as you mentioned turning the ignition back on is simple and brings back all the functions. When I'm at the drive-in I don't even use the ignition, just press power on the stereo and it can play the movie sound through the radio, however Bluetooth calls and audio won't turn on without the ignition. Figured I would ask in case there was a newer MIB unit out there that could enhance these items.
Cuzoe
Gotcha... I don't think anything has changed. On a call when I shut off the engine I can still hear the other person, they just can't hear me after a short time.
The "logic" problem is that the MIB doesn't provide power to anything. Without looking at the schematic I have to assume the mic is on accessory power. It could be re-wired to be on battery power but then it would be on all the time. Probably drawing next to no power and would take exceedingly long time to drain your battery, but no ideal.
Of course now I'm thinking, why leave well enough alone? I'm running an aftermarket amp that has 12 volt remote turn on. If I remember the spec sheet correctly it's 0.5A max. I could put a clamp meter on the power to the mic and see if it even pulls 0.5A...
If it doesn't I could wire directly from the remote turn on. If it does take more than 0.5A amps, which would be surprising, I can still use the remote turn on to trigger a relay that provides 12 volt battery power to the mic.
The short of it is... I'm going to make the modifications required for my mic to work anytime the radio is on... ignition or no ignition 🤣.
Wilkius
BC, Canada
2015 Golf TDI
What have people done when their VAS5054 device beeps like crazy and isn't recognized by the ODIS software? My device appears to have the drivers working over Bluetooth but the device just keeps beeping and is not recognized by ODIS.
Wilkius
BC, Canada
2015 Golf TDI
clone that beeps when connected via bluetooth. on usb it doesn't seem to find the drivers.
Sorted by using the Virtual Machine!
MIB2 Retrofit is essentially complete - except the ambient lighting option has no content in it. I can go into the ambient lighting menu, but it's blank, save for a "select your area" sort of text when my hand waves over the screen. Any thoughts on this one? Donor unit was a 2016 Golf R into my 2015 TDI "Highline".
Cuzoe
That's going to be an issue with adaptations. Does your car have any ambient lighting?
If you have an adaptation map of your old unit to compare to the new one that's the easiest way to sort this.
Wilkius
BC, Canada
2015 Golf TDI
The car does have ambient lighting, yes. We copied the adaptations over from the old MIB to the MIB2 - all the menus are as they were with the old car but the images of the vehicle are different (areas like when the hood is open doesn't show a glow around the hood and it's a black car for the first time). Under the Ambient Lighting Menu, it is just blank with the option to select an area, but there are no items or images to select from. Confused.
Cuzoe
@Wilkius what ambient lighting does it have? I assume door strips? And footwell lighting?
The adaptations will not copy over directly but post up an adaptation map...
Code:
Copy the CSV files into code tags like this, otherwise it will be an exceedingly long post.
It might be one only had sliders to adjust ambient lighting. You may have just had one that said ambient lights or possibly you had a slider for ambient lights at a separate one for footwells. In any case, on MIB2 the ambient light menu is capable of showing a picture of the car interior, with graphics for whichever lights your car has. I think you can also do sliders but I'm not positive on that.
The graphic representation looks better anyway, imo. Something like this, but it can be coded to only show the lights you have, and it won't show that color slider since your lights will be white only...
As far as the car image being incorrect, that sounds like something in the first few bytes of long coding is wrong. Those bytes determine the vehicle type.
Wilkius
BC, Canada
2015 Golf TDI
I have door strips (I think near the handles as well) and footwell lighting. If I recall correctly, it was not a graphic of those but just the sliders (separate sliders for door and footwell). Would love the graphic photo of the car but that's a nice to have. Is it the 5f or the 09 adaptations you'd need? @Cuzoe
Edit - looking at your post about your BCM, we have the same part number 5Q0-937-087-S (and I suspect, car - top end 2015 TDI)
Wilkius
BC, Canada
2015 Golf TDI
@Wilkius correct, 5F and 09 should do it.
Here goes...
Code:
;SW:3G0-035-047-E   HW:3G0-035-047 ---  Information Electr.
;Component:MU-H-NS-US    H42 0344     Coding:027300020000000051220002001828001F0100F401200105DE
;EV_MUHig4CGen2HBAS    1001    EV_MUHig4CGen2HBAS_VW37.rod
;Saturday    30    July
;VCDS Version: Release 22.3.1 (x64)  Data version: 20220407 DS337.0
IDE00001-Production mode    00 00 00     3
IDE00346-Summertime-automatic    USA     1
IDE00759-Base volume of speech output    50%    1
IDE00760-Microphone sensitivity    0 dB    1
IDE00768-Country identification: country of sale    --     2
IDE00769-Call number 1 for info call    FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF     23
IDE00770-Number 1 for roadside assistance    FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF     23
IDE00820-ENG117828-Activating and deactivating all development messages-Infotainment_CAN_Messages    OFF     1
IDE00820-ENG117829-Activating and deactivating all development messages-MIB_CAN_Messages    OFF     1
IDE00845-Wheel circumference    0 mm    2
IDE01996-MAS00076-Installation list: specified installations-Instrument cluster control module    No     3
IDE01996-MAS00839-Installation list: specified installations-TV Tuner    No     3
IDE01996-MAS00844-Installation list: specified installations-Radio    No     3
IDE01996-MAS00847-Installation list: specified installations-Digital Sound System Control Module    Yes     3
IDE01996-MAS00849-Installation list: specified installations-Information electronics control module 1    Yes     3
IDE01996-MAS00850-Installation list: specified installations-Information electronics control module 2    No     3
IDE01996-MAS04300-Installation list: specified installations-DVD changer    No     3
IDE01996-MAS14306-Installation list: specified installations-Windshield projection head up display control module    No     3
IDE01996-SFT271943-Installation list: specified installations-Multimedia system control head    No     3
IDE01996-ENG154341-Installation list: specified installations-Reserved_8    No     3
IDE01996-ENG152491-Installation list: specified installations-Smart Control Carrier 1    No     3
IDE01996-ENG152490-Installation list: specified installations-Smart Control Carrier 2    No     3
IDE01996-ENG152488-Installation list: specified installations-Smart Display Carrier 1    No     3
IDE01996-ENG152492-Installation list: specified installations-Smart Display Carrier 2    No     3
IDE01996-ENG152493-Installation list: specified installations-Wireless Charger 1    No     3
IDE01996-ENG152489-Installation list: specified installations-Wireless Charger 2    No     3
IDE02121-CD eject button    Enabled     1
IDE02122-Developer mode    activated     1
IDE02330-Call number 2 for info call    FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF     23
IDE02331-Number 2 for roadside assistance    FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF     23
IDE02332-Deactivate production mode    0    3
IDE02476-MAS03001-Electrical test of speakers-Mode    automatic     49
IDE02476-ENG117360-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_1_Test_Frequency    19000 Hz    49
IDE02476-ENG117361-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_1_Test_Volume    22    49
IDE02476-ENG117378-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_10_Test_Frequency    19000 Hz    49
IDE02476-ENG117379-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_10_Test_Volume    22    49
IDE02476-ENG117380-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_11_Test_Frequency    19000 Hz    49
IDE02476-ENG117381-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_11_Test_Volume    22    49
IDE02476-ENG117382-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_12_Test_Frequency    19000 Hz    49
IDE02476-ENG117383-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_12_Test_Volume    22    49
IDE02476-ENG117384-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_13_Test_Frequency    19000 Hz    49
IDE02476-ENG117385-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_13_Test_Volume    22    49
IDE02476-ENG117386-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_14_Test_Frequency    19000 Hz    49
IDE02476-ENG117387-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_14_Test_Volume    22    49
IDE02476-ENG117388-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_15_Test_Frequency    19000 Hz    49
IDE02476-ENG117389-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_15_Test_Volume    22    49
IDE02476-ENG117390-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_16_Test_Frequency    19000 Hz    49
IDE02476-ENG117391-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_16_Test_Volume    22    49
IDE02476-ENG117362-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_2_Test_Frequency    19000 Hz    49
IDE02476-ENG117363-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_2_Test_Volume    22    49
IDE02476-ENG117364-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_3_Test_Frequency    19000 Hz    49
IDE02476-ENG117365-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_3_Test_Volume    22    49
IDE02476-ENG117366-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_4_Test_Frequency    19000 Hz    49
IDE02476-ENG117367-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_4_Test_Volume    22    49
IDE02476-ENG117368-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_5_Test_Frequency    19000 Hz    49
IDE02476-ENG117369-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_5_Test_Volume    22    49
IDE02476-ENG117370-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_6_Test_Frequency    19000 Hz    49
IDE02476-ENG117371-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_6_Test_Volume    22    49
IDE02476-ENG117372-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_7_Test_Frequency    19000 Hz    49
IDE02476-ENG117373-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_7_Test_Volume    22    49
IDE02476-ENG117374-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_8_Test_Frequency    19000 Hz    49
IDE02476-ENG117375-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_8_Test_Volume    22    49
IDE02476-ENG117376-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_9_Test_Frequency    19000 Hz    49
IDE02476-ENG117377-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_9_Test_Volume    22    49
IDE02502-Confirmation of installation change    76 2D     2
IDE02506-MAS03229-Copy multimedia data-Data carrier    On     1
IDE02506-MAS03230-Copy multimedia data-Optical drive    On     1
IDE02607-Wheel pulse    0    2
IDE02699-Number 1 for roadside assistance    FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF     23
IDE02701-Number 1 (roaming) for roadside assistance    FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF     23
IDE03471-ENG117847-Vehicle configuration-advanced_range_display    OFF     30
IDE03471-ENG249824-Vehicle configuration-AliBox    OFF     30
IDE03471-ENG142146-Vehicle configuration-allow_message_editing    OFF     30
IDE03471-ENG130249-Vehicle configuration-Apple_DIO    On     30
IDE03471-ENG185764-Vehicle configuration-Apple_DIO_Wireless    OFF     30
IDE03471-ENG152525-Vehicle configuration-Baidu_Car_Life    OFF     30
IDE03471-ENG152559-Vehicle configuration-Baidu_Car_Life_ios    OFF     30
IDE03471-ENG185765-Vehicle configuration-Baidu_Car_Life_ios_Wireless    OFF     30
IDE03471-ENG185766-Vehicle configuration-Baidu_Car_Life_Wireless    OFF     30
IDE03471-ENG152560-Vehicle configuration-block_hmi_function_p_epb    locked     30
IDE03471-ENG142151-Vehicle configuration-conditioning_variant    0    30
IDE03471-ENG263540-Vehicle configuration-correction_e_mileage    0    30
IDE03471-ENG125043-Vehicle configuration-Dtmf_without_active_call    On     30
IDE03471-ENG142145-Vehicle configuration-esim_data_only_sms_support    OFF     30
IDE03471-ENG185778-Vehicle configuration-FoD    SWaP     30
IDE03471-ENG130248-Vehicle configuration-Google_GAL    On     30
IDE03471-ENG185779-Vehicle configuration-Google_GAL_Wireless    OFF     30
IDE03471-ENG117850-Vehicle configuration-gracenote_local_coverarts    On     30
IDE03471-ENG117851-Vehicle configuration-gracenote_local_other    On     30
IDE03471-ENG117848-Vehicle configuration-gracenote_online_coverarts    OFF     30
IDE03471-ENG117849-Vehicle configuration-gracenote_online_other    OFF     30
IDE03471-ENG152533-Vehicle configuration-Hybrid_Radio_additional_online_data    not activated     30
IDE03471-ENG152534-Vehicle configuration-Hybrid_Radio_Range_Extender    Deactivated     30
IDE03471-ENG261211-Vehicle configuration-internet_over_WLAN_default_setting    OFF     30
IDE03471-ENG125049-Vehicle configuration-Joker_button_1    not installed     30
IDE03471-ENG125050-Vehicle configuration-Joker_button_2    not installed     30
IDE03471-ENG127492-Vehicle configuration-LGI    OFF     30
IDE03471-ENG130246-Vehicle configuration-LTE_modul    Deactivated     30
IDE03471-ENG142142-Vehicle configuration-map_email_support    OFF     30
IDE03471-ENG142143-Vehicle configuration-map_instant_messaging_support    OFF     30
IDE03471-ENG142141-Vehicle configuration-map_sms_support    OFF     30
IDE03471-ENG142152-Vehicle configuration-Map_Style    0    30
IDE03471-ENG152537-Vehicle configuration-media_control    not activated     30
IDE03471-ENG138662-Vehicle configuration-Mirror_link    On     30
IDE03471-ENG142148-Vehicle configuration-MirrorLink_Country_Code    MIB_EU     30
IDE03471-ENG142150-Vehicle configuration-MirrorLink_RGB_Preference    RGB565     30
IDE03471-ENG117843-Vehicle configuration-my_audi    OFF     30
IDE03471-ENG117845-Vehicle configuration-online_dictation    OFF     30
IDE03471-ENG127495-Vehicle configuration-online_media    OFF     30
IDE03471-ENG117840-Vehicle configuration-online_navigation    OFF     30
IDE03471-ENG117837-Vehicle configuration-online_POI    OFF     30
IDE03471-ENG117838-Vehicle configuration-online_POI_voice    OFF     30
IDE03471-ENG117839-Vehicle configuration-online_portal_browser_services    OFF     30
IDE03471-ENG152553-Vehicle configuration-online_radio    Deactivated     30
IDE03471-ENG117841-Vehicle configuration-online_street_view    OFF     30
IDE03471-ENG125048-Vehicle configuration-OPS_display_in_dash_board_display_unit    OFF     30
IDE03471-ENG167521-Vehicle configuration-perso_v_threshold    0    30
IDE03471-ENG167522-Vehicle configuration-perso_v_threshold_hysteresis    0    30
IDE03471-ENG152554-Vehicle configuration-Phone_HMI_Privacy    0    30
IDE03471-ENG125046-Vehicle configuration-Phone_module_operation_mode    only data service act.     30
IDE03471-ENG117844-Vehicle configuration-picture_navi    On     30
IDE03471-ENG167523-Vehicle configuration-Pilot_Parking    not activated     30
IDE03471-ENG167525-Vehicle configuration-Popup_if_GPS_services_in_use    not activated     30
IDE03471-ENG152555-Vehicle configuration-Privacy_WithPINRequest    0    30
IDE03471-ENG127496-Vehicle configuration-ProbeCar_lgi    OFF     30
IDE03471-ENG137646-Vehicle configuration-ProbeCar_vzo    OFF     30
IDE03471-ENG125047-Vehicle configuration-PSD_Protocol_Version    PSD_1.5     30
IDE03471-ENG117846-Vehicle configuration-remote_HMI    OFF     30
IDE03471-ENG138661-Vehicle configuration-RSE_software_component    activated     30
IDE03471-ENG245031-Vehicle configuration-rvc_low_black_screen_trunk_open    not activated     30
IDE03471-ENG244966-Vehicle configuration-rvc_low_black_screen_velocity_threshold    not activated     30
IDE03471-ENG245015-Vehicle configuration-rvc_low_failsafe    not activated     30
IDE03471-ENG126143-Vehicle configuration-RVC_video_input    FBAS     30
IDE03471-ENG152556-Vehicle configuration-scon_telephony    not activated     30
IDE03471-ENG142081-Vehicle configuration-sd_slot_deactivation    no restriction     30
IDE03471-ENG138660-Vehicle configuration-SDS_Region_Flag    no_region     30
IDE03471-ENG152557-Vehicle configuration-show_volte_hmi_switch    not activated     30
IDE03471-ENG125045-Vehicle configuration-Sim_card_mode_switch    not installed     30
IDE03471-ENG142144-Vehicle configuration-sim_data_only_sms_support    OFF     30
IDE03471-ENG138663-Vehicle configuration-Smartphone_interface_for_rhmi    activated     30
IDE03471-ENG126993-Vehicle configuration-Station_Logo_DB_Mode    0    30
IDE03471-ENG125044-Vehicle configuration-Support_for_response_and_hold    OFF     30
IDE03471-ENG125042-Vehicle configuration-Support_of_threeway_calling    On     30
IDE03471-ENG130247-Vehicle configuration-Support_second_phone    On     30
IDE03471-ENG167531-Vehicle configuration-Tencent_myCar_canceling_share_location    OFF     30
IDE03471-ENG126994-Vehicle configuration-TPEG_availability    OFF     30
IDE03471-ENG152571-Vehicle configuration-unblock_functions_while_piloted_driving    locked     30
IDE03471-ENG137647-Vehicle configuration-UOTA    OFF     30
IDE03471-ENG167532-Vehicle configuration-UOTA_2    OFF     30
IDE03471-ENG117852-Vehicle configuration-UPnP    On     30
IDE03471-ENG142149-Vehicle configuration-vehicle_leaving_sound    not activated     30
IDE03471-ENG142147-Vehicle configuration-vehicle_readiness_sound    not activated     30
IDE03471-ENG152558-Vehicle configuration-voice_over_lte    not activated     30
IDE03471-ENG117836-Vehicle configuration-VZAPro    OFF     30
IDE03471-ENG127494-Vehicle configuration-VZO    OFF     30
IDE03471-ENG137648-Vehicle configuration-WiFi_Client_HMI    OFF     30
IDE03471-ENG117842-Vehicle configuration-WIFI_Hotspot    On     30
IDE03471-ENG152572-Vehicle configuration-wlan_5ghz_switch    not activated     30
IDE03902-Automatic ring break diagnostic    No automatic start     1
IDE04295-Bluetooth: Preferred connection profile for phone book data    PBAP     1
IDE04298-MAS01779-Vehicle dimensions-Length    0 mm    6
IDE04298-MAS01780-Vehicle dimensions-Width    0 mm    6
IDE04298-MAS02230-Vehicle dimensions-Height    0 mm    6
IDE04331-Selection of release codes for a SWaP function    FF FF FF FF     4
IDE04484-ENG117426-Regional codes-Parameter_Set_BlueRay_System_Region_Code    1    2
IDE04484-ENG117425-Regional codes-Parameter_Set_DVD_Region_Code    1    2
IDE04521-Sporadic ring break detection    optical     1
IDE04522-Awakening ability on optical databus    OFF     1
IDE04550-Bluetooth: Sniff mode    OFF     1
IDE05111-Fee-based traffic information (TMC)    1537    2
IDE05113-Infotainment Recorder    activated     1
IDE06425-Dynamometer mode: functional-    not activated     1
IDE06425-ENG98891-Dynamometer mode: functional-Reserved    0    1
IDE06697-Audio management mute function    Muting of audio sources     1
IDE10221-MAS00839-Audio Management Input Gain Generation 2-TV Tuner    -128    40
IDE10221-MAS00846-Audio Management Input Gain Generation 2-Satellite radio    5    40
IDE10221-MAS01984-Audio Management Input Gain Generation 2-Radio (FM)    -128    40
IDE10221-MAS01985-Audio Management Input Gain Generation 2-Radio (AM)    -128    40
IDE10221-MAS01986-Audio Management Input Gain Generation 2-Digital radio (DAB)    -128    40
IDE10221-ENG125854-Audio Management Input Gain Generation 2-Exbox_DMB    -128    40
IDE10221-ENG117430-Audio Management Input Gain Generation 2-HFP    -128    40
IDE10221-ENG125846-Audio Management Input Gain Generation 2-Media_Airplay    -128    40
IDE10221-ENG125837-Audio Management Input Gain Generation 2-Media_AUX_Adapter    -128    40
IDE10221-ENG125836-Audio Management Input Gain Generation 2-Media_AUXIN    -128    40
IDE10221-ENG125843-Audio Management Input Gain Generation 2-Media_Bluray    -128    40
IDE10221-ENG125841-Audio Management Input Gain Generation 2-Media_BTDevice    -128    40
IDE10221-ENG125838-Audio Management Input Gain Generation 2-Media_CDA    -128    40
IDE10221-ENG125848-Audio Management Input Gain Generation 2-Media_Cloud    -128    40
IDE10221-ENG125839-Audio Management Input Gain Generation 2-Media_DVD    -128    40
IDE10221-ENG125844-Audio Management Input Gain Generation 2-Media_HDMI    -128    40
IDE10221-ENG125840-Audio Management Input Gain Generation 2-Media_MFP    -128    40
IDE10221-ENG125847-Audio Management Input Gain Generation 2-Media_UPNP    -128    40
IDE10221-ENG125855-Audio Management Input Gain Generation 2-Mirrorlink    -128    40
IDE10221-ENG125859-Audio Management Input Gain Generation 2-Phone_Ringer_MFP    -128    40
IDE10221-ENG125860-Audio Management Input Gain Generation 2-Phone_Ringer_OB    -3    40
IDE10221-ENG125858-Audio Management Input Gain Generation 2-Phone_Voice    -128    40
IDE10221-ENG125842-Audio Management Input Gain Generation 2-TA_Tuner_FM    -128    40
IDE10221-ENG125850-Audio Management Input Gain Generation 2-Tone_Beep    -128    40
IDE10221-ENG125853-Audio Management Input Gain Generation 2-Tone_Messaging    -128    40
IDE10221-ENG125852-Audio Management Input Gain Generation 2-Tone_Touchscreen    -128    40
IDE10221-ENG125851-Audio Management Input Gain Generation 2-Tone_Warning    -128    40
IDE10221-ENG125856-Audio Management Input Gain Generation 2-TTS_Nav    -128    40
IDE10221-ENG125857-Audio Management Input Gain Generation 2-TTS_SDS    -128    40
IDE10221-ENG125845-Audio Management Input Gain Generation 2-Tuner_Online    -128    40
IDE10221-ENG125849-Audio Management Input Gain Generation 2-Tuner_Personal    -128    40
IDE10221-ENG125835-Audio Management Input Gain Generation 2-Tuner_TI    -128    40
IDE10221-ENG125861-Audio Management Input Gain Generation 2-TV_AV_IN    -128    40
IDE10480-MAS10741-Interface for external media: activation-Connection 1    activated     4
IDE10480-MAS10742-Interface for external media: activation-Connection 2    not activated     4
IDE10480-MAS10743-Interface for external media: activation-Connection 3    not activated     4
IDE10480-MAS10744-Interface for external media: activation-Connection 4    not activated     4
IDE10604-Menu entries for mobile online services    not activated     1
IDE11104-ENG127502-FM tuner: mono/stereo setting-l_hf_stereo_lower_threshold    37 dBµV    3
IDE11104-ENG127503-FM tuner: mono/stereo setting-l_nf_max_stereo_channel_separation    32 dB    3
IDE11104-ENG127504-FM tuner: mono/stereo setting-t_hysteresis_mono_to_stereo    15.0 s    3
IDE11105-Brand-specific display of connect application         256
IDE11122-Country identification: country of sale HMI    CA     2
IDE11153-ENG152487-Surroundings display: virtual camera positions-focallength    4294967295    330
IDE11153-ENG152457-Surroundings display: virtual camera positions-Pitchangle    65535    330
IDE11153-ENG152445-Surroundings display: virtual camera positions-Rollangle    65535    330
IDE11153-ENG147432-Surroundings display: virtual camera positions-xpos    32767    330
IDE11153-ENG152451-Surroundings display: virtual camera positions-Yawangle    65535    330
IDE11153-ENG147433-Surroundings display: virtual camera positions-ypos    32767    330
IDE11153-ENG147434-Surroundings display: virtual camera positions-zpos    32767    330
IDE11502-ENG127601-Locked menu contents-FB_CAR_0    non_blocked     21
IDE11502-ENG127602-Locked menu contents-FB_CAR_1    non_blocked     21
IDE11502-ENG127611-Locked menu contents-FB_CAR_10    non_blocked     21
IDE11502-ENG127612-Locked menu contents-FB_CAR_11    non_blocked     21
IDE11502-ENG127613-Locked menu contents-FB_CAR_12    non_blocked     21
IDE11502-ENG127614-Locked menu contents-FB_CAR_13    non_blocked     21
IDE11502-ENG127615-Locked menu contents-FB_CAR_14    non_blocked     21
IDE11502-ENG127616-Locked menu contents-FB_CAR_15    non_blocked     21
IDE11502-ENG127617-Locked menu contents-FB_CAR_16    non_blocked     21
IDE11502-ENG127618-Locked menu contents-FB_CAR_17    non_blocked     21
IDE11502-ENG127619-Locked menu contents-FB_CAR_18    non_blocked     21
IDE11502-ENG127620-Locked menu contents-FB_CAR_19    non_blocked     21
IDE11502-ENG127603-Locked menu contents-FB_CAR_2    non_blocked     21
IDE11502-ENG127621-Locked menu contents-FB_CAR_20    non_blocked     21
IDE11502-ENG127622-Locked menu contents-FB_CAR_21    non_blocked     21
IDE11502-ENG127623-Locked menu contents-FB_CAR_22    non_blocked     21
IDE11502-ENG127624-Locked menu contents-FB_CAR_23    non_blocked     21
IDE11502-ENG127604-Locked menu contents-FB_CAR_3    non_blocked     21
IDE11502-ENG127605-Locked menu contents-FB_CAR_4    non_blocked     21
IDE11502-ENG127606-Locked menu contents-FB_CAR_5    non_blocked     21
IDE11502-ENG127607-Locked menu contents-FB_CAR_6    non_blocked     21
IDE11502-ENG127608-Locked menu contents-FB_CAR_7    non_blocked     21
IDE11502-ENG127609-Locked menu contents-FB_CAR_8    non_blocked     21
IDE11502-ENG127610-Locked menu contents-FB_CAR_9    non_blocked     21
IDE11502-ENG127521-Locked menu contents-FB_MEDIA_0    non_blocked     21
IDE11502-ENG127522-Locked menu contents-FB_MEDIA_1    non_blocked     21
IDE11502-ENG127531-Locked menu contents-FB_MEDIA_10    non_blocked     21
IDE11502-ENG127532-Locked menu contents-FB_MEDIA_11    non_blocked     21
IDE11502-ENG127533-Locked menu contents-FB_MEDIA_12    non_blocked     21
IDE11502-ENG127534-Locked menu contents-FB_MEDIA_13    non_blocked     21
IDE11502-ENG127535-Locked menu contents-FB_MEDIA_14    non_blocked     21
IDE11502-ENG127536-Locked menu contents-FB_MEDIA_15    non_blocked     21
IDE11502-ENG127537-Locked menu contents-FB_MEDIA_16    non_blocked     21
IDE11502-ENG127538-Locked menu contents-FB_MEDIA_17    non_blocked     21
IDE11502-ENG127539-Locked menu contents-FB_MEDIA_18    non_blocked     21
IDE11502-ENG127540-Locked menu contents-FB_MEDIA_19    non_blocked     21
IDE11502-ENG127523-Locked menu contents-FB_MEDIA_2    non_blocked     21
IDE11502-ENG127541-Locked menu contents-FB_MEDIA_20    non_blocked     21
IDE11502-ENG127542-Locked menu contents-FB_MEDIA_21    non_blocked     21
IDE11502-ENG127543-Locked menu contents-FB_MEDIA_22    non_blocked     21
IDE11502-ENG127544-Locked menu contents-FB_MEDIA_23    non_blocked     21
IDE11502-ENG127524-Locked menu contents-FB_MEDIA_3    non_blocked     21
IDE11502-ENG127525-Locked menu contents-FB_MEDIA_4    non_blocked     21
IDE11502-ENG127526-Locked menu contents-FB_MEDIA_5    non_blocked     21
IDE11502-ENG127527-Locked menu contents-FB_MEDIA_6    non_blocked     21
IDE11502-ENG127528-Locked menu contents-FB_MEDIA_7    non_blocked     21
IDE11502-ENG127529-Locked menu contents-FB_MEDIA_8    non_blocked     21
IDE11502-ENG127530-Locked menu contents-FB_MEDIA_9    non_blocked     21
IDE11502-ENG127625-Locked menu contents-FB_MISC_0    non_blocked     21
IDE11502-ENG127626-Locked menu contents-FB_MISC_1    non_blocked     21
IDE11502-ENG127635-Locked menu contents-FB_MISC_10    non_blocked     21
IDE11502-ENG127636-Locked menu contents-FB_MISC_11    non_blocked     21
IDE11502-ENG127637-Locked menu contents-FB_MISC_12    non_blocked     21
IDE11502-ENG127638-Locked menu contents-FB_MISC_13    non_blocked     21
IDE11502-ENG127639-Locked menu contents-FB_MISC_14    non_blocked     21
IDE11502-ENG127640-Locked menu contents-FB_MISC_15    non_blocked     21
IDE11502-ENG127641-Locked menu contents-FB_MISC_16    non_blocked     21
IDE11502-ENG127642-Locked menu contents-FB_MISC_17    non_blocked     21
IDE11502-ENG127643-Locked menu contents-FB_MISC_18    non_blocked     21
IDE11502-ENG127644-Locked menu contents-FB_MISC_19    non_blocked     21
IDE11502-ENG127627-Locked menu contents-FB_MISC_2    non_blocked     21
IDE11502-ENG127645-Locked menu contents-FB_MISC_20    non_blocked     21
IDE11502-ENG127646-Locked menu contents-FB_MISC_21    non_blocked     21
IDE11502-ENG127647-Locked menu contents-FB_MISC_22    non_blocked     21
IDE11502-ENG127648-Locked menu contents-FB_MISC_23    non_blocked     21
IDE11502-ENG127649-Locked menu contents-FB_MISC_24    non_blocked     21
IDE11502-ENG127650-Locked menu contents-FB_MISC_25    non_blocked     21
IDE11502-ENG127651-Locked menu contents-FB_MISC_26    non_blocked     21
IDE11502-ENG127652-Locked menu contents-FB_MISC_27    non_blocked     21
IDE11502-ENG127653-Locked menu contents-FB_MISC_28    non_blocked     21
IDE11502-ENG127654-Locked menu contents-FB_MISC_29    non_blocked     21
IDE11502-ENG127628-Locked menu contents-FB_MISC_3    non_blocked     21
IDE11502-ENG127655-Locked menu contents-FB_MISC_30    non_blocked     21
IDE11502-ENG127656-Locked menu contents-FB_MISC_31    non_blocked     21
IDE11502-ENG127657-Locked menu contents-FB_MISC_32    non_blocked     21
IDE11502-ENG127658-Locked menu contents-FB_MISC_33    non_blocked     21
IDE11502-ENG127659-Locked menu contents-FB_MISC_34    non_blocked     21
IDE11502-ENG127660-Locked menu contents-FB_MISC_35    non_blocked     21
IDE11502-ENG127661-Locked menu contents-FB_MISC_36    non_blocked     21
IDE11502-ENG127662-Locked menu contents-FB_MISC_37    non_blocked     21
IDE11502-ENG127663-Locked menu contents-FB_MISC_38    non_blocked     21
IDE11502-ENG127664-Locked menu contents-FB_MISC_39    non_blocked     21
IDE11502-ENG127629-Locked menu contents-FB_MISC_4    non_blocked     21
IDE11502-ENG127665-Locked menu contents-FB_MISC_40    non_blocked     21
IDE11502-ENG127666-Locked menu contents-FB_MISC_41    non_blocked     21
IDE11502-ENG127667-Locked menu contents-FB_MISC_42    non_blocked     21
IDE11502-ENG127668-Locked menu contents-FB_MISC_43    non_blocked     21
IDE11502-ENG127669-Locked menu contents-FB_MISC_44    non_blocked     21
IDE11502-ENG127670-Locked menu contents-FB_MISC_45    non_blocked     21
IDE11502-ENG127671-Locked menu contents-FB_MISC_46    non_blocked     21
IDE11502-ENG127672-Locked menu contents-FB_MISC_47    non_blocked     21
IDE11502-ENG127630-Locked menu contents-FB_MISC_5    non_blocked     21
IDE11502-ENG127631-Locked menu contents-FB_MISC_6    non_blocked     21
IDE11502-ENG127632-Locked menu contents-FB_MISC_7    non_blocked     21
IDE11502-ENG127633-Locked menu contents-FB_MISC_8    non_blocked     21
IDE11502-ENG127634-Locked menu contents-FB_MISC_9    non_blocked     21
IDE11502-ENG127561-Locked menu contents-FB_NAV_0    non_blocked     21
IDE11502-ENG127562-Locked menu contents-FB_NAV_1    non_blocked     21
IDE11502-ENG127571-Locked menu contents-FB_NAV_10    non_blocked     21
IDE11502-ENG127572-Locked menu contents-FB_NAV_11    non_blocked     21
IDE11502-ENG127573-Locked menu contents-FB_NAV_12    non_blocked     21
IDE11502-ENG127574-Locked menu contents-FB_NAV_13    non_blocked     21
IDE11502-ENG127575-Locked menu contents-FB_NAV_14    non_blocked     21
IDE11502-ENG127576-Locked menu contents-FB_NAV_15    non_blocked     21
IDE11502-ENG127577-Locked menu contents-FB_NAV_16    non_blocked     21
IDE11502-ENG127578-Locked menu contents-FB_NAV_17    non_blocked     21
IDE11502-ENG127579-Locked menu contents-FB_NAV_18    non_blocked     21
IDE11502-ENG127580-Locked menu contents-FB_NAV_19    non_blocked     21
IDE11502-ENG127563-Locked menu contents-FB_NAV_2    non_blocked     21
IDE11502-ENG127581-Locked menu contents-FB_NAV_20    non_blocked     21
IDE11502-ENG127582-Locked menu contents-FB_NAV_21    non_blocked     21
IDE11502-ENG127583-Locked menu contents-FB_NAV_22    non_blocked     21
IDE11502-ENG127584-Locked menu contents-FB_NAV_23    non_blocked     21
IDE11502-ENG127585-Locked menu contents-FB_NAV_24    non_blocked     21
IDE11502-ENG127586-Locked menu contents-FB_NAV_25    non_blocked     21
IDE11502-ENG127587-Locked menu contents-FB_NAV_26    non_blocked     21
IDE11502-ENG127588-Locked menu contents-FB_NAV_27    non_blocked     21
IDE11502-ENG127589-Locked menu contents-FB_NAV_28    non_blocked     21
IDE11502-ENG127590-Locked menu contents-FB_NAV_29    non_blocked     21
IDE11502-ENG127564-Locked menu contents-FB_NAV_3    non_blocked     21
IDE11502-ENG127591-Locked menu contents-FB_NAV_30    non_blocked     21
IDE11502-ENG127592-Locked menu contents-FB_NAV_31    non_blocked     21
IDE11502-ENG127593-Locked menu contents-FB_NAV_32    non_blocked     21
IDE11502-ENG127594-Locked menu contents-FB_NAV_33    non_blocked     21
IDE11502-ENG127595-Locked menu contents-FB_NAV_34    non_blocked     21
IDE11502-ENG127596-Locked menu contents-FB_NAV_35    non_blocked     21
IDE11502-ENG127597-Locked menu contents-FB_NAV_36    non_blocked     21
IDE11502-ENG127598-Locked menu contents-FB_NAV_37    non_blocked     21
IDE11502-ENG127599-Locked menu contents-FB_NAV_38    non_blocked     21
IDE11502-ENG127600-Locked menu contents-FB_NAV_39    non_blocked     21
IDE11502-ENG127565-Locked menu contents-FB_NAV_4    non_blocked     21
IDE11502-ENG127566-Locked menu contents-FB_NAV_5    non_blocked     21
IDE11502-ENG127567-Locked menu contents-FB_NAV_6    non_blocked     21
IDE11502-ENG127568-Locked menu contents-FB_NAV_7    non_blocked     21
IDE11502-ENG127569-Locked menu contents-FB_NAV_8    non_blocked     21
IDE11502-ENG127570-Locked menu contents-FB_NAV_9    non_blocked     21
IDE11502-ENG127545-Locked menu contents-FB_PHONE_0    non_blocked     21
IDE11502-ENG127546-Locked menu contents-FB_PHONE_1    non_blocked     21
IDE11502-ENG127555-Locked menu contents-FB_PHONE_10    non_blocked     21
IDE11502-ENG127556-Locked menu contents-FB_PHONE_11    non_blocked     21
IDE11502-ENG127557-Locked menu contents-FB_PHONE_12    non_blocked     21
IDE11502-ENG127558-Locked menu contents-FB_PHONE_13    non_blocked     21
IDE11502-ENG127559-Locked menu contents-FB_PHONE_14    non_blocked     21
IDE11502-ENG127560-Locked menu contents-FB_PHONE_15    non_blocked     21
IDE11502-ENG127547-Locked menu contents-FB_PHONE_2    non_blocked     21
IDE11502-ENG127548-Locked menu contents-FB_PHONE_3    non_blocked     21
IDE11502-ENG127549-Locked menu contents-FB_PHONE_4    non_blocked     21
IDE11502-ENG127550-Locked menu contents-FB_PHONE_5    non_blocked     21
IDE11502-ENG127551-Locked menu contents-FB_PHONE_6    non_blocked     21
IDE11502-ENG127552-Locked menu contents-FB_PHONE_7    non_blocked     21
IDE11502-ENG127553-Locked menu contents-FB_PHONE_8    non_blocked     21
IDE11502-ENG127554-Locked menu contents-FB_PHONE_9    non_blocked     21
IDE11502-ENG127505-Locked menu contents-FB_TUNER_0    non_blocked     21
IDE11502-ENG127506-Locked menu contents-FB_TUNER_1    non_blocked     21
IDE11502-ENG127515-Locked menu contents-FB_TUNER_10    non_blocked     21
IDE11502-ENG127516-Locked menu contents-FB_TUNER_11    non_blocked     21
IDE11502-ENG127517-Locked menu contents-FB_TUNER_12    non_blocked     21
IDE11502-ENG127518-Locked menu contents-FB_TUNER_13    non_blocked     21
IDE11502-ENG127519-Locked menu contents-FB_TUNER_14    non_blocked     21
IDE11502-ENG127520-Locked menu contents-FB_TUNER_15    non_blocked     21
IDE11502-ENG127507-Locked menu contents-FB_TUNER_2    non_blocked     21
IDE11502-ENG127508-Locked menu contents-FB_TUNER_3    non_blocked     21
IDE11502-ENG127509-Locked menu contents-FB_TUNER_4    non_blocked     21
IDE11502-ENG127510-Locked menu contents-FB_TUNER_5    non_blocked     21
IDE11502-ENG127511-Locked menu contents-FB_TUNER_6    non_blocked     21
IDE11502-ENG127512-Locked menu contents-FB_TUNER_7    non_blocked     21
IDE11502-ENG127513-Locked menu contents-FB_TUNER_8    non_blocked     21
IDE11502-ENG127514-Locked menu contents-FB_TUNER_9    non_blocked     21
IDE11503-Satellite radio tuner: pre-activated subscription    2    1
IDE11638-Bluetooth Audio Codec    FF     1
MAS00951-Bluetooth    On     1
MAS02809-MAS02870-Check tone frequency-High note frequency range    4000 Hz    6
MAS02809-MAS02871-Check tone frequency-Medium note frequency range    1000 Hz    6
MAS02809-MAS02872-Check tone frequency-Low note frequency range    100 Hz    6
MAS03782-WLAN    On     1
ENG126140-ENG117811-Audio_Management_Audio_Delay_Lines_Gen2-Amplifier_Delay_On_Off    OFF     12
ENG126140-ENG117813-Audio_Management_Audio_Delay_Lines_Gen2-Amplifier_Delay_Time    0.00 ms    12
ENG126140-ENG126188-Audio_Management_Audio_Delay_Lines_Gen2-Headphone_Delay_On_Off    OFF     12
ENG126140-ENG126189-Audio_Management_Audio_Delay_Lines_Gen2-Headphone_Delay_Time    0.00 ms    12
ENG126140-ENG126190-Audio_Management_Audio_Delay_Lines_Gen2-Headphone_wireless_Delay_On_Off    OFF     12
ENG126140-ENG126191-Audio_Management_Audio_Delay_Lines_Gen2-Headphone_wireless_Delay_Time    0.00 ms    12
ENG126140-ENG117810-Audio_Management_Audio_Delay_Lines_Gen2-Main_Unit_Delay_On_Off    OFF     12
ENG126140-ENG117812-Audio_Management_Audio_Delay_Lines_Gen2-Main_Unit_Delay_Time    0.00 ms    12
ENG117920-Audio_Managment_Soundset_Menu    OFF     1
ENG117917-BAP_Debug_Mode_Release    not_released     1
ENG122227-ENG125811-Car_Function_Adaptations_Gen2-menu_auxiliary_climatization    not activated     60
ENG122227-ENG125814-Car_Function_Adaptations_Gen2-menu_auxiliary_climatization_after_disclaimer    not activated     60
ENG122227-ENG126995-Car_Function_Adaptations_Gen2-menu_auxiliary_climatization_clamp_15_off    not activated     60
ENG122227-ENG125812-Car_Function_Adaptations_Gen2-menu_auxiliary_climatization_over_threshold_high    not activated     60
ENG122227-ENG125813-Car_Function_Adaptations_Gen2-menu_auxiliary_climatization_standstill    not activated     60
ENG122227-ENG152538-Car_Function_Adaptations_Gen2-menu_auxiliary_ventilation    not activated     60
ENG122227-ENG152539-Car_Function_Adaptations_Gen2-menu_auxiliary_ventilation_after_disclaimer    not activated     60
ENG122227-ENG152540-Car_Function_Adaptations_Gen2-menu_auxiliary_ventilation_clamp_15_off    not activated     60
ENG122227-ENG152541-Car_Function_Adaptations_Gen2-menu_auxiliary_ventilation_over_threshold_high    not activated     60
ENG122227-ENG152542-Car_Function_Adaptations_Gen2-menu_auxiliary_ventilation_standstill    not activated     60
ENG122227-ENG152543-Car_Function_Adaptations_Gen2-menu_crossroad_assistent    not activated     60
ENG122227-ENG152544-Car_Function_Adaptations_Gen2-menu_crossroad_assistent_after_disclaimer    not activated     60
ENG122227-ENG152545-Car_Function_Adaptations_Gen2-menu_crossroad_assistent_clamp_15_off    not activated     60
ENG122227-ENG152546-Car_Function_Adaptations_Gen2-menu_crossroad_assistent_over_threshold_high    not activated     60
ENG122227-ENG152547-Car_Function_Adaptations_Gen2-menu_crossroad_assistent_standstill    not activated     60
ENG122227-ENG117486-Car_Function_Adaptations_Gen2-menu_display_ACC    not activated     60
ENG122227-ENG117490-Car_Function_Adaptations_Gen2-menu_display_ACC_after_disclaimer    not activated     60
ENG122227-ENG117487-Car_Function_Adaptations_Gen2-menu_display_ACC_operation_clamp_15_off    not activated     60
ENG122227-ENG117488-Car_Function_Adaptations_Gen2-menu_display_ACC_over_threshold_high    activated     60
ENG122227-ENG117489-Car_Function_Adaptations_Gen2-menu_display_ACC_standstill    not activated     60
ENG122227-ENG117646-Car_Function_Adaptations_Gen2-menu_display_adaptive_key    not activated     60
ENG122227-ENG117650-Car_Function_Adaptations_Gen2-menu_display_adaptive_key_after_disclaimer    not activated     60
ENG122227-ENG117647-Car_Function_Adaptations_Gen2-menu_display_adaptive_key_clamp_15_off    not activated     60
ENG122227-ENG117648-Car_Function_Adaptations_Gen2-menu_display_adaptive_key_over_threshold_high    not activated     60
ENG122227-ENG117649-Car_Function_Adaptations_Gen2-menu_display_adaptive_key_standstill    not activated     60
ENG122227-ENG126152-Car_Function_Adaptations_Gen2-menu_display_Adblue    not activated     60
ENG122227-ENG126155-Car_Function_Adaptations_Gen2-menu_display_Adblue_after_disclaimer    not activated     60
ENG122227-ENG127002-Car_Function_Adaptations_Gen2-menu_display_Adblue_clamp_15_off    not activated     60
ENG122227-ENG126153-Car_Function_Adaptations_Gen2-menu_display_Adblue_over_threshold_high    not activated     60
ENG122227-ENG126154-Car_Function_Adaptations_Gen2-menu_display_Adblue_standstill    not activated     60
ENG122227-ENG117591-Car_Function_Adaptations_Gen2-menu_display_air_damper    not activated     60
ENG122227-ENG117595-Car_Function_Adaptations_Gen2-menu_display_air_damper_after_disclaimer    not activated     60
ENG122227-ENG117592-Car_Function_Adaptations_Gen2-menu_display_air_damper_clamp_15_off    not activated     60
ENG122227-ENG117593-Car_Function_Adaptations_Gen2-menu_display_air_damper_over_threshold_high    not activated     60
ENG122227-ENG117594-Car_Function_Adaptations_Gen2-menu_display_air_damper_standstill    not activated     60
ENG122227-ENG117491-Car_Function_Adaptations_Gen2-menu_display_ambient_illumination    activated     60
ENG122227-ENG117495-Car_Function_Adaptations_Gen2-menu_display_ambient_illumination_after_disclaimer    not activated     60
ENG122227-ENG117492-Car_Function_Adaptations_Gen2-menu_display_ambient_illumination_clamp_15_off    not activated     60
ENG122227-ENG117493-Car_Function_Adaptations_Gen2-menu_display_ambient_illumination_over_threshold_high    activated     60
ENG122227-ENG117494-Car_Function_Adaptations_Gen2-menu_display_ambient_illumination_standstill    not activated     60
ENG122227-ENG122296-Car_Function_Adaptations_Gen2-menu_display_angle_of_slope    not activated     60
ENG122227-ENG122300-Car_Function_Adaptations_Gen2-menu_display_angle_of_slope_after_disclaimer    not activated     60
ENG122227-ENG122297-Car_Function_Adaptations_Gen2-menu_display_angle_of_slope_clamp_15_off    not activated     60
ENG122227-ENG122298-Car_Function_Adaptations_Gen2-menu_display_angle_of_slope_over_threshold_high    not activated     60
ENG122227-ENG122299-Car_Function_Adaptations_Gen2-menu_display_angle_of_slope_standstill    not activated     60
ENG122227-ENG117641-Car_Function_Adaptations_Gen2-menu_display_attention_identification    not activated     60
ENG122227-ENG117645-Car_Function_Adaptations_Gen2-menu_display_attention_identification_after_disclaimer    not activated     60
ENG122227-ENG117642-Car_Function_Adaptations_Gen2-menu_display_attention_identification_clamp_15_off    not activated     60
ENG122227-ENG117643-Car_Function_Adaptations_Gen2-menu_display_attention_identification_over_threshold_high    not activated     60
ENG122227-ENG117644-Car_Function_Adaptations_Gen2-menu_display_attention_identification_standstill    not activated     60
ENG122227-ENG117531-Car_Function_Adaptations_Gen2-menu_display_auxiliary_heating    not activated     60
ENG122227-ENG117535-Car_Function_Adaptations_Gen2-menu_display_auxiliary_heating_after_disclaimer    not activated     60
ENG122227-ENG117532-Car_Function_Adaptations_Gen2-menu_display_auxiliary_heating_clamp_15_off    not activated     60
ENG122227-ENG117533-Car_Function_Adaptations_Gen2-menu_display_auxiliary_heating_over_threshold_high    not activated     60
ENG122227-ENG117534-Car_Function_Adaptations_Gen2-menu_display_auxiliary_heating_standstill    not activated     60
ENG122227-ENG117501-Car_Function_Adaptations_Gen2-menu_display_awv    not activated     60
ENG122227-ENG117505-Car_Function_Adaptations_Gen2-menu_display_awv_after_disclaimer    not activated     60
ENG122227-ENG117502-Car_Function_Adaptations_Gen2-menu_display_awv_clamp_15_off    not activated     60
ENG122227-ENG117503-Car_Function_Adaptations_Gen2-menu_display_awv_over_threshold_high    activated     60
ENG122227-ENG117504-Car_Function_Adaptations_Gen2-menu_display_awv_standstill    not activated     60
ENG122227-ENG122301-Car_Function_Adaptations_Gen2-menu_display_battery_management    not activated     60
ENG122227-ENG122305-Car_Function_Adaptations_Gen2-menu_display_battery_management_after_disclaimer    not activated     60
ENG122227-ENG122302-Car_Function_Adaptations_Gen2-menu_display_battery_management_clamp_15_off    not activated     60
ENG122227-ENG122303-Car_Function_Adaptations_Gen2-menu_display_battery_management_over_threshold_high    not activated     60
ENG122227-ENG122304-Car_Function_Adaptations_Gen2-menu_display_battery_management_standstill    not activated     60
ENG122227-ENG117666-Car_Function_Adaptations_Gen2-menu_display_BCmE    activated     60
ENG122227-ENG117670-Car_Function_Adaptations_Gen2-menu_display_BCmE_after_disclaimer    not activated     60
ENG122227-ENG117667-Car_Function_Adaptations_Gen2-menu_display_BCmE_clamp_15_off    not activated     60
ENG122227-ENG117668-Car_Function_Adaptations_Gen2-menu_display_BCmE_over_threshold_high    activated     60
ENG122227-ENG117669-Car_Function_Adaptations_Gen2-menu_display_BCmE_standstill    not activated     60
ENG122227-ENG117536-Car_Function_Adaptations_Gen2-menu_display_board_computer    activated     60
ENG122227-ENG117540-Car_Function_Adaptations_Gen2-menu_display_board_computer_after_disclaimer    not activated     60
ENG122227-ENG117537-Car_Function_Adaptations_Gen2-menu_display_board_computer_clamp_15_off    not activated     60
ENG122227-ENG117538-Car_Function_Adaptations_Gen2-menu_display_board_computer_over_threshold_high    activated     60
ENG122227-ENG117539-Car_Function_Adaptations_Gen2-menu_display_board_computer_standstill    not activated     60
ENG122227-ENG117671-Car_Function_Adaptations_Gen2-menu_display_Brake_Function    activated     60
ENG122227-ENG117675-Car_Function_Adaptations_Gen2-menu_display_Brake_Function_after_disclaimer    not activated     60
ENG122227-ENG117672-Car_Function_Adaptations_Gen2-menu_display_Brake_Function_clamp_15_off    not activated     60
ENG122227-ENG117673-Car_Function_Adaptations_Gen2-menu_display_Brake_Function_over_threshold_high    activated     60
ENG122227-ENG117674-Car_Function_Adaptations_Gen2-menu_display_Brake_Function_standstill    not activated     60
ENG122227-ENG117651-Car_Function_Adaptations_Gen2-menu_display_car_mirror    activated     60
ENG122227-ENG117655-Car_Function_Adaptations_Gen2-menu_display_car_mirror_after_disclaimer    not activated     60
ENG122227-ENG117652-Car_Function_Adaptations_Gen2-menu_display_car_mirror_clamp_15_off    not activated     60
ENG122227-ENG117653-Car_Function_Adaptations_Gen2-menu_display_car_mirror_over_threshold_high    activated     60
ENG122227-ENG117654-Car_Function_Adaptations_Gen2-menu_display_car_mirror_standstill    not activated     60
ENG122227-ENG117561-Car_Function_Adaptations_Gen2-menu_display_central_locking    activated     60
ENG122227-ENG117565-Car_Function_Adaptations_Gen2-menu_display_central_locking_after_disclaimer    not activated     60
ENG122227-ENG117562-Car_Function_Adaptations_Gen2-menu_display_central_locking_clamp_15_off    not activated     60
ENG122227-ENG117563-Car_Function_Adaptations_Gen2-menu_display_central_locking_over_threshold_high    activated     60
ENG122227-ENG117564-Car_Function_Adaptations_Gen2-menu_display_central_locking_standstill    not activated     60
ENG122227-ENG117601-Car_Function_Adaptations_Gen2-menu_display_central_unit_master    activated     60
ENG122227-ENG117605-Car_Function_Adaptations_Gen2-menu_display_central_unit_master_after_disclaimer    not activated     60
ENG122227-ENG117602-Car_Function_Adaptations_Gen2-menu_display_central_unit_master_clamp_15_off    not activated     60
ENG122227-ENG117603-Car_Function_Adaptations_Gen2-menu_display_central_unit_master_over_threshold_high    activated     60
ENG122227-ENG117604-Car_Function_Adaptations_Gen2-menu_display_central_unit_master_standstill    not activated     60
ENG122227-ENG117571-Car_Function_Adaptations_Gen2-menu_display_charisma    not activated     60
ENG122227-ENG117575-Car_Function_Adaptations_Gen2-menu_display_charisma_after_disclaimer    not activated     60
ENG122227-ENG117572-Car_Function_Adaptations_Gen2-menu_display_charisma_clamp_15_off    not activated     60
ENG122227-ENG117573-Car_Function_Adaptations_Gen2-menu_display_charisma_over_threshold_high    not activated     60
ENG122227-ENG117574-Car_Function_Adaptations_Gen2-menu_display_charisma_standstill    not activated     60
ENG122227-ENG117526-Car_Function_Adaptations_Gen2-menu_display_clima_configuration    activated     60
ENG122227-ENG117530-Car_Function_Adaptations_Gen2-menu_display_clima_configuration_after_disclaimer    not activated     60
ENG122227-ENG117527-Car_Function_Adaptations_Gen2-menu_display_clima_configuration_clamp_15_off    not activated     60
ENG122227-ENG117528-Car_Function_Adaptations_Gen2-menu_display_clima_configuration_over_threshold_high    activated     60
ENG122227-ENG117529-Car_Function_Adaptations_Gen2-menu_display_clima_configuration_standstill    not activated     60
ENG122227-ENG117586-Car_Function_Adaptations_Gen2-menu_display_clock    activated     60
ENG122227-ENG117590-Car_Function_Adaptations_Gen2-menu_display_clock_after_disclaimer    not activated     60
ENG122227-ENG117587-Car_Function_Adaptations_Gen2-menu_display_clock_clamp_15_off    not activated     60
ENG122227-ENG117588-Car_Function_Adaptations_Gen2-menu_display_clock_over_threshold_high    activated     60
ENG122227-ENG117589-Car_Function_Adaptations_Gen2-menu_display_clock_standstill    not activated     60
ENG122227-ENG117566-Car_Function_Adaptations_Gen2-menu_display_compass    not activated     60
ENG122227-ENG117570-Car_Function_Adaptations_Gen2-menu_display_compass_after_disclaimer    not activated     60
ENG122227-ENG117567-Car_Function_Adaptations_Gen2-menu_display_compass_clamp_15_off    not activated     60
ENG122227-ENG117568-Car_Function_Adaptations_Gen2-menu_display_compass_over_threshold_high    activated     60
ENG122227-ENG117569-Car_Function_Adaptations_Gen2-menu_display_compass_standstill    not activated     60
ENG122227-ENG125823-Car_Function_Adaptations_Gen2-menu_display_Curve_Assist    not activated     60
ENG122227-ENG125826-Car_Function_Adaptations_Gen2-menu_display_Curve_Assist_after_disclaimer    not activated     60
ENG122227-ENG126998-Car_Function_Adaptations_Gen2-menu_display_Curve_Assist_clamp_15_off    not activated     60
ENG122227-ENG125824-Car_Function_Adaptations_Gen2-menu_display_Curve_Assist_over_threshold_high    not activated     60
ENG122227-ENG125825-Car_Function_Adaptations_Gen2-menu_display_Curve_Assist_standstill    not activated     60
ENG122227-ENG142087-Car_Function_Adaptations_Gen2-menu_display_Display_Configuration    not activated     60
ENG122227-ENG142091-Car_Function_Adaptations_Gen2-menu_display_Display_Configuration_after_disclaimer    not activated     60
ENG122227-ENG142088-Car_Function_Adaptations_Gen2-menu_display_Display_Configuration_clamp_15_off    not activated     60
ENG122227-ENG142089-Car_Function_Adaptations_Gen2-menu_display_Display_Configuration_over_threshold_high    not activated     60
ENG122227-ENG142090-Car_Function_Adaptations_Gen2-menu_display_Display_Configuration_standstill    not activated     60
ENG122227-ENG117656-Car_Function_Adaptations_Gen2-menu_display_driving_school    not activated     60
ENG122227-ENG117660-Car_Function_Adaptations_Gen2-menu_display_driving_school_after_disclaimer    not activated     60
ENG122227-ENG117657-Car_Function_Adaptations_Gen2-menu_display_driving_school_clamp_15_off    not activated     60
ENG122227-ENG117658-Car_Function_Adaptations_Gen2-menu_display_driving_school_over_threshold_high    not activated     60
ENG122227-ENG117659-Car_Function_Adaptations_Gen2-menu_display_driving_school_standstill    not activated     60
ENG122227-ENG125034-Car_Function_Adaptations_Gen2-menu_display_Ecall    not activated     60
ENG122227-ENG125038-Car_Function_Adaptations_Gen2-menu_display_Ecall_after_disclaimer    not activated     60
ENG122227-ENG126999-Car_Function_Adaptations_Gen2-menu_display_eCall_clamp_15_off    not activated     60
ENG122227-ENG125036-Car_Function_Adaptations_Gen2-menu_display_Ecall_over_threshold_high    not activated     60
ENG122227-ENG125037-Car_Function_Adaptations_Gen2-menu_display_Ecall_standstill    not activated     60
ENG122227-ENG126160-Car_Function_Adaptations_Gen2-menu_display_Efficiency_Assist    not activated     60
ENG122227-ENG126163-Car_Function_Adaptations_Gen2-menu_display_Efficiency_Assist_after_disclaimer    not activated     60
ENG122227-ENG127004-Car_Function_Adaptations_Gen2-menu_display_Efficiency_Assist_clamp_15_off    not activated     60
ENG122227-ENG126161-Car_Function_Adaptations_Gen2-menu_display_Efficiency_Assist_over_threshold_high    not activated     60
ENG122227-ENG126162-Car_Function_Adaptations_Gen2-menu_display_Efficiency_Assist_standstill    not activated     60
ENG122227-ENG126144-Car_Function_Adaptations_Gen2-menu_display_ENI    not activated     60
ENG122227-ENG126147-Car_Function_Adaptations_Gen2-menu_display_ENI_after_disclaimer    not activated     60
ENG122227-ENG127000-Car_Function_Adaptations_Gen2-menu_display_ENI_clamp_15_off    not activated     60
ENG122227-ENG126145-Car_Function_Adaptations_Gen2-menu_display_ENI_over_threshold_high    not activated     60
ENG122227-ENG126146-Car_Function_Adaptations_Gen2-menu_display_ENI_standstill    not activated     60
ENG122227-ENG117516-Car_Function_Adaptations_Gen2-menu_display_exterior_illumination    activated     60
ENG122227-ENG117520-Car_Function_Adaptations_Gen2-menu_display_exterior_illumination_after_disclaimer    not activated     60
ENG122227-ENG117517-Car_Function_Adaptations_Gen2-menu_display_exterior_illumination_clamp_15_off    not activated     60
ENG122227-ENG117518-Car_Function_Adaptations_Gen2-menu_display_exterior_illumination_over_threshold_high    activated     60
ENG122227-ENG117519-Car_Function_Adaptations_Gen2-menu_display_exterior_illumination_standstill    not activated     60
ENG122227-ENG117596-Car_Function_Adaptations_Gen2-menu_display_headup_display    not activated     60
ENG122227-ENG117600-Car_Function_Adaptations_Gen2-menu_display_headup_display_after_disclaimer    not activated     60
ENG122227-ENG117597-Car_Function_Adaptations_Gen2-menu_display_headup_display_clamp_15_off    not activated     60
ENG122227-ENG117598-Car_Function_Adaptations_Gen2-menu_display_headup_display_over_threshold_high    not activated     60
ENG122227-ENG117599-Car_Function_Adaptations_Gen2-menu_display_headup_display_standstill    not activated     60
ENG122227-ENG117606-Car_Function_Adaptations_Gen2-menu_display_hybrid    not activated     60
ENG122227-ENG117610-Car_Function_Adaptations_Gen2-menu_display_hybrid_after_disclaimer    not activated     60
ENG122227-ENG117607-Car_Function_Adaptations_Gen2-menu_display_hybrid_clamp_15_off    not activated     60
ENG122227-ENG117608-Car_Function_Adaptations_Gen2-menu_display_hybrid_over_threshold_high    not activated     60
ENG122227-ENG117609-Car_Function_Adaptations_Gen2-menu_display_hybrid_standstill    not activated     60
ENG122227-ENG125805-Car_Function_Adaptations_Gen2-menu_display_lane_assistant    not activated     60
ENG122227-ENG125809-Car_Function_Adaptations_Gen2-menu_display_lane_assistant_after_disclaimer    not activated     60
ENG122227-ENG125806-Car_Function_Adaptations_Gen2-menu_display_lane_assistant_clamp_15_off    not activated     60
ENG122227-ENG125807-Car_Function_Adaptations_Gen2-menu_display_lane_assistant_over_threshold_high    activated     60
ENG122227-ENG125808-Car_Function_Adaptations_Gen2-menu_display_lane_assistant_standstill    not activated     60
ENG122227-ENG117506-Car_Function_Adaptations_Gen2-menu_display_Lane_Departure_Warning    not activated     60
ENG122227-ENG117510-Car_Function_Adaptations_Gen2-menu_display_Lane_Departure_Warning_after_disclaimer    not activated     60
ENG122227-ENG117507-Car_Function_Adaptations_Gen2-menu_display_Lane_Departure_Warning_clamp_15_off    not activated     60
ENG122227-ENG117508-Car_Function_Adaptations_Gen2-menu_display_Lane_Departure_Warning_over_threshold_high    activated     60
ENG122227-ENG117509-Car_Function_Adaptations_Gen2-menu_display_Lane_Departure_Warning_standstill    not activated     60
ENG122227-ENG117631-Car_Function_Adaptations_Gen2-menu_display_MFL_jocker    not activated     60
ENG122227-ENG117635-Car_Function_Adaptations_Gen2-menu_display_MFL_jocker_after_disclaimer    not activated     60
ENG122227-ENG117632-Car_Function_Adaptations_Gen2-menu_display_MFL_jocker_clamp_15_off    not activated     60
ENG122227-ENG117633-Car_Function_Adaptations_Gen2-menu_display_MFL_jocker_over_threshold_high    not activated     60
ENG122227-ENG117634-Car_Function_Adaptations_Gen2-menu_display_MFL_jocker_standstill    not activated     60
ENG122227-ENG117616-Car_Function_Adaptations_Gen2-menu_display_night_vision    not activated     60
ENG122227-ENG117620-Car_Function_Adaptations_Gen2-menu_display_night_vision_after_disclaimer    not activated     60
ENG122227-ENG117617-Car_Function_Adaptations_Gen2-menu_display_night_vision_clamp_15_off    not activated     60
ENG122227-ENG117618-Car_Function_Adaptations_Gen2-menu_display_night_vision_over_threshold_high    not activated     60
ENG122227-ENG117619-Car_Function_Adaptations_Gen2-menu_display_night_vision_standstill    not activated     60
ENG122227-ENG117576-Car_Function_Adaptations_Gen2-menu_display_oil_level    not activated     60
ENG122227-ENG117580-Car_Function_Adaptations_Gen2-menu_display_oil_level_after_disclaimer    not activated     60
ENG122227-ENG117577-Car_Function_Adaptations_Gen2-menu_display_oil_level_clamp_15_off    not activated     60
ENG122227-ENG117578-Car_Function_Adaptations_Gen2-menu_display_oil_level_over_threshold_high    not activated     60
ENG122227-ENG117579-Car_Function_Adaptations_Gen2-menu_display_oil_level_standstill    not activated     60
ENG122227-ENG117496-Car_Function_Adaptations_Gen2-menu_display_pdc    not activated     60
ENG122227-ENG117500-Car_Function_Adaptations_Gen2-menu_display_pdc_after_disclaimer    not activated     60
ENG122227-ENG117497-Car_Function_Adaptations_Gen2-menu_display_pdc_clamp_15_off    not activated     60
ENG122227-ENG117498-Car_Function_Adaptations_Gen2-menu_display_pdc_over_threshold_high    activated     60
ENG122227-ENG117499-Car_Function_Adaptations_Gen2-menu_display_pdc_standstill    not activated     60
ENG122227-ENG125815-Car_Function_Adaptations_Gen2-menu_display_Pedestrian_Assist    not activated     60
ENG122227-ENG125818-Car_Function_Adaptations_Gen2-menu_display_Pedestrian_Assist_after_disclaimer    not activated     60
ENG122227-ENG126996-Car_Function_Adaptations_Gen2-menu_display_Pedestrian_Assist_clamp_15_off    not activated     60
ENG122227-ENG125816-Car_Function_Adaptations_Gen2-menu_display_Pedestrian_Assist_over_threshold_high    not activated     60
ENG122227-ENG125817-Car_Function_Adaptations_Gen2-menu_display_Pedestrian_Assist_standstill    not activated     60
ENG122227-ENG117541-Car_Function_Adaptations_Gen2-menu_display_rdk    activated     60
ENG122227-ENG117545-Car_Function_Adaptations_Gen2-menu_display_rdk_after_disclaimer    not activated     60
ENG122227-ENG117542-Car_Function_Adaptations_Gen2-menu_display_rdk_clamp_15_off    not activated     60
ENG122227-ENG117543-Car_Function_Adaptations_Gen2-menu_display_rdk_over_threshold_high    activated     60
ENG122227-ENG117544-Car_Function_Adaptations_Gen2-menu_display_rdk_standstill    not activated     60
ENG122227-ENG122306-Car_Function_Adaptations_Gen2-menu_display_RearSeatEntertainment    not activated     60
ENG122227-ENG122310-Car_Function_Adaptations_Gen2-menu_display_RearSeatEntertainment_after_disclaimer    not activated     60
ENG122227-ENG122307-Car_Function_Adaptations_Gen2-menu_display_RearSeatEntertainment_clamp_15_off    not activated     60
ENG122227-ENG122308-Car_Function_Adaptations_Gen2-menu_display_RearSeatEntertainment_over_threshold_high    not activated     60
ENG122227-ENG122309-Car_Function_Adaptations_Gen2-menu_display_RearSeatEntertainment_standstill    not activated     60
ENG122227-ENG117626-Car_Function_Adaptations_Gen2-menu_display_reversible_belt_pre_load    not activated     60
ENG122227-ENG117630-Car_Function_Adaptations_Gen2-menu_display_reversible_belt_pre_load_after_disclaimer    not activated     60
ENG122227-ENG117627-Car_Function_Adaptations_Gen2-menu_display_reversible_belt_pre_load_clamp_15_off    not activated     60
ENG122227-ENG117628-Car_Function_Adaptations_Gen2-menu_display_reversible_belt_pre_load_over_threshold_high    not activated     60
ENG122227-ENG117629-Car_Function_Adaptations_Gen2-menu_display_reversible_belt_pre_load_standstill    not activated     60
ENG122227-ENG117636-Car_Function_Adaptations_Gen2-menu_display_road_sign_identification    not activated     60
ENG122227-ENG117640-Car_Function_Adaptations_Gen2-menu_display_road_sign_identification_after_disclaimer    not activated     60
ENG122227-ENG117637-Car_Function_Adaptations_Gen2-menu_display_road_sign_identification_clamp_15_off    not activated     60
ENG122227-ENG117638-Car_Function_Adaptations_Gen2-menu_display_road_sign_identification_over_threshold_high    not activated     60
ENG122227-ENG117639-Car_Function_Adaptations_Gen2-menu_display_road_sign_identification_standstill    not activated     60
ENG122227-ENG117556-Car_Function_Adaptations_Gen2-menu_display_seat_configuration    not activated     60
ENG122227-ENG117560-Car_Function_Adaptations_Gen2-menu_display_seat_configuration_after_disclaimer    not activated     60
ENG122227-ENG117557-Car_Function_Adaptations_Gen2-menu_display_seat_configuration_clamp_15_off    not activated     60
ENG122227-ENG117558-Car_Function_Adaptations_Gen2-menu_display_seat_configuration_over_threshold_high    not activated     60
ENG122227-ENG117559-Car_Function_Adaptations_Gen2-menu_display_seat_configuration_standstill    not activated     60
ENG122227-ENG125819-Car_Function_Adaptations_Gen2-menu_display_Seat_Pneumatic    not activated     60
ENG122227-ENG125822-Car_Function_Adaptations_Gen2-menu_display_Seat_Pneumatic_after_disclaimer    not activated     60
ENG122227-ENG126997-Car_Function_Adaptations_Gen2-menu_display_Seat_Pneumatic_clamp_15_off    not activated     60
ENG122227-ENG125820-Car_Function_Adaptations_Gen2-menu_display_Seat_Pneumatic_over_threshold_high    not activated     60
ENG122227-ENG125821-Car_Function_Adaptations_Gen2-menu_display_Seat_Pneumatic_standstill    not activated     60
ENG122227-ENG117551-Car_Function_Adaptations_Gen2-menu_display_sia    activated     60
ENG122227-ENG117555-Car_Function_Adaptations_Gen2-menu_display_sia_after_disclaimer    not activated     60
ENG122227-ENG117552-Car_Function_Adaptations_Gen2-menu_display_sia_clamp_15_off    not activated     60
ENG122227-ENG117553-Car_Function_Adaptations_Gen2-menu_display_sia_over_threshold_high    activated     60
ENG122227-ENG117554-Car_Function_Adaptations_Gen2-menu_display_sia_standstill    not activated     60
ENG122227-ENG117621-Car_Function_Adaptations_Gen2-menu_display_side_view    not activated     60
ENG122227-ENG117625-Car_Function_Adaptations_Gen2-menu_display_side_view_after_disclaimer    not activated     60
ENG122227-ENG117622-Car_Function_Adaptations_Gen2-menu_display_side_view_clamp_15_off    not activated     60
ENG122227-ENG117623-Car_Function_Adaptations_Gen2-menu_display_side_view_over_threshold_high    not activated     60
ENG122227-ENG117624-Car_Function_Adaptations_Gen2-menu_display_side_view_standstill    not activated     60
ENG122227-ENG122311-Car_Function_Adaptations_Gen2-menu_display_special_functions    not activated     60
ENG122227-ENG122314-Car_Function_Adaptations_Gen2-menu_display_special_functions_after_disclaimer    not activated     60
ENG122227-ENG125810-Car_Function_Adaptations_Gen2-menu_display_special_functions_clamp_15_off    not activated     60
ENG122227-ENG122312-Car_Function_Adaptations_Gen2-menu_display_special_functions_over_threshold_high    not activated     60
ENG122227-ENG122313-Car_Function_Adaptations_Gen2-menu_display_special_functions_standstill    not activated     60
ENG122227-ENG142082-Car_Function_Adaptations_Gen2-menu_display_Spoiler    not activated     60
ENG122227-ENG142086-Car_Function_Adaptations_Gen2-menu_display_Spoiler_after_disclaimer    not activated     60
ENG122227-ENG142083-Car_Function_Adaptations_Gen2-menu_display_Spoiler_clamp_15_off    not activated     60
ENG122227-ENG142084-Car_Function_Adaptations_Gen2-menu_display_Spoiler_over_threshold_high    not activated     60
ENG122227-ENG142085-Car_Function_Adaptations_Gen2-menu_display_Spoiler_standstill    not activated     60
ENG122227-ENG126148-Car_Function_Adaptations_Gen2-menu_display_SportHMI    activated     60
ENG122227-ENG126151-Car_Function_Adaptations_Gen2-menu_display_SportHMI_after_disclaimer    not activated     60
ENG122227-ENG127001-Car_Function_Adaptations_Gen2-menu_display_SportHMI_clamp_15_off    not activated     60
ENG122227-ENG126149-Car_Function_Adaptations_Gen2-menu_display_SportHMI_over_threshold_high    activated     60
ENG122227-ENG126150-Car_Function_Adaptations_Gen2-menu_display_SportHMI_standstill    not activated     60
ENG122227-ENG117676-Car_Function_Adaptations_Gen2-menu_display_Start_Stop_reasons    not activated     60
ENG122227-ENG117680-Car_Function_Adaptations_Gen2-menu_display_Start_Stop_reasons_after_disclaimer    not activated     60
ENG122227-ENG117677-Car_Function_Adaptations_Gen2-menu_display_Start_Stop_reasons_clamp_15_off    not activated     60
ENG122227-ENG117678-Car_Function_Adaptations_Gen2-menu_display_Start_Stop_reasons_over_threshold_high    not activated     60
ENG122227-ENG117679-Car_Function_Adaptations_Gen2-menu_display_Start_Stop_reasons_standstill    not activated     60
ENG122227-ENG122315-Car_Function_Adaptations_Gen2-menu_display_trailer_assistant    not activated     60
ENG122227-ENG122319-Car_Function_Adaptations_Gen2-menu_display_trailer_assistant_after_disclaimer    not activated     60
ENG122227-ENG122316-Car_Function_Adaptations_Gen2-menu_display_trailer_assistant_clamp_15_off    not activated     60
ENG122227-ENG122317-Car_Function_Adaptations_Gen2-menu_display_trailer_assistant_over_threshold_high    not activated     60
ENG122227-ENG122318-Car_Function_Adaptations_Gen2-menu_display_trailer_assistant_standstill    not activated     60
ENG122227-ENG122320-Car_Function_Adaptations_Gen2-menu_display_TV_tuner    not activated     60
ENG122227-ENG122324-Car_Function_Adaptations_Gen2-menu_display_TV_tuner_after_disclaimer    not activated     60
ENG122227-ENG122321-Car_Function_Adaptations_Gen2-menu_display_TV_tuner_clamp_15_off    not activated     60
ENG122227-ENG122322-Car_Function_Adaptations_Gen2-menu_display_TV_tuner_over_threshold_high    not activated     60
ENG122227-ENG122323-Car_Function_Adaptations_Gen2-menu_display_TV_tuner_standstill    not activated     60
ENG122227-ENG117611-Car_Function_Adaptations_Gen2-menu_display_ugdo    not activated     60
ENG122227-ENG117615-Car_Function_Adaptations_Gen2-menu_display_ugdo_after_disclaimer    not activated     60
ENG122227-ENG117612-Car_Function_Adaptations_Gen2-menu_display_ugdo_clamp_15_off    not activated     60
ENG122227-ENG117613-Car_Function_Adaptations_Gen2-menu_display_ugdo_over_threshold_high    not activated     60
ENG122227-ENG117614-Car_Function_Adaptations_Gen2-menu_display_ugdo_standstill    not activated     60
ENG122227-ENG122291-Car_Function_Adaptations_Gen2-menu_display_user_eco_rating    activated     60
ENG122227-ENG122295-Car_Function_Adaptations_Gen2-menu_display_user_eco_rating_after_disclaimer    not activated     60
ENG122227-ENG122292-Car_Function_Adaptations_Gen2-menu_display_user_eco_rating_clamp_15_off    not activated     60
ENG122227-ENG122293-Car_Function_Adaptations_Gen2-menu_display_user_eco_rating_over_threshold_high    activated     60
ENG122227-ENG122294-Car_Function_Adaptations_Gen2-menu_display_user_eco_rating_standstill    not activated     60
ENG122227-ENG117581-Car_Function_Adaptations_Gen2-menu_display_vin    activated     60
ENG122227-ENG117585-Car_Function_Adaptations_Gen2-menu_display_vin_after_disclaimer    not activated     60
ENG122227-ENG117582-Car_Function_Adaptations_Gen2-menu_display_vin_clamp_15_off    not activated     60
ENG122227-ENG117583-Car_Function_Adaptations_Gen2-menu_display_vin_over_threshold_high    activated     60
ENG122227-ENG117584-Car_Function_Adaptations_Gen2-menu_display_vin_standstill    not activated     60
ENG122227-ENG117661-Car_Function_Adaptations_Gen2-menu_display_weariness_recognition    not activated     60
ENG122227-ENG117665-Car_Function_Adaptations_Gen2-menu_display_weariness_recognition_after_disclaimer    not activated     60
ENG122227-ENG117662-Car_Function_Adaptations_Gen2-menu_display_weariness_recognition_clamp_15_off    not activated     60
ENG122227-ENG117663-Car_Function_Adaptations_Gen2-menu_display_weariness_recognition_over_threshold_high    not activated     60
ENG122227-ENG117664-Car_Function_Adaptations_Gen2-menu_display_weariness_recognition_standstill    not activated     60
ENG122227-ENG117521-Car_Function_Adaptations_Gen2-menu_display_windows    activated     60
ENG122227-ENG117525-Car_Function_Adaptations_Gen2-menu_display_windows_after_disclaimer    not activated     60
ENG122227-ENG117522-Car_Function_Adaptations_Gen2-menu_display_windows_clamp_15_off    not activated     60
ENG122227-ENG117523-Car_Function_Adaptations_Gen2-menu_display_windows_over_threshold_high    activated     60
ENG122227-ENG117524-Car_Function_Adaptations_Gen2-menu_display_windows_standstill    not activated     60
ENG122227-ENG117546-Car_Function_Adaptations_Gen2-menu_display_wiper    activated     60
ENG122227-ENG117550-Car_Function_Adaptations_Gen2-menu_display_wiper_after_disclaimer    not activated     60
ENG122227-ENG117547-Car_Function_Adaptations_Gen2-menu_display_wiper_clamp_15_off    not activated     60
ENG122227-ENG117548-Car_Function_Adaptations_Gen2-menu_display_wiper_over_threshold_high    activated     60
ENG122227-ENG117549-Car_Function_Adaptations_Gen2-menu_display_wiper_standstill    not activated     60
ENG122227-ENG142092-Car_Function_Adaptations_Gen2-menu_soundcontrol    not activated     60
ENG122227-ENG142096-Car_Function_Adaptations_Gen2-menu_soundcontrol_after_disclaimer    not activated     60
ENG122227-ENG142093-Car_Function_Adaptations_Gen2-menu_soundcontrol_clamp_15_off    not activated     60
ENG122227-ENG142094-Car_Function_Adaptations_Gen2-menu_soundcontrol_over_threshold_high    not activated     60
ENG122227-ENG142095-Car_Function_Adaptations_Gen2-menu_soundcontrol_standstill    not activated     60
ENG122229-ENG117700-Car_Function_List_BAP_Gen2-ACC_0x05    not activated     64
ENG122229-ENG117701-Car_Function_List_BAP_Gen2-ACC_0x05_msg_bus    Extended data bus     64
ENG122229-ENG117702-Car_Function_List_BAP_Gen2-air_suspension_0x06    not activated     64
ENG122229-ENG117703-Car_Function_List_BAP_Gen2-air_suspension_0x06_msg_bus    Suspension data bus     64
ENG122229-ENG117764-Car_Function_List_BAP_Gen2-Amplifier_0x2D    not activated     64
ENG122229-ENG117765-Car_Function_List_BAP_Gen2-Amplifier_0x2D_msg_bus    not activated     64
ENG122229-ENG122334-Car_Function_List_BAP_Gen2-Angle_Of_Slope_0x24    not activated     64
ENG122229-ENG122335-Car_Function_List_BAP_Gen2-Angle_Of_Slope_0x24_msg_bus    not activated     64
ENG122229-ENG117696-Car_Function_List_BAP_Gen2-auxilary_heating_0x03    not activated     64
ENG122229-ENG117697-Car_Function_List_BAP_Gen2-auxilary_heating_0x03_msg_bus    Comfort data bus     64
ENG122229-ENG117744-Car_Function_List_BAP_Gen2-AWV_0x1B    not activated     64
ENG122229-ENG117745-Car_Function_List_BAP_Gen2-AWV_0x1B_msg_bus    Terminal 15     64
ENG122229-ENG122336-Car_Function_List_BAP_Gen2-Battery_Management_0x25    not activated     64
ENG122229-ENG122337-Car_Function_List_BAP_Gen2-Battery_Management_0x25_msg_bus    Powertrain data bus     64
ENG122229-ENG117758-Car_Function_List_BAP_Gen2-BCmE_0x23    activated     64
ENG122229-ENG117759-Car_Function_List_BAP_Gen2-BCmE_0x23_msg_bus    Infotainment data bus     64
ENG122229-ENG117760-Car_Function_List_BAP_Gen2-Brake_0x26    activated     64
ENG122229-ENG117761-Car_Function_List_BAP_Gen2-Brake_0x26_msg_bus    Suspension data bus     64
ENG122229-ENG117717-Car_Function_List_BAP_Gen2-central_locking_0x0D    activated     64
ENG122229-ENG117716-Car_Function_List_BAP_Gen2-central_locking_0x0D_msg_bus    Comfort data bus     64
ENG122229-ENG117736-Car_Function_List_BAP_Gen2-charisma_0x17    not activated     64
ENG122229-ENG117737-Car_Function_List_BAP_Gen2-charisma_0x17_msg_bus    Infotainment data bus     64
ENG122229-ENG117734-Car_Function_List_BAP_Gen2-clima_slave_2_0x16    not activated     64
ENG122229-ENG117735-Car_Function_List_BAP_Gen2-clima_slave_2_0x16_msg_bus    Comfort data bus     64
ENG122229-ENG117692-Car_Function_List_BAP_Gen2-climatic_master_0x01    activated     64
ENG122229-ENG117693-Car_Function_List_BAP_Gen2-climatic_master_0x01_msg_bus    Comfort data bus     64
ENG122229-ENG117694-Car_Function_List_BAP_Gen2-climatic_slave_0x02    not activated     64
ENG122229-ENG117695-Car_Function_List_BAP_Gen2-climatic_slave_0x02_msg_bus    Comfort data bus     64
ENG122229-ENG117724-Car_Function_List_BAP_Gen2-clock_0x11    activated     64
ENG122229-ENG117725-Car_Function_List_BAP_Gen2-clock_0x11_msg_bus    Comfort data bus     64
ENG122229-ENG117732-Car_Function_List_BAP_Gen2-compass_0x15    not activated     64
ENG122229-ENG117733-Car_Function_List_BAP_Gen2-compass_0x15_msg_bus    not activated     64
ENG122229-ENG117722-Car_Function_List_BAP_Gen2-driver_seat_0x10    not activated     64
ENG122229-ENG117723-Car_Function_List_BAP_Gen2-driver_seat_0x10_msg_bus    Comfort data bus     64
ENG122229-ENG125039-Car_Function_List_BAP_Gen2-Ecall_0x33    not activated     64
ENG122229-ENG125828-Car_Function_List_BAP_Gen2-eCall_0x33_msg_bus    Comfort data bus     64
ENG122229-ENG127500-Car_Function_List_BAP_Gen2-efficiency_assis_msg_bus_0x3C    Comfort data bus     64
ENG122229-ENG127499-Car_Function_List_BAP_Gen2-efficiency_assist_0x3C    not activated     64
ENG122229-ENG125829-Car_Function_List_BAP_Gen2-ENI_0x37    not activated     64
ENG122229-ENG125830-Car_Function_List_BAP_Gen2-ENI_0x37_msg_bus    Comfort data bus     64
ENG122229-ENG152531-Car_Function_List_BAP_Gen2-ExBoxM2_0x38    not activated     64
ENG122229-ENG152532-Car_Function_List_BAP_Gen2-ExBoxM2_0x38_msg_bus    Comfort data bus     64
ENG122229-ENG117708-Car_Function_List_BAP_Gen2-exterieur_light_0x09    activated     64
ENG122229-ENG117709-Car_Function_List_BAP_Gen2-exterieur_light_0x09_msg_bus    Comfort data bus     64
ENG122229-ENG117698-Car_Function_List_BAP_Gen2-headup_displ_0x04    not activated     64
ENG122229-ENG117699-Car_Function_List_BAP_Gen2-headup_displ_0x04_msg_bus    Comfort data bus     64
ENG122229-ENG117746-Car_Function_List_BAP_Gen2-Hybrid_0x1D    not activated     64
ENG122229-ENG117747-Car_Function_List_BAP_Gen2-Hybrid_0x1D_msg_bus    Powertrain data bus     64
ENG122229-ENG117706-Car_Function_List_BAP_Gen2-interieur_light_0x08    activated     64
ENG122229-ENG117707-Car_Function_List_BAP_Gen2-interieur_light_0x08_msg_bus    Comfort data bus     64
ENG122229-ENG117740-Car_Function_List_BAP_Gen2-LDW_HCA_0x19    not activated     64
ENG122229-ENG117741-Car_Function_List_BAP_Gen2-LDW_HCA_0x19_msg_bus    Extended data bus     64
ENG122229-ENG117720-Car_Function_List_BAP_Gen2-MFA_0x0F    activated     64
ENG122229-ENG117721-Car_Function_List_BAP_Gen2-MFA_0x0F_msg_bus    Comfort data bus     64
ENG122229-ENG117767-Car_Function_List_BAP_Gen2-MFL_Jocker_0x34    not activated     64
ENG122229-ENG117766-Car_Function_List_BAP_Gen2-MFL_Jocker_msg_bus_0x34    Infotainment data bus     64
ENG122229-ENG117719-Car_Function_List_BAP_Gen2-mirror_0x0E    activated     64
ENG122229-ENG117718-Car_Function_List_BAP_Gen2-mirror_0x0E_msg_bus    Comfort data bus     64
ENG122229-ENG117738-Car_Function_List_BAP_Gen2-Night_Vision_0x18    not activated     64
ENG122229-ENG117739-Car_Function_List_BAP_Gen2-Night_Vision_0x18_msg_bus    not activated     64
ENG122229-ENG117710-Car_Function_List_BAP_Gen2-parking_assist_0x0A    not activated     64
ENG122229-ENG117711-Car_Function_List_BAP_Gen2-parking_assist_0x0A_msg_bus    Terminal 15     64
ENG122229-ENG117752-Car_Function_List_BAP_Gen2-Passenger_Seat_0x20    not activated     64
ENG122229-ENG117753-Car_Function_List_BAP_Gen2-Passenger_Seat_0x20_msg_bus    Comfort data bus     64
ENG122229-ENG125831-Car_Function_List_BAP_Gen2-Pedestrian_Assist_0x3A    not activated     64
ENG122229-ENG125832-Car_Function_List_BAP_Gen2-Pedestrian_Assist_msg_bus_0x3A    Extended data bus     64
ENG122229-ENG122333-Car_Function_List_BAP_Gen2-Range_Data_0x39    not activated     64
ENG122229-ENG125827-Car_Function_List_BAP_Gen2-Range_Data_msg_bus_0x39    Infotainment data bus     64
ENG122229-ENG122327-Car_Function_List_BAP_Gen2-RearSeatEntertainment_0x2E    not activated     64
ENG122229-ENG122328-Car_Function_List_BAP_Gen2-RearSeatEntertainment_0x2E_msg_bus    Comfort data bus     64
ENG122229-ENG117750-Car_Function_List_BAP_Gen2-Reversible_Seat_Belt_Tightener_0x1F    not activated     64
ENG122229-ENG117751-Car_Function_List_BAP_Gen2-Reversible_Seat_Belt_Tightener_0x1F_msg_bus    Powertrain data bus     64
ENG122229-ENG125833-Car_Function_List_BAP_Gen2-Seat_Pneumatic_0x3B    not activated     64
ENG122229-ENG125834-Car_Function_List_BAP_Gen2-Seat_Pneumatic_msg_bus_0x3B    Comfort data bus     64
ENG122229-ENG139200-Car_Function_List_BAP_Gen2-Seatmemory_codriver_rear_0x3F    not activated     64
ENG122229-ENG139201-Car_Function_List_BAP_Gen2-Seatmemory_codriver_rear_msg_bus_0x3F    Comfort data bus     64
ENG122229-ENG139198-Car_Function_List_BAP_Gen2-Seatmemory_driver_rear_0x3E    not activated     64
ENG122229-ENG139199-Car_Function_List_BAP_Gen2-Seatmemory_driver_rear_msg_bus_0x3E    Comfort data bus     64
ENG122229-ENG117726-Car_Function_List_BAP_Gen2-service_interval_display_0x12    activated     64
ENG122229-ENG117727-Car_Function_List_BAP_Gen2-service_interval_display_0x12_msg_bus    Comfort data bus     64
ENG122229-ENG117748-Car_Function_List_BAP_Gen2-SideView_0x1E    not activated     64
ENG122229-ENG117749-Car_Function_List_BAP_Gen2-SideView_0x1E_msg_bus    not activated     64
ENG122229-ENG122329-Car_Function_List_BAP_Gen2-Special_Functions_0x35    not activated     64
ENG122229-ENG122330-Car_Function_List_BAP_Gen2-Special_Functions_msg_bus_0x35    Comfort data bus     64
ENG122229-ENG117762-Car_Function_List_BAP_Gen2-Start_Stop_reasons_0x27    not activated     64
ENG122229-ENG117763-Car_Function_List_BAP_Gen2-Start_Stop_reasons_0x27_msg_bus    Infotainment data bus     64
ENG122229-ENG117742-Car_Function_List_BAP_Gen2-SWA_0x1A    not activated     64
ENG122229-ENG117743-Car_Function_List_BAP_Gen2-SWA_0x1A_msg_bus    Extended data bus     64
ENG122229-ENG117704-Car_Function_List_BAP_Gen2-tire_pressure_system_0x07    activated     64
ENG122229-ENG117705-Car_Function_List_BAP_Gen2-tire_pressure_system_0x07_msg_bus    Suspension data bus     64
ENG122229-ENG117754-Car_Function_List_BAP_Gen2-traffic_sign_recognition_0x21    not activated     64
ENG122229-ENG117755-Car_Function_List_BAP_Gen2-traffic_sign_recognition_0x21_msg_bus    Extended data bus     64
ENG122229-ENG122331-Car_Function_List_BAP_Gen2-Trailer_Assistant_0x36    not activated     64
ENG122229-ENG122332-Car_Function_List_BAP_Gen2-Trailer_Assistant_msg_bus_0x36    Comfort data bus     64
ENG122229-ENG122325-Car_Function_List_BAP_Gen2-TV_tuner_0x2C    not activated     64
ENG122229-ENG122326-Car_Function_List_BAP_Gen2-TV_tuner_0x2C_msg_bus    Comfort data bus     64
ENG122229-ENG117730-Car_Function_List_BAP_Gen2-UGDO_0x14    not activated     64
ENG122229-ENG117731-Car_Function_List_BAP_Gen2-UGDO_0x14_msg_bus    Terminal 15     64
ENG122229-ENG117728-Car_Function_List_BAP_Gen2-unit_master_0x13    activated     64
ENG122229-ENG117729-Car_Function_List_BAP_Gen2-unit_master_0x13_msg_bus    Comfort data bus     64
ENG122229-ENG117712-Car_Function_List_BAP_Gen2-VPS_0x0B    not activated     64
ENG122229-ENG117713-Car_Function_List_BAP_Gen2-VPS_0x0B_msg_bus    Infotainment data bus     64
ENG122229-ENG117756-Car_Function_List_BAP_Gen2-weariness_rcognition_0x22    not activated     64
ENG122229-ENG117757-Car_Function_List_BAP_Gen2-weariness_rcognition_0x22_msg_bus    Infotainment data bus     64
ENG122229-ENG117714-Car_Function_List_BAP_Gen2-wiper_comfort_0x0C    activated     64
ENG122229-ENG117715-Car_Function_List_BAP_Gen2-wiper_comfort_0x0C_msg_bus    Comfort data bus     64
ENG122228-ENG127498-Car_Function_List_CAN_Gen2-Adaptive_key    Not available     8
ENG122228-ENG117690-Car_Function_List_CAN_Gen2-Adaptive_key_msg_bus    Comfort data bus     8
ENG122228-ENG117688-Car_Function_List_CAN_Gen2-Driving_school    Not available     8
ENG122228-ENG117689-Car_Function_List_CAN_Gen2-Driving_school_msg_bus    Infotainment data bus     8
ENG122228-ENG107608-Car_Function_List_CAN_Gen2-MFL    available.     8
ENG122228-ENG117681-Car_Function_List_CAN_Gen2-MFL_msg_bus    Infotainment data bus     8
ENG122228-ENG117683-Car_Function_List_CAN_Gen2-Oil_level    Not available     8
ENG122228-ENG117684-Car_Function_List_CAN_Gen2-Oil_level_msg_bus    Powertrain data bus     8
ENG122228-ENG117685-Car_Function_List_CAN_Gen2-PDC_audio_lowering    Not available     8
ENG122228-ENG117686-Car_Function_List_CAN_Gen2-PDC_audio_lowering_msg_bus    Suspension data bus     8
ENG122228-ENG98891-Car_Function_List_CAN_Gen2-Reserved    Not available     8
ENG122228-ENG101416-Car_Function_List_CAN_Gen2-Reserved_1    Comfort data bus     8
ENG122228-ENG99458-Car_Function_List_CAN_Gen2-Reserved_2    Comfort data bus     8
ENG122228-ENG99668-Car_Function_List_CAN_Gen2-Reserved_3    Not available     8
ENG122228-ENG99892-Car_Function_List_CAN_Gen2-VIN    available.     8
ENG122228-ENG117687-Car_Function_List_CAN_Gen2-VIN_msg_bus    Comfort data bus     8
ENG122230-ENG142097-Dashboard_Display_Configuration-ability_switch_nav_maps    OFF     10
ENG122230-ENG122343-Dashboard_Display_Configuration-call_picture    OFF     10
ENG122230-ENG122341-Dashboard_Display_Configuration-coverart    OFF     10
ENG122230-ENG122340-Dashboard_Display_Configuration-crossroad_detail_map_compression_mode    RLE     10
ENG122230-ENG122344-Dashboard_Display_Configuration-crossroad_detail_map_resolution    resolution_1     10
ENG122230-ENG127006-Dashboard_Display_Configuration-crossroad_detail_map_transmission_mode    OFF     10
ENG122230-ENG142153-Dashboard_Display_Configuration-dynamic_icon    0    10
ENG122230-ENG127501-Dashboard_Display_Configuration-fastlist_most    OFF     10
ENG122230-ENG122338-Dashboard_Display_Configuration-navigation_map_compression_mode    RLE     10
ENG122230-ENG122339-Dashboard_Display_Configuration-navigation_map_resolution    resolution_1     10
ENG122230-ENG127005-Dashboard_Display_Configuration-navigation_map_transmission_mode    OFF     10
ENG122230-ENG122342-Dashboard_Display_Configuration-stationart    OFF     10
ENG117913-ENG101574-Dimming_Ambient_Illumination_Information_Control_Unit-X1    0    6
ENG117913-ENG99557-Dimming_Ambient_Illumination_Information_Control_Unit-X2    50    6
ENG117913-ENG102140-Dimming_Ambient_Illumination_Information_Control_Unit-X3    100    6
ENG117913-ENG99777-Dimming_Ambient_Illumination_Information_Control_Unit-Y1    0    6
ENG117913-ENG100480-Dimming_Ambient_Illumination_Information_Control_Unit-Y2    50    6
ENG117913-ENG100773-Dimming_Ambient_Illumination_Information_Control_Unit-Y3    100    6
ENG117914-ENG101574-Dimming_Ambient_Illumination_Operating_and_Display_Unit-X1    0    6
ENG117914-ENG99557-Dimming_Ambient_Illumination_Operating_and_Display_Unit-X2    50    6
ENG117914-ENG102140-Dimming_Ambient_Illumination_Operating_and_Display_Unit-X3    100    6
ENG117914-ENG99777-Dimming_Ambient_Illumination_Operating_and_Display_Unit-Y1    0    6
ENG117914-ENG100480-Dimming_Ambient_Illumination_Operating_and_Display_Unit-Y2    50    6
ENG117914-ENG100773-Dimming_Ambient_Illumination_Operating_and_Display_Unit-Y3    100    6
ENG117916-ENG101574-Dimming_Illumination_for_Display_Unit-X1    0    12
ENG117916-ENG99557-Dimming_Illumination_for_Display_Unit-X2    10    12
ENG117916-ENG102140-Dimming_Illumination_for_Display_Unit-X3    100    12
ENG117916-ENG102936-Dimming_Illumination_for_Display_Unit-X4    150    12
ENG117916-ENG103548-Dimming_Illumination_for_Display_Unit-X5    220    12
ENG117916-ENG113992-Dimming_Illumination_for_Display_Unit-X6    253    12
ENG117916-ENG99777-Dimming_Illumination_for_Display_Unit-Y1    1%    12
ENG117916-ENG100480-Dimming_Illumination_for_Display_Unit-Y2    1%    12
ENG117916-ENG100773-Dimming_Illumination_for_Display_Unit-Y3    8%    12
ENG117916-ENG100631-Dimming_Illumination_for_Display_Unit-Y4    20%    12
ENG117916-ENG102174-Dimming_Illumination_for_Display_Unit-Y5    60%    12
ENG117916-ENG113993-Dimming_Illumination_for_Display_Unit-Y6    100%    12
ENG107658-ENG126192-mobile phone voice control availability-apple_device    not installed     1
ENG107658-ENG126193-mobile phone voice control availability-other_devices    not installed     1
ENG117921-Operating_and_Display_Unit_1_Proximity_Sensor_Basic_Adaptation    04 01 52 04 52 10 52 40 52 32 00 64 00 5E 01 5E 01 96 00 FA 00 14 00 14 00 14 00 14 00 FF FF FF FF FF FF FF FF 01 00 CE     40
ENG117809-p_damping_Display    5 ms    1
ENG117808-p_HMI_Display    13%    1
ENG122219-ENG122287-Radio_Level_Quality_Offsets-Set_AM_Quality_Level_Offset    0    2
ENG122219-ENG122288-Radio_Level_Quality_Offsets-Set_FM_Quality_Level_Offset    0    2
ENG117919-Startup_Screen_Sticker_HMI    00 01     2
ENG117905-ENG99753-Testmode_Video_speed_cutoff-PIN    0    3
ENG117905-ENG109008-Testmode_Video_speed_cutoff-speed_limit    0 km/h    3
Elapsed Time: 01:05
And here's 09
Code:
;SW:5Q0-937-087-P   HW:5Q0-937-087-P ---  Cent. Elect.
;Component:BCM PQ37BOSCH 028 0106     Coding:00110B464041A2E949E44000091407001800000000000000000000000000
;EV_BodyContrModul1UDSBosc    13005    EV_BCMBOSCH_013.rod
;Saturday    30    July    2022    10:58:22:52692
;VCDS Version: Release 22.3.1 (x64)  Data version: 20220407 DS337.0
;VCID: 48C9553D623F260B47F-801C
IDE00001-ENG99061-Production mode-Access control    not active     3
IDE00001-ENG115730-Production mode-Exterior lighting    not active     3
IDE00001-ENG116710-Production mode-Frontwischer deaktivieren    not active     3
IDE00001-ENG112304-Production mode-Heckwischer    not active     3
IDE00001-ENG98647-Production mode-Interior lights    not active     3
IDE00001-ENG115729-Production mode-Scheinwerferreinigung    not active     3
IDE00001-ENG115731-Production mode-Virtuel_pedal    not active     3
IDE00002-Transport mode    active     1
IDE00820-Activating and deactivating all development messages    not active     1
IDE01268-ENG115835-Windshield wiper-Adaptives Nachwischen bei SRA    not active     12
IDE01268-ENG116609-Windshield wiper-Anzahl Betaetigungen Frontwaschanlage pro SRA Aktivierung    0    12
IDE01268-ENG115836-Windshield wiper-Frontwischer Notlaufprogramm    active     12
IDE01268-ENG116614-Windshield wiper-Frontwischer Referenzlauf    active     12
IDE01268-ENG116617-Windshield wiper-Geschwindigkeitsabhaengige Wischstufenrueckschaltung    active     12
IDE01268-ENG116615-Windshield wiper-Menuesteuerung Frontwischer    not active     12
IDE01268-ENG115771-Windshield wiper-Regensensor aktivieren    Deactivating     12
IDE01268-ENG115769-Windshield wiper-SRA bei Waschwassermangel    not active     12
IDE01268-ENG115767-Windshield wiper-SRA Einweichpausenzeit    0 ms    12
IDE01268-ENG115768-Windshield wiper-SRA Nachwaschzeit    0 ms    12
IDE01268-ENG116611-Windshield wiper-SRA Pausenzeit    0 ms    12
IDE01268-ENG116610-Windshield wiper-SRA Verzoegerungszeit    0 ms    12
IDE01268-ENG115766-Windshield wiper-SRA Waschzeit    0 ms    12
IDE01268-ENG116616-Windshield wiper-Tippwischen mit erhoehter Wischfrequenz    active     12
IDE01268-ENG116618-Windshield wiper-Traenenwischen Front Status    not active     12
IDE01268-ENG115770-Windshield wiper-Variable Regensensoraktivierung    not active     12
IDE01268-ENG126844-Windshield wiper-Washer_Tipwiping_Variant    0    12
IDE01268-ENG116613-Windshield wiper-Wischer abparken bei Oeffnen der Motorhaube    not active     12
IDE01268-ENG116612-Windshield wiper-Wischer stop bei KL15 aus    not active     12
IDE01268-ENG122185-Windshield wiper-Wischer Stopp bei Oeffnen der Motorhaube    not active     12
IDE01550-Service position    170.49 °    2
IDE02152-Characteristics in production mode    2000 ms    4
IDE02269-MAS04382-Acknowledgement signals-Optical feedback during locking    DELAY     4
IDE02269-ENG116666-Acknowledgement signals-Akustische Rueckmeldung entriegeln    not active     4
IDE02269-ENG116669-Acknowledgement signals-Akustische Rueckmeldung global    active     4
IDE02269-ENG116670-Acknowledgement signals-Akustische Rueckmeldung Signalhorn    not active     4
IDE02269-ENG116667-Acknowledgement signals-Akustische Rueckmeldung verriegeln    active     4
IDE02269-ENG122187-Acknowledgement signals-Dauer der Akustischen Rueckmeldung vom Einfachhorn    normal     4
IDE02269-ENG122188-Acknowledgement signals-Menuesteuerung akustische Rueckmeldung    active     4
IDE02269-ENG122995-Acknowledgement signals-Optische Rueckmeldung 3.Bremsleuchte    not active     4
IDE02269-ENG116668-Acknowledgement signals-Optische Rueckmeldung Komfortschliessen    active     4
IDE02332-Deactivate production mode    0    3
IDE02711-ENG116690-Rear wiper-Automatisches Heckwischen    not active     8
IDE02711-ENG114947-Rear wiper-Heckwischer Weiterlauf    not active     8
IDE02711-ENG116692-Rear wiper-Kein automatisches Abparken    not active     8
IDE02711-ENG114946-Rear wiper-Komfortwischen Heck    active     8
IDE02711-ENG116695-Rear wiper-Komofortwischen Heck Intervallpausenzeit Stufe 1    5 s    8
IDE02711-ENG116696-Rear wiper-Komofortwischen Heck Intervallpausenzeit Stufe 2    3 s    8
IDE02711-ENG116694-Rear wiper-Komofortwischen Heck Intervallpausenzeit Stufe Automatik    7 s    8
IDE02711-ENG116693-Rear wiper-Komofortwischen Heck Intervallpausenzeit Stufe Intervall    7 s    8
IDE02711-ENG116689-Rear wiper-Menuesteuerung Komfortwischen HW    active     8
IDE02711-ENG116691-Rear wiper-Traenenwischen Heck    active     8
IDE02957-ENG115822-Ambient lighting-Defaultwert Ambienteprofil Fussraum    50%    8
IDE02957-ENG116685-Ambient lighting-Defaultwert Ambienteprofil Tuer    50%    8
IDE02957-ENG115823-Ambient lighting-Defaultwert Ambienteprofil Vorn    50%    8
IDE02957-ENG115824-Ambient lighting-Innenlichtinszenierung    Enabled     8
IDE02957-ENG116687-Ambient lighting-Tuerinnengriff mit Tuertafel    not installed     8
IDE02957-ENG116686-Ambient lighting-Tuerinnengriffbeleuchtung mit I-Tafel    not installed     8
IDE03638-IDE04231-Stationary cornering lamp-Steering wheel angle: offset    -63.75 °    14
IDE03638-ENG116677-Stationary cornering lamp-Abdimmgeschwindigkeit    50.00 %/s    14
IDE03638-ENG116673-Stationary cornering lamp-bei Rueckwaertsfahrt    double sided     14
IDE03638-ENG116675-Stationary cornering lamp-Lower speed threshold    0.00 km/h    14
IDE03638-ENG116682-Stationary cornering lamp-Maximaltemperatur    100.00 °C    14
IDE03638-ENG116679-Stationary cornering lamp-obere Grenztemperatur    95.00 °C    14
IDE03638-ENG116681-Stationary cornering lamp-Oberer Lenkradwinkel    120 °    14
IDE03638-ENG116680-Stationary cornering lamp-untere Grenztemperatur    80.00 °C    14
IDE03638-ENG116678-Stationary cornering lamp-Unterer Lenkradwinkel    180 °    14
IDE03638-ENG116676-Stationary cornering lamp-Upper speed threshold    40.00 km/h    14
IDE03638-ENG116674-Stationary cornering lamp-Vorschrift    ECE R119     14
IDE04923-ENG116590-Turn signal control-Blinkkontrolleuchte fuer Anhaenger    separte     8
IDE04923-ENG115774-Turn signal control-Komfortblinken    active     8
IDE04923-ENG116587-Turn signal control-Komfortblinken Blinkzyklen    3    8
IDE04923-ENG116589-Turn signal control-Signalprioritaet fuer Blinker    MFG     8
IDE04923-ENG116588-Turn signal control-Sonderfunktionen    not enabled     8
IDE04923-ENG115818-Turn signal control-Warnblinken bei Verdeckentriegelung    not active     8
IDE04923-ENG115819-Turn signal control-Warnblinktastersuchbeleuchtung Aktivierung    Always active     8
IDE04923-ENG115821-Turn signal control-Warnblinktastersuchbeleuchtung Faktor    0.1    8
IDE04923-ENG115820-Turn signal control-Warnblinktastersuchbeleuchtung Grundwert    10.00%    8
IDE04924-ENG116705-Driving light and parking light-Allwetterlicht Ausschaltgrenze    350 km/h    14
IDE04924-ENG116704-Driving light and parking light-Allwetterlicht Einschaltgrenze    350 km/h    14
IDE04924-ENG115858-Driving light and parking light-Kontrollleuchte fuer Begrenzungslicht    integriert in Suchbeleuchtung     14
IDE04924-ENG115861-Driving light and parking light-Lichthupe bei Zuendung aus moeglich    active     14
IDE04924-ENG115862-Driving light and parking light-Lichtwarnungsverhalten    klemmenabhaengig     14
IDE04924-ENG115863-Driving light and parking light-Menueeinstellung CHO LHO    Menuesteuerung Zeit aktivieren     14
IDE04924-ENG115782-Driving light and parking light-Nebelschlusslicht Warngeschwindigkeit    0 km/h    14
IDE04924-ENG115859-Driving light and parking light-Parklicht ueber LSS aktiviert    not active     14
IDE04924-ENG115831-Driving light and parking light-Schlusslicht mit Bremslichtfunktion    not active     14
IDE04924-ENG126816-Driving light and parking light-Standlicht aus    active     14
IDE04924-ENG115829-Driving light and parking light-Standlichtreduzierung mit beidseitigem Parklicht    not active     14
IDE04924-ENG122200-Driving light and parking light-Warnung Fahrt mit Standlicht    not active     14
IDE04924-ENG115860-Driving light and parking light-Zahl der aktiven Scheinwerfer auf 2 limitieren    in Betrieb lassen     14
IDE04924-ENG115830-Driving light and parking light-Zeitwert Einschaltzeit Abbiegelicht    15 min    14
IDE04926-ENG115656-Comfort illumination-Coming Home Leuchten    Fog lamp     8
IDE04926-ENG116601-Comfort illumination-Coming Home Verbaustatus    automatic     8
IDE04926-ENG116604-Comfort illumination-Coming-home Einschaltereignis    Driver door     8
IDE04926-ENG116608-Comfort illumination-Helligkeitsschwelle Forward-Messung    46400 lx    8
IDE04926-ENG116605-Comfort illumination-Helligkeitsschwelle Infrarot-Messung    12 lx    8
IDE04926-ENG115657-Comfort illumination-Leaving-Home Verbausstatus    Enabled     8
IDE04926-ENG116603-Comfort illumination-Menueeinstellung Cominghome    10 seconds     8
IDE04926-ENG116607-Comfort illumination-Menueeinstellung Leaving-home Zeit per BAP    10 seconds     8
IDE04926-ENG116602-Comfort illumination-Menuesteuerung Coming Home Werkseinstellung    active     8
IDE04926-ENG116606-Comfort illumination-Menuesteuerung Leaving-home Freischaltung per BAP    active     8
IDE04927-IDE01446-Window heater-Running time of heated front window    240 s    8
IDE04927-ENG126847-Window heater-Abschalttemperatur fuer Frontscheibenheizung    35.00 °C    8
IDE04927-ENG126846-Window heater-Abschalttemperatur fuer Heckscheibenheizung    35.00 °C    8
IDE04927-ENG126845-Window heater-FSH Automatik    active     8
IDE04927-ENG115736-Window heater-Heckscheibenheizung Zeitwert    600 s    8
IDE04927-ENG116620-Window heater-Temperaturabhaengige Einschaltzeit FSH    active     8
IDE04927-ENG116619-Window heater-Temperaturabhaengige Einschaltzeit HSH    not active     8
IDE04928-ENG115867-Anti-theft protection-Akustischer Alarm Signalhorn    not active     4
IDE04928-ENG115864-Anti-theft protection-Alarmsignal    frequency modulated     4
IDE04928-ENG115865-Anti-theft protection-DWA Alarmverzoegerung    driver door contact thatcham     4
IDE04928-ENG115812-Anti-theft protection-DWA Camper Modus    not active     4
IDE04928-ENG115866-Anti-theft protection-Sirenen Alarmzahl    1 Alarm     4
IDE04928-ENG126842-Anti-theft protection-Ueberwachung Innenentriegelungshebel    not active     4
IDE04928-ENG115868-Anti-theft protection-Verzoegerung Panikalarm    keine verzoegerung     4
IDE05142-ENG116628-Access control-Autolock Autounlock wirkt auf Heck    active     8
IDE05142-ENG116621-Access control-automatisches Entriegeln    active     8
IDE05142-ENG115756-Access control-automatisches Verriegeln bei Geschwindigkeit    active     8
IDE05142-ENG116706-Access control-Autounlock NAR    active     8
IDE05142-ENG116632-Access control-Bewusstes Safe mit 2. Betaetigung der FFB    not active     8
IDE05142-ENG116624-Access control-CAN Wecken bei Softtouchbetaetigung    active     8
IDE05142-ENG125653-Access control-Deaktivierung_SAFE_ueber_DWA_Deaktivierungstaster    active     8
IDE05142-ENG115759-Access control-Direkter Auswurf des Heckdeckels    active     8
IDE05142-ENG115722-Access control-Electrical rear lid    not active     8
IDE05142-ENG126839-Access control-Entriegelungwunsch_verzoegert_waehrend_Zuziehvorgang    not active     8
IDE05142-ENG126837-Access control-Entsafen mit autorisierte Klemme 15 Ein    not active     8
IDE05142-ENG116707-Access control-Freigabenachlauf Heck nach Einzeloeffnung ueber HDF-Funktaster    not active     8
IDE05142-ENG115754-Access control-Funk bei Klemme 15 ein    not active     8
IDE05142-ENG116622-Access control-Geschwindigkeitsabhaengige Tankdeckelverriegelung    not active     8
IDE05142-ENG116627-Access control-Heckdeckel-Bedienstellen nachCrash temporaer sperren    active     8
IDE05142-ENG115763-Access control-Manuelle ZV Variantenprogrammierung    not active     8
IDE05142-ENG116633-Access control-Menuesteuerung Tuerentriegelung    active     8
IDE05142-ENG116634-Access control-Menuesteuerung ZV Autolock-Unlock    adjustable     8
IDE05142-ENG115761-Access control-Nach externer Verriegelung ist Heck noch zeitbegrenzt entriegelt    not active     8
IDE05142-ENG115755-Access control-Notschließfunktion    active     8
IDE05142-ENG116626-Access control-Oeffnung Heckdeckel bei Wiederentriegelung    not active     8
IDE05142-ENG116631-Access control-Schliessung der Schiebetuer bei geoeffneter Tankklappe    not active     8
IDE05142-ENG125652-Access control-Servoheck Schlossansteuerung    Always     8
IDE05142-ENG126838-Access control-Softtouch-Betaetigung senden    Always     8
IDE05142-ENG115758-Access control-Valet Parking    not active     8
IDE05142-ENG126840-Access control-Vorrastenhaenger_Freigabe    not active     8
IDE05142-ENG116630-Access control-Wiederholte Heckansteuerung beim Schliessen FT oder BT    not active     8
IDE05142-ENG116625-Access control-Wiederoeffnung Elektrische-Schiebetuer    not active     8
IDE05142-ENG115760-Access control-ZV entriegelt auch Heckdeckel    active     8
IDE05142-ENG116629-Access control-ZV Heck nur direkt auswerfen    not active     8
IDE05142-ENG116623-Access control-ZV Tuerentriegelung    Einzeltuerentriegelung     8
IDE05142-ENG116635-Access control-ZV-Entriegelung nach Seitencrash    not active     8
IDE05143-MAS02985-Writing parameter-Value    130    5
IDE05143-MAS04381-Writing parameter-Parameter address    FE 00 00     5
IDE05144-Read parameter address    FE 00 00     3
IDE05145-ENG115874-Light configuration-BAP Bitposition 0    34    560
IDE05145-ENG115893-Light configuration-BAP Bitposition 1    3E     560
IDE05145-ENG116063-Light configuration-BAP Bitposition 10    37    560
IDE05145-ENG116082-Light configuration-BAP Bitposition 11    41    560
IDE05145-ENG116101-Light configuration-BAP Bitposition 12    38    560
IDE05145-ENG116120-Light configuration-BAP Bitposition 13    42    560
IDE05145-ENG116139-Light configuration-BAP Bitposition 14    0    560
IDE05145-ENG116158-Light configuration-BAP Bitposition 15    0    560
IDE05145-ENG116177-Light configuration-BAP Bitposition 16    0    560
IDE05145-ENG116196-Light configuration-BAP Bitposition 17    0    560
IDE05145-ENG116215-Light configuration-BAP Bitposition 18    0    560
IDE05145-ENG116234-Light configuration-BAP Bitposition 19    0    560
IDE05145-ENG115911-Light configuration-BAP Bitposition 2    48    560
IDE05145-ENG116253-Light configuration-BAP Bitposition 20    13    560
IDE05145-ENG116272-Light configuration-BAP Bitposition 21    23    560
IDE05145-ENG116291-Light configuration-BAP Bitposition 22    29    560
IDE05145-ENG116310-Light configuration-BAP Bitposition 23    0A     560
IDE05145-ENG116329-Light configuration-BAP Bitposition 24    1A     560
IDE05145-ENG116348-Light configuration-BAP Bitposition 25    28    560
IDE05145-ENG116367-Light configuration-BAP Bitposition 26    0    560
IDE05145-ENG116386-Light configuration-BAP Bitposition 27    0    560
IDE05145-ENG116405-Light configuration-BAP Bitposition 28    0B     560
IDE05145-ENG116424-Light configuration-BAP Bitposition 29    1B     560
IDE05145-ENG115930-Light configuration-BAP Bitposition 3    4C     560
IDE05145-ENG116443-Light configuration-BAP Bitposition 30    0    560
IDE05145-ENG116462-Light configuration-BAP Bitposition 31    0    560
IDE05145-ENG116481-Light configuration-BAP Bitposition 32    0    560
IDE05145-ENG116500-Light configuration-BAP Bitposition 33    0    560
IDE05145-ENG116519-Light configuration-BAP Bitposition 34    0    560
IDE05145-ENG115949-Light configuration-BAP Bitposition 4    3A     560
IDE05145-ENG115968-Light configuration-BAP Bitposition 5    44    560
IDE05145-ENG115987-Light configuration-BAP Bitposition 6    36    560
IDE05145-ENG116006-Light configuration-BAP Bitposition 7    40    560
IDE05145-ENG116025-Light configuration-BAP Bitposition 8    35    560
IDE05145-ENG116044-Light configuration-BAP Bitposition 9    3F     560
IDE05145-ENG115883-Light configuration-Dimming Direction CD 0    maximize     560
IDE05145-ENG115902-Light configuration-Dimming Direction CD 1    maximize     560
IDE05145-ENG116072-Light configuration-Dimming Direction CD 10    maximize     560
IDE05145-ENG116091-Light configuration-Dimming Direction CD 11    maximize     560
IDE05145-ENG116110-Light configuration-Dimming Direction CD 12    maximize     560
IDE05145-ENG116129-Light configuration-Dimming Direction CD 13    maximize     560
IDE05145-ENG116148-Light configuration-Dimming Direction CD 14    maximize     560
IDE05145-ENG116167-Light configuration-Dimming Direction CD 15    maximize     560
IDE05145-ENG116186-Light configuration-Dimming Direction CD 16    maximize     560
IDE05145-ENG116205-Light configuration-Dimming Direction CD 17    maximize     560
IDE05145-ENG116224-Light configuration-Dimming Direction CD 18    maximize     560
IDE05145-ENG116243-Light configuration-Dimming Direction CD 19    maximize     560
IDE05145-ENG115920-Light configuration-Dimming Direction CD 2    minimize     560
IDE05145-ENG116262-Light configuration-Dimming Direction CD 20    minimize     560
IDE05145-ENG116281-Light configuration-Dimming Direction CD 21    minimize     560
IDE05145-ENG116300-Light configuration-Dimming Direction CD 22    maximize     560
IDE05145-ENG116319-Light configuration-Dimming Direction CD 23    maximize     560
IDE05145-ENG116338-Light configuration-Dimming Direction CD 24    maximize     560
IDE05145-ENG116357-Light configuration-Dimming Direction CD 25    maximize     560
IDE05145-ENG116376-Light configuration-Dimming Direction CD 26    maximize     560
IDE05145-ENG116395-Light configuration-Dimming Direction CD 27    maximize     560
IDE05145-ENG116414-Light configuration-Dimming Direction CD 28    maximize     560
IDE05145-ENG116433-Light configuration-Dimming Direction CD 29    maximize     560
IDE05145-ENG115939-Light configuration-Dimming Direction CD 3    minimize     560
IDE05145-ENG116452-Light configuration-Dimming Direction CD 30    maximize     560
IDE05145-ENG116471-Light configuration-Dimming Direction CD 31    maximize     560
IDE05145-ENG116490-Light configuration-Dimming Direction CD 32    maximize     560
IDE05145-ENG116509-Light configuration-Dimming Direction CD 33    maximize     560
IDE05145-ENG116528-Light configuration-Dimming Direction CD 34    maximize     560
IDE05145-ENG115958-Light configuration-Dimming Direction CD 4    minimize     560
IDE05145-ENG115977-Light configuration-Dimming Direction CD 5    minimize     560
IDE05145-ENG115996-Light configuration-Dimming Direction CD 6    maximize     560
IDE05145-ENG116015-Light configuration-Dimming Direction CD 7    maximize     560
IDE05145-ENG116034-Light configuration-Dimming Direction CD 8    maximize     560
IDE05145-ENG116053-Light configuration-Dimming Direction CD 9    maximize     560
IDE05145-ENG115887-Light configuration-Dimming Direction EF 0    maximize     560
IDE05145-ENG115906-Light configuration-Dimming Direction EF 1    maximize     560
IDE05145-ENG116076-Light configuration-Dimming Direction EF 10    maximize     560
IDE05145-ENG116095-Light configuration-Dimming Direction EF 11    maximize     560
IDE05145-ENG116114-Light configuration-Dimming Direction EF 12    maximize     560
IDE05145-ENG116133-Light configuration-Dimming Direction EF 13    maximize     560
IDE05145-ENG116152-Light configuration-Dimming Direction EF 14    maximize     560
IDE05145-ENG116171-Light configuration-Dimming Direction EF 15    maximize     560
IDE05145-ENG116190-Light configuration-Dimming Direction EF 16    maximize     560
IDE05145-ENG116209-Light configuration-Dimming Direction EF 17    maximize     560
IDE05145-ENG116228-Light configuration-Dimming Direction EF 18    maximize     560
IDE05145-ENG116247-Light configuration-Dimming Direction EF 19    maximize     560
IDE05145-ENG115924-Light configuration-Dimming Direction EF 2    maximize     560
IDE05145-ENG116266-Light configuration-Dimming Direction EF 20    maximize     560
IDE05145-ENG116285-Light configuration-Dimming Direction EF 21    maximize     560
IDE05145-ENG116304-Light configuration-Dimming Direction EF 22    maximize     560
IDE05145-ENG116323-Light configuration-Dimming Direction EF 23    maximize     560
IDE05145-ENG116342-Light configuration-Dimming Direction EF 24    maximize     560
IDE05145-ENG116361-Light configuration-Dimming Direction EF 25    maximize     560
IDE05145-ENG116380-Light configuration-Dimming Direction EF 26    maximize     560
IDE05145-ENG116399-Light configuration-Dimming Direction EF 27    maximize     560
IDE05145-ENG116418-Light configuration-Dimming Direction EF 28    maximize     560
IDE05145-ENG116437-Light configuration-Dimming Direction EF 29    maximize     560
IDE05145-ENG115943-Light configuration-Dimming Direction EF 3    maximize     560
IDE05145-ENG116456-Light configuration-Dimming Direction EF 30    maximize     560
IDE05145-ENG116475-Light configuration-Dimming Direction EF 31    maximize     560
IDE05145-ENG116494-Light configuration-Dimming Direction EF 32    maximize     560
IDE05145-ENG116513-Light configuration-Dimming Direction EF 33    maximize     560
IDE05145-ENG116532-Light configuration-Dimming Direction EF 34    maximize     560
IDE05145-ENG115962-Light configuration-Dimming Direction EF 4    maximize     560
IDE05145-ENG115981-Light configuration-Dimming Direction EF 5    maximize     560
IDE05145-ENG116000-Light configuration-Dimming Direction EF 6    maximize     560
IDE05145-ENG116019-Light configuration-Dimming Direction EF 7    maximize     560
IDE05145-ENG116038-Light configuration-Dimming Direction EF 8    maximize     560
IDE05145-ENG116057-Light configuration-Dimming Direction EF 9    maximize     560
IDE05145-ENG115891-Light configuration-Dimming Direction GH 0    maximize     560
IDE05145-ENG115909-Light configuration-Dimming Direction GH 1    maximize     560
IDE05145-ENG116080-Light configuration-Dimming Direction GH 10    maximize     560
IDE05145-ENG116099-Light configuration-Dimming Direction GH 11    maximize     560
IDE05145-ENG116118-Light configuration-Dimming Direction GH 12    maximize     560
IDE05145-ENG116137-Light configuration-Dimming Direction GH 13    maximize     560
IDE05145-ENG116156-Light configuration-Dimming Direction GH 14    maximize     560
IDE05145-ENG116175-Light configuration-Dimming Direction GH 15    maximize     560
IDE05145-ENG116194-Light configuration-Dimming Direction GH 16    maximize     560
IDE05145-ENG116213-Light configuration-Dimming Direction GH 17    maximize     560
IDE05145-ENG116232-Light configuration-Dimming Direction GH 18    maximize     560
IDE05145-ENG116251-Light configuration-Dimming Direction GH 19    maximize     560
IDE05145-ENG115928-Light configuration-Dimming Direction GH 2    maximize     560
IDE05145-ENG116270-Light configuration-Dimming Direction GH 20    maximize     560
IDE05145-ENG116289-Light configuration-Dimming Direction GH 21    maximize     560
IDE05145-ENG116308-Light configuration-Dimming Direction GH 22    maximize     560
IDE05145-ENG116327-Light configuration-Dimming Direction GH 23    maximize     560
IDE05145-ENG116346-Light configuration-Dimming Direction GH 24    maximize     560
IDE05145-ENG116365-Light configuration-Dimming Direction GH 25    maximize     560
IDE05145-ENG116384-Light configuration-Dimming Direction GH 26    maximize     560
IDE05145-ENG116403-Light configuration-Dimming Direction GH 27    maximize     560
IDE05145-ENG116422-Light configuration-Dimming Direction GH 28    maximize     560
IDE05145-ENG116441-Light configuration-Dimming Direction GH 29    maximize     560
IDE05145-ENG115947-Light configuration-Dimming Direction GH 3    maximize     560
IDE05145-ENG116460-Light configuration-Dimming Direction GH 30    maximize     560
IDE05145-ENG116479-Light configuration-Dimming Direction GH 31    maximize     560
IDE05145-ENG116498-Light configuration-Dimming Direction GH 32    maximize     560
IDE05145-ENG116517-Light configuration-Dimming Direction GH 33    maximize     560
IDE05145-ENG116536-Light configuration-Dimming Direction GH 34    maximize     560
IDE05145-ENG115966-Light configuration-Dimming Direction GH 4    maximize     560
IDE05145-ENG115985-Light configuration-Dimming Direction GH 5    maximize     560
IDE05145-ENG116004-Light configuration-Dimming Direction GH 6    maximize     560
IDE05145-ENG116023-Light configuration-Dimming Direction GH 7    maximize     560
IDE05145-ENG116042-Light configuration-Dimming Direction GH 8    maximize     560
IDE05145-ENG116061-Light configuration-Dimming Direction GH 9    maximize     560
IDE05145-ENG115878-Light configuration-Dimmwert AB 0    100    560
IDE05145-ENG115897-Light configuration-Dimmwert AB 1    100    560
IDE05145-ENG116067-Light configuration-Dimmwert AB 10    127    560
IDE05145-ENG116086-Light configuration-Dimmwert AB 11    127    560
IDE05145-ENG116105-Light configuration-Dimmwert AB 12    100    560
IDE05145-ENG116124-Light configuration-Dimmwert AB 13    100    560
IDE05145-ENG116143-Light configuration-Dimmwert AB 14    0    560
IDE05145-ENG116162-Light configuration-Dimmwert AB 15    0    560
IDE05145-ENG116181-Light configuration-Dimmwert AB 16    0    560
IDE05145-ENG116200-Light configuration-Dimmwert AB 17    0    560
IDE05145-ENG116219-Light configuration-Dimmwert AB 18    0    560
IDE05145-ENG116238-Light configuration-Dimmwert AB 19    0    560
IDE05145-ENG115915-Light configuration-Dimmwert AB 2    100    560
IDE05145-ENG116257-Light configuration-Dimmwert AB 20    100    560
IDE05145-ENG116276-Light configuration-Dimmwert AB 21    100    560
IDE05145-ENG116295-Light configuration-Dimmwert AB 22    100    560
IDE05145-ENG116314-Light configuration-Dimmwert AB 23    28    560
IDE05145-ENG116333-Light configuration-Dimmwert AB 24    28    560
IDE05145-ENG116352-Light configuration-Dimmwert AB 25    100    560
IDE05145-ENG116371-Light configuration-Dimmwert AB 26    0    560
IDE05145-ENG116390-Light configuration-Dimmwert AB 27    127    560
IDE05145-ENG116409-Light configuration-Dimmwert AB 28    100    560
IDE05145-ENG116428-Light configuration-Dimmwert AB 29    100    560
IDE05145-ENG115934-Light configuration-Dimmwert AB 3    100    560
IDE05145-ENG116447-Light configuration-Dimmwert AB 30    89    560
IDE05145-ENG116466-Light configuration-Dimmwert AB 31    0    560
IDE05145-ENG116485-Light configuration-Dimmwert AB 32    0    560
IDE05145-ENG116504-Light configuration-Dimmwert AB 33    0    560
IDE05145-ENG116523-Light configuration-Dimmwert AB 34    0    560
IDE05145-ENG115953-Light configuration-Dimmwert AB 4    127    560
IDE05145-ENG115972-Light configuration-Dimmwert AB 5    127    560
IDE05145-ENG115991-Light configuration-Dimmwert AB 6    127    560
IDE05145-ENG116010-Light configuration-Dimmwert AB 7    127    560
IDE05145-ENG116029-Light configuration-Dimmwert AB 8    127    560
IDE05145-ENG116048-Light configuration-Dimmwert AB 9    127    560
IDE05145-ENG115882-Light configuration-Dimmwert CD 0    0    560
IDE05145-ENG115901-Light configuration-Dimmwert CD 1    0    560
IDE05145-ENG116071-Light configuration-Dimmwert CD 10    0    560
IDE05145-ENG116090-Light configuration-Dimmwert CD 11    0    560
IDE05145-ENG116109-Light configuration-Dimmwert CD 12    0    560
IDE05145-ENG116128-Light configuration-Dimmwert CD 13    0    560
IDE05145-ENG116147-Light configuration-Dimmwert CD 14    0    560
IDE05145-ENG116166-Light configuration-Dimmwert CD 15    0    560
IDE05145-ENG116185-Light configuration-Dimmwert CD 16    0    560
IDE05145-ENG116204-Light configuration-Dimmwert CD 17    0    560
IDE05145-ENG116223-Light configuration-Dimmwert CD 18    0    560
IDE05145-ENG116242-Light configuration-Dimmwert CD 19    0    560
IDE05145-ENG115919-Light configuration-Dimmwert CD 2    0    560
IDE05145-ENG116261-Light configuration-Dimmwert CD 20    0    560
IDE05145-ENG116280-Light configuration-Dimmwert CD 21    0    560
IDE05145-ENG116299-Light configuration-Dimmwert CD 22    0    560
IDE05145-ENG116318-Light configuration-Dimmwert CD 23    100    560
IDE05145-ENG116337-Light configuration-Dimmwert CD 24    100    560
IDE05145-ENG116356-Light configuration-Dimmwert CD 25    0    560
IDE05145-ENG116375-Light configuration-Dimmwert CD 26    0    560
IDE05145-ENG116394-Light configuration-Dimmwert CD 27    0    560
IDE05145-ENG116413-Light configuration-Dimmwert CD 28    0    560
IDE05145-ENG116432-Light configuration-Dimmwert CD 29    0    560
IDE05145-ENG115938-Light configuration-Dimmwert CD 3    0    560
IDE05145-ENG116451-Light configuration-Dimmwert CD 30    0    560
IDE05145-ENG116470-Light configuration-Dimmwert CD 31    0    560
IDE05145-ENG116489-Light configuration-Dimmwert CD 32    0    560
IDE05145-ENG116508-Light configuration-Dimmwert CD 33    0    560
IDE05145-ENG116527-Light configuration-Dimmwert CD 34    0    560
IDE05145-ENG115957-Light configuration-Dimmwert CD 4    0    560
IDE05145-ENG115976-Light configuration-Dimmwert CD 5    0    560
IDE05145-ENG115995-Light configuration-Dimmwert CD 6    0    560
IDE05145-ENG116014-Light configuration-Dimmwert CD 7    0    560
IDE05145-ENG116033-Light configuration-Dimmwert CD 8    0    560
IDE05145-ENG116052-Light configuration-Dimmwert CD 9    0    560
IDE05145-ENG115886-Light configuration-Dimmwert EF 0    0    560
IDE05145-ENG115905-Light configuration-Dimmwert EF 1    0    560
IDE05145-ENG116075-Light configuration-Dimmwert EF 10    0    560
IDE05145-ENG116094-Light configuration-Dimmwert EF 11    0    560
IDE05145-ENG116113-Light configuration-Dimmwert EF 12    0    560
IDE05145-ENG116132-Light configuration-Dimmwert EF 13    0    560
IDE05145-ENG116151-Light configuration-Dimmwert EF 14    0    560
IDE05145-ENG116170-Light configuration-Dimmwert EF 15    0    560
IDE05145-ENG116189-Light configuration-Dimmwert EF 16    0    560
IDE05145-ENG116208-Light configuration-Dimmwert EF 17    0    560
IDE05145-ENG116227-Light configuration-Dimmwert EF 18    0    560
IDE05145-ENG116246-Light configuration-Dimmwert EF 19    0    560
IDE05145-ENG115923-Light configuration-Dimmwert EF 2    26    560
IDE05145-ENG116265-Light configuration-Dimmwert EF 20    28    560
IDE05145-ENG116284-Light configuration-Dimmwert EF 21    28    560
IDE05145-ENG116303-Light configuration-Dimmwert EF 22    0    560
IDE05145-ENG116322-Light configuration-Dimmwert EF 23    0    560
IDE05145-ENG116341-Light configuration-Dimmwert EF 24    0    560
IDE05145-ENG116360-Light configuration-Dimmwert EF 25    0    560
IDE05145-ENG116379-Light configuration-Dimmwert EF 26    0    560
IDE05145-ENG116398-Light configuration-Dimmwert EF 27    0    560
IDE05145-ENG116417-Light configuration-Dimmwert EF 28    0    560
IDE05145-ENG116436-Light configuration-Dimmwert EF 29    0    560
IDE05145-ENG115942-Light configuration-Dimmwert EF 3    26    560
IDE05145-ENG116455-Light configuration-Dimmwert EF 30    0    560
IDE05145-ENG116474-Light configuration-Dimmwert EF 31    0    560
IDE05145-ENG116493-Light configuration-Dimmwert EF 32    0    560
IDE05145-ENG116512-Light configuration-Dimmwert EF 33    0    560
IDE05145-ENG116531-Light configuration-Dimmwert EF 34    0    560
IDE05145-ENG115961-Light configuration-Dimmwert EF 4    127    560
IDE05145-ENG115980-Light configuration-Dimmwert EF 5    127    560
IDE05145-ENG115999-Light configuration-Dimmwert EF 6    0    560
IDE05145-ENG116018-Light configuration-Dimmwert EF 7    0    560
IDE05145-ENG116037-Light configuration-Dimmwert EF 8    0    560
IDE05145-ENG116056-Light configuration-Dimmwert EF 9    0    560
IDE05145-ENG115890-Light configuration-Dimmwert GH 0    0    560
IDE05145-ENG115908-Light configuration-Dimmwert GH 1    0    560
IDE05145-ENG116079-Light configuration-Dimmwert GH 10    0    560
IDE05145-ENG116098-Light configuration-Dimmwert GH 11    0    560
IDE05145-ENG116117-Light configuration-Dimmwert GH 12    0    560
IDE05145-ENG116136-Light configuration-Dimmwert GH 13    0    560
IDE05145-ENG116155-Light configuration-Dimmwert GH 14    0    560
IDE05145-ENG116174-Light configuration-Dimmwert GH 15    0    560
IDE05145-ENG116193-Light configuration-Dimmwert GH 16    0    560
IDE05145-ENG116212-Light configuration-Dimmwert GH 17    0    560
IDE05145-ENG116231-Light configuration-Dimmwert GH 18    0    560
IDE05145-ENG116250-Light configuration-Dimmwert GH 19    0    560
IDE05145-ENG115927-Light configuration-Dimmwert GH 2    0    560
IDE05145-ENG116269-Light configuration-Dimmwert GH 20    0    560
IDE05145-ENG116288-Light configuration-Dimmwert GH 21    0    560
IDE05145-ENG116307-Light configuration-Dimmwert GH 22    0    560
IDE05145-ENG116326-Light configuration-Dimmwert GH 23    0    560
IDE05145-ENG116345-Light configuration-Dimmwert GH 24    0    560
IDE05145-ENG116364-Light configuration-Dimmwert GH 25    0    560
IDE05145-ENG116383-Light configuration-Dimmwert GH 26    0    560
IDE05145-ENG116402-Light configuration-Dimmwert GH 27    0    560
IDE05145-ENG116421-Light configuration-Dimmwert GH 28    0    560
IDE05145-ENG116440-Light configuration-Dimmwert GH 29    0    560
IDE05145-ENG115946-Light configuration-Dimmwert GH 3    0    560
IDE05145-ENG116459-Light configuration-Dimmwert GH 30    0    560
IDE05145-ENG116478-Light configuration-Dimmwert GH 31    0    560
IDE05145-ENG116497-Light configuration-Dimmwert GH 32    0    560
IDE05145-ENG116516-Light configuration-Dimmwert GH 33    0    560
IDE05145-ENG116535-Light configuration-Dimmwert GH 34    0    560
IDE05145-ENG115965-Light configuration-Dimmwert GH 4    0    560
IDE05145-ENG115984-Light configuration-Dimmwert GH 5    0    560
IDE05145-ENG116003-Light configuration-Dimmwert GH 6    0    560
IDE05145-ENG116022-Light configuration-Dimmwert GH 7    0    560
IDE05145-ENG116041-Light configuration-Dimmwert GH 8    0    560
IDE05145-ENG116060-Light configuration-Dimmwert GH 9    0    560
IDE05145-ENG115875-Light configuration-Fehlerort mittleres Byte DTC-DFCC 0    14    560
IDE05145-ENG115894-Light configuration-Fehlerort mittleres Byte DTC-DFCC 1    15    560
IDE05145-ENG116064-Light configuration-Fehlerort mittleres Byte DTC-DFCC 10    1E     560
IDE05145-ENG116083-Light configuration-Fehlerort mittleres Byte DTC-DFCC 11    1F     560
IDE05145-ENG116102-Light configuration-Fehlerort mittleres Byte DTC-DFCC 12    22    560
IDE05145-ENG116121-Light configuration-Fehlerort mittleres Byte DTC-DFCC 13    23    560
IDE05145-ENG116140-Light configuration-Fehlerort mittleres Byte DTC-DFCC 14    0    560
IDE05145-ENG116159-Light configuration-Fehlerort mittleres Byte DTC-DFCC 15    0    560
IDE05145-ENG116178-Light configuration-Fehlerort mittleres Byte DTC-DFCC 16    0    560
IDE05145-ENG116197-Light configuration-Fehlerort mittleres Byte DTC-DFCC 17    0    560
IDE05145-ENG116216-Light configuration-Fehlerort mittleres Byte DTC-DFCC 18    0    560
IDE05145-ENG116235-Light configuration-Fehlerort mittleres Byte DTC-DFCC 19    0    560
IDE05145-ENG115912-Light configuration-Fehlerort mittleres Byte DTC-DFCC 2    4A     560
IDE05145-ENG116254-Light configuration-Fehlerort mittleres Byte DTC-DFCC 20    3D     560
IDE05145-ENG116273-Light configuration-Fehlerort mittleres Byte DTC-DFCC 21    3E     560
IDE05145-ENG116292-Light configuration-Fehlerort mittleres Byte DTC-DFCC 22    2C     560
IDE05145-ENG116311-Light configuration-Fehlerort mittleres Byte DTC-DFCC 23    29    560
IDE05145-ENG116330-Light configuration-Fehlerort mittleres Byte DTC-DFCC 24    2A     560
IDE05145-ENG116349-Light configuration-Fehlerort mittleres Byte DTC-DFCC 25    30    560
IDE05145-ENG116368-Light configuration-Fehlerort mittleres Byte DTC-DFCC 26    0    560
IDE05145-ENG116387-Light configuration-Fehlerort mittleres Byte DTC-DFCC 27    47    560
IDE05145-ENG116406-Light configuration-Fehlerort mittleres Byte DTC-DFCC 28    31    560
IDE05145-ENG116425-Light configuration-Fehlerort mittleres Byte DTC-DFCC 29    32    560
IDE05145-ENG115931-Light configuration-Fehlerort mittleres Byte DTC-DFCC 3    4C     560
IDE05145-ENG116444-Light configuration-Fehlerort mittleres Byte DTC-DFCC 30    2    560
IDE05145-ENG116463-Light configuration-Fehlerort mittleres Byte DTC-DFCC 31    0    560
IDE05145-ENG116482-Light configuration-Fehlerort mittleres Byte DTC-DFCC 32    0    560
IDE05145-ENG116501-Light configuration-Fehlerort mittleres Byte DTC-DFCC 33    0    560
IDE05145-ENG116520-Light configuration-Fehlerort mittleres Byte DTC-DFCC 34    0    560
IDE05145-ENG115950-Light configuration-Fehlerort mittleres Byte DTC-DFCC 4    49    560
IDE05145-ENG115969-Light configuration-Fehlerort mittleres Byte DTC-DFCC 5    4B     560
IDE05145-ENG115988-Light configuration-Fehlerort mittleres Byte DTC-DFCC 6    1A     560
IDE05145-ENG116007-Light configuration-Fehlerort mittleres Byte DTC-DFCC 7    1B     560
IDE05145-ENG116026-Light configuration-Fehlerort mittleres Byte DTC-DFCC 8    26    560
IDE05145-ENG116045-Light configuration-Fehlerort mittleres Byte DTC-DFCC 9    27    560
IDE05145-ENG115873-Light configuration-Lasttyp 0    12 - Blinkleuchten     560
IDE05145-ENG115892-Light configuration-Lasttyp 1    12 - Blinkleuchten     560
IDE05145-ENG116062-Light configuration-Lasttyp 10    2 - Shutter: Diagnosesensierung für 'LED low'     560
IDE05145-ENG116081-Light configuration-Lasttyp 11    2 - Shutter: Diagnosesensierung für 'LED low'     560
IDE05145-ENG116100-Light configuration-Lasttyp 12    10 - allgemeine Scheinwerfer     560
IDE05145-ENG116119-Light configuration-Lasttyp 13    10 - allgemeine Scheinwerfer     560
IDE05145-ENG116138-Light configuration-Lasttyp 14    not active     560
IDE05145-ENG116157-Light configuration-Lasttyp 15    not active     560
IDE05145-ENG116176-Light configuration-Lasttyp 16    not active     560
IDE05145-ENG116195-Light configuration-Lasttyp 17    not active     560
IDE05145-ENG116214-Light configuration-Lasttyp 18    not active     560
IDE05145-ENG116233-Light configuration-Lasttyp 19    not active     560
IDE05145-ENG115910-Light configuration-Lasttyp 2    4 - LED Tagfahrlichtmodul Signal     560
IDE05145-ENG116252-Light configuration-Lasttyp 20    14 - kombinierte Blink- Bremsleuchten     560
IDE05145-ENG116271-Light configuration-Lasttyp 21    14 - kombinierte Blink- Bremsleuchten     560
IDE05145-ENG116290-Light configuration-Lasttyp 22    42 - LED dritte Bremsleuchte     560
IDE05145-ENG116309-Light configuration-Lasttyp 23    9 - allgemeine Glühlampe 27W: auch H15     560
IDE05145-ENG116328-Light configuration-Lasttyp 24    9 - allgemeine Glühlampe 27W: auch H15     560
IDE05145-ENG116347-Light configuration-Lasttyp 25    18 - 2* 5W     560
IDE05145-ENG116366-Light configuration-Lasttyp 26    not active     560
IDE05145-ENG116385-Light configuration-Lasttyp 27    1 - LED Tagfahrlichtmodul Versorgung     560
IDE05145-ENG116404-Light configuration-Lasttyp 28    43 - allgemeine LED     560
IDE05145-ENG116423-Light configuration-Lasttyp 29    43 - allgemeine LED     560
IDE05145-ENG115929-Light configuration-Lasttyp 3    4 - LED Tagfahrlichtmodul Signal     560
IDE05145-ENG116442-Light configuration-Lasttyp 30    36 - LED Kleinleistung     560
IDE05145-ENG116461-Light configuration-Lasttyp 31    not active     560
IDE05145-ENG116480-Light configuration-Lasttyp 32    not active     560
IDE05145-ENG116499-Light configuration-Lasttyp 33    not active     560
IDE05145-ENG116518-Light configuration-Lasttyp 34    not active     560
IDE05145-ENG115948-Light configuration-Lasttyp 4    1 - LED Tagfahrlichtmodul Versorgung     560
IDE05145-ENG115967-Light configuration-Lasttyp 5    1 - LED Tagfahrlichtmodul Versorgung     560
IDE05145-ENG115986-Light configuration-Lasttyp 6    3 - Xenon Abblendlicht     560
IDE05145-ENG116005-Light configuration-Lasttyp 7    3 - Xenon Abblendlicht     560
IDE05145-ENG116024-Light configuration-Lasttyp 8    36 - LED Kleinleistung     560
IDE05145-ENG116043-Light configuration-Lasttyp 9    36 - LED Kleinleistung     560
IDE05145-ENG115879-Light configuration-Lichtansteuerung HD AB 0    Always     560
IDE05145-ENG115898-Light configuration-Lichtansteuerung HD AB 1    Always     560
IDE05145-ENG116068-Light configuration-Lichtansteuerung HD AB 10    Always     560
IDE05145-ENG116087-Light configuration-Lichtansteuerung HD AB 11    Always     560
IDE05145-ENG116106-Light configuration-Lichtansteuerung HD AB 12    Always     560
IDE05145-ENG116125-Light configuration-Lichtansteuerung HD AB 13    Always     560
IDE05145-ENG116144-Light configuration-Lichtansteuerung HD AB 14    Always     560
IDE05145-ENG116163-Light configuration-Lichtansteuerung HD AB 15    Always     560
IDE05145-ENG116182-Light configuration-Lichtansteuerung HD AB 16    Always     560
IDE05145-ENG116201-Light configuration-Lichtansteuerung HD AB 17    Always     560
IDE05145-ENG116220-Light configuration-Lichtansteuerung HD AB 18    Always     560
IDE05145-ENG116239-Light configuration-Lichtansteuerung HD AB 19    Always     560
IDE05145-ENG115916-Light configuration-Lichtansteuerung HD AB 2    Always     560
IDE05145-ENG116258-Light configuration-Lichtansteuerung HD AB 20    Always     560
IDE05145-ENG116277-Light configuration-Lichtansteuerung HD AB 21    Always     560
IDE05145-ENG116296-Light configuration-Lichtansteuerung HD AB 22    Always     560
IDE05145-ENG116315-Light configuration-Lichtansteuerung HD AB 23    Always     560
IDE05145-ENG116334-Light configuration-Lichtansteuerung HD AB 24    Always     560
IDE05145-ENG116353-Light configuration-Lichtansteuerung HD AB 25    Always     560
IDE05145-ENG116372-Light configuration-Lichtansteuerung HD AB 26    Always     560
IDE05145-ENG116391-Light configuration-Lichtansteuerung HD AB 27    Always     560
IDE05145-ENG116410-Light configuration-Lichtansteuerung HD AB 28    Always     560
IDE05145-ENG116430-Light configuration-Lichtansteuerung HD AB 29    Always     560
IDE05145-ENG115935-Light configuration-Lichtansteuerung HD AB 3    Always     560
IDE05145-ENG116448-Light configuration-Lichtansteuerung HD AB 30    Always     560
IDE05145-ENG116467-Light configuration-Lichtansteuerung HD AB 31    Always     560
IDE05145-ENG116486-Light configuration-Lichtansteuerung HD AB 32    Always     560
IDE05145-ENG116505-Light configuration-Lichtansteuerung HD AB 33    Always     560
IDE05145-ENG116524-Light configuration-Lichtansteuerung HD AB 34    Always     560
IDE05145-ENG115954-Light configuration-Lichtansteuerung HD AB 4    Always     560
IDE05145-ENG115973-Light configuration-Lichtansteuerung HD AB 5    Always     560
IDE05145-ENG115992-Light configuration-Lichtansteuerung HD AB 6    Always     560
IDE05145-ENG116011-Light configuration-Lichtansteuerung HD AB 7    Always     560
IDE05145-ENG116030-Light configuration-Lichtansteuerung HD AB 8    Always     560
IDE05145-ENG116049-Light configuration-Lichtansteuerung HD AB 9    Always     560
IDE05145-ENG116199-Light configuration-Lichtfunktion  B 17    0    560
IDE05145-ENG116126-Light configuration-Lichtfunktion  C 13    0    560
IDE05145-ENG115876-Light configuration-Lichtfunktion A 0    2    560
IDE05145-ENG115895-Light configuration-Lichtfunktion A 1    4    560
IDE05145-ENG116065-Light configuration-Lichtfunktion A 10    13    560
IDE05145-ENG116084-Light configuration-Lichtfunktion A 11    14    560
IDE05145-ENG116103-Light configuration-Lichtfunktion A 12    18    560
IDE05145-ENG116122-Light configuration-Lichtfunktion A 13    19    560
IDE05145-ENG116141-Light configuration-Lichtfunktion A 14    0    560
IDE05145-ENG116160-Light configuration-Lichtfunktion A 15    0    560
IDE05145-ENG116179-Light configuration-Lichtfunktion A 16    0    560
IDE05145-ENG116198-Light configuration-Lichtfunktion A 17    0    560
IDE05145-ENG116217-Light configuration-Lichtfunktion A 18    0    560
IDE05145-ENG116236-Light configuration-Lichtfunktion A 19    0    560
IDE05145-ENG115913-Light configuration-Lichtfunktion A 2    20    560
IDE05145-ENG116255-Light configuration-Lichtfunktion A 20    24    560
IDE05145-ENG116274-Light configuration-Lichtfunktion A 21    24    560
IDE05145-ENG116293-Light configuration-Lichtfunktion A 22    24    560
IDE05145-ENG116312-Light configuration-Lichtfunktion A 23    8    560
IDE05145-ENG116331-Light configuration-Lichtfunktion A 24    8    560
IDE05145-ENG116350-Light configuration-Lichtfunktion A 25    8    560
IDE05145-ENG116369-Light configuration-Lichtfunktion A 26    0    560
IDE05145-ENG116388-Light configuration-Lichtfunktion A 27    8    560
IDE05145-ENG116407-Light configuration-Lichtfunktion A 28    25    560
IDE05145-ENG116426-Light configuration-Lichtfunktion A 29    25    560
IDE05145-ENG115932-Light configuration-Lichtfunktion A 3    20    560
IDE05145-ENG116445-Light configuration-Lichtfunktion A 30    43    560
IDE05145-ENG116464-Light configuration-Lichtfunktion A 31    0    560
IDE05145-ENG116483-Light configuration-Lichtfunktion A 32    0    560
IDE05145-ENG116502-Light configuration-Lichtfunktion A 33    0    560
IDE05145-ENG116521-Light configuration-Lichtfunktion A 34    0    560
IDE05145-ENG115951-Light configuration-Lichtfunktion A 4    20    560
IDE05145-ENG115970-Light configuration-Lichtfunktion A 5    20    560
IDE05145-ENG115989-Light configuration-Lichtfunktion A 6    11    560
IDE05145-ENG116008-Light configuration-Lichtfunktion A 7    12    560
IDE05145-ENG116027-Light configuration-Lichtfunktion A 8    8    560
IDE05145-ENG116046-Light configuration-Lichtfunktion A 9    8    560
IDE05145-ENG115877-Light configuration-Lichtfunktion B 0    0    560
IDE05145-ENG115896-Light configuration-Lichtfunktion B 1    0    560
IDE05145-ENG116066-Light configuration-Lichtfunktion B 10    15    560
IDE05145-ENG116085-Light configuration-Lichtfunktion B 11    15    560
IDE05145-ENG116104-Light configuration-Lichtfunktion B 12    0    560
IDE05145-ENG116123-Light configuration-Lichtfunktion B 13    0    560
IDE05145-ENG116142-Light configuration-Lichtfunktion B 14    0    560
IDE05145-ENG116161-Light configuration-Lichtfunktion B 15    0    560
IDE05145-ENG116180-Light configuration-Lichtfunktion B 16    0    560
IDE05145-ENG116218-Light configuration-Lichtfunktion B 18    0    560
IDE05145-ENG116237-Light configuration-Lichtfunktion B 19    0    560
IDE05145-ENG115914-Light configuration-Lichtfunktion B 2    0    560
IDE05145-ENG116256-Light configuration-Lichtfunktion B 20    2    560
IDE05145-ENG116275-Light configuration-Lichtfunktion B 21    4    560
IDE05145-ENG116294-Light configuration-Lichtfunktion B 22    0    560
IDE05145-ENG116313-Light configuration-Lichtfunktion B 23    0    560
IDE05145-ENG116332-Light configuration-Lichtfunktion B 24    0    560
IDE05145-ENG116351-Light configuration-Lichtfunktion B 25    0    560
IDE05145-ENG116370-Light configuration-Lichtfunktion B 26    0    560
IDE05145-ENG116389-Light configuration-Lichtfunktion B 27    0    560
IDE05145-ENG116408-Light configuration-Lichtfunktion B 28    0    560
IDE05145-ENG116427-Light configuration-Lichtfunktion B 29    0    560
IDE05145-ENG115933-Light configuration-Lichtfunktion B 3    0    560
IDE05145-ENG116446-Light configuration-Lichtfunktion B 30    0    560
IDE05145-ENG116465-Light configuration-Lichtfunktion B 31    0    560
IDE05145-ENG116484-Light configuration-Lichtfunktion B 32    0    560
IDE05145-ENG116503-Light configuration-Lichtfunktion B 33    0    560
IDE05145-ENG116522-Light configuration-Lichtfunktion B 34    0    560
IDE05145-ENG115952-Light configuration-Lichtfunktion B 4    0    560
IDE05145-ENG115971-Light configuration-Lichtfunktion B 5    0    560
IDE05145-ENG115990-Light configuration-Lichtfunktion B 6    15    560
IDE05145-ENG116009-Light configuration-Lichtfunktion B 7    15    560
IDE05145-ENG116028-Light configuration-Lichtfunktion B 8    9    560
IDE05145-ENG116047-Light configuration-Lichtfunktion B 9    10    560
IDE05145-ENG115880-Light configuration-Lichtfunktion C 0    0    560
IDE05145-ENG115899-Light configuration-Lichtfunktion C 1    0    560
IDE05145-ENG116069-Light configuration-Lichtfunktion C 10    0    560
IDE05145-ENG116088-Light configuration-Lichtfunktion C 11    0    560
IDE05145-ENG116107-Light configuration-Lichtfunktion C 12    0    560
IDE05145-ENG116145-Light configuration-Lichtfunktion C 14    0    560
IDE05145-ENG116164-Light configuration-Lichtfunktion C 15    0    560
IDE05145-ENG116183-Light configuration-Lichtfunktion C 16    0    560
IDE05145-ENG116202-Light configuration-Lichtfunktion C 17    0    560
IDE05145-ENG116221-Light configuration-Lichtfunktion C 18    0    560
IDE05145-ENG116240-Light configuration-Lichtfunktion C 19    0    560
IDE05145-ENG115917-Light configuration-Lichtfunktion C 2    6    560
IDE05145-ENG116259-Light configuration-Lichtfunktion C 20    3    560
IDE05145-ENG116278-Light configuration-Lichtfunktion C 21    5    560
IDE05145-ENG116297-Light configuration-Lichtfunktion C 22    0    560
IDE05145-ENG116316-Light configuration-Lichtfunktion C 23    24    560
IDE05145-ENG116335-Light configuration-Lichtfunktion C 24    24    560
IDE05145-ENG116354-Light configuration-Lichtfunktion C 25    0    560
IDE05145-ENG116373-Light configuration-Lichtfunktion C 26    0    560
IDE05145-ENG116392-Light configuration-Lichtfunktion C 27    24    560
IDE05145-ENG116411-Light configuration-Lichtfunktion C 28    0    560
IDE05145-ENG116429-Light configuration-Lichtfunktion C 29    0    560
IDE05145-ENG115936-Light configuration-Lichtfunktion C 3    7    560
IDE05145-ENG116449-Light configuration-Lichtfunktion C 30    0    560
IDE05145-ENG116468-Light configuration-Lichtfunktion C 31    0    560
IDE05145-ENG116487-Light configuration-Lichtfunktion C 32    0    560
IDE05145-ENG116506-Light configuration-Lichtfunktion C 33    0    560
IDE05145-ENG116525-Light configuration-Lichtfunktion C 34    0    560
IDE05145-ENG115955-Light configuration-Lichtfunktion C 4    6    560
IDE05145-ENG115974-Light configuration-Lichtfunktion C 5    7    560
IDE05145-ENG115993-Light configuration-Lichtfunktion C 6    0    560
IDE05145-ENG116012-Light configuration-Lichtfunktion C 7    0    560
IDE05145-ENG116031-Light configuration-Lichtfunktion C 8    0    560
IDE05145-ENG116050-Light configuration-Lichtfunktion C 9    0    560
IDE05145-ENG115881-Light configuration-Lichtfunktion D 0    0    560
IDE05145-ENG115900-Light configuration-Lichtfunktion D 1    0    560
IDE05145-ENG116070-Light configuration-Lichtfunktion D 10    0    560
IDE05145-ENG116089-Light configuration-Lichtfunktion D 11    0    560
IDE05145-ENG116108-Light configuration-Lichtfunktion D 12    0    560
IDE05145-ENG116127-Light configuration-Lichtfunktion D 13    0    560
IDE05145-ENG116146-Light configuration-Lichtfunktion D 14    0    560
IDE05145-ENG116165-Light configuration-Lichtfunktion D 15    0    560
IDE05145-ENG116184-Light configuration-Lichtfunktion D 16    0    560
IDE05145-ENG116203-Light configuration-Lichtfunktion D 17    0    560
IDE05145-ENG116222-Light configuration-Lichtfunktion D 18    0    560
IDE05145-ENG116241-Light configuration-Lichtfunktion D 19    0    560
IDE05145-ENG115918-Light configuration-Lichtfunktion D 2    0    560
IDE05145-ENG116260-Light configuration-Lichtfunktion D 20    0    560
IDE05145-ENG116279-Light configuration-Lichtfunktion D 21    0    560
IDE05145-ENG116298-Light configuration-Lichtfunktion D 22    0    560
IDE05145-ENG116317-Light configuration-Lichtfunktion D 23    0    560
IDE05145-ENG116336-Light configuration-Lichtfunktion D 24    0    560
IDE05145-ENG116355-Light configuration-Lichtfunktion D 25    0    560
IDE05145-ENG116374-Light configuration-Lichtfunktion D 26    0    560
IDE05145-ENG116393-Light configuration-Lichtfunktion D 27    0    560
IDE05145-ENG116412-Light configuration-Lichtfunktion D 28    0    560
IDE05145-ENG116431-Light configuration-Lichtfunktion D 29    0    560
IDE05145-ENG115937-Light configuration-Lichtfunktion D 3    0    560
IDE05145-ENG116450-Light configuration-Lichtfunktion D 30    0    560
IDE05145-ENG116469-Light configuration-Lichtfunktion D 31    0    560
IDE05145-ENG116488-Light configuration-Lichtfunktion D 32    0    560
IDE05145-ENG116507-Light configuration-Lichtfunktion D 33    0    560
IDE05145-ENG116526-Light configuration-Lichtfunktion D 34    0    560
IDE05145-ENG115956-Light configuration-Lichtfunktion D 4    0    560
IDE05145-ENG115975-Light configuration-Lichtfunktion D 5    0    560
IDE05145-ENG115994-Light configuration-Lichtfunktion D 6    0    560
IDE05145-ENG116013-Light configuration-Lichtfunktion D 7    0    560
IDE05145-ENG116032-Light configuration-Lichtfunktion D 8    0    560
IDE05145-ENG116051-Light configuration-Lichtfunktion D 9    0    560
IDE05145-ENG115884-Light configuration-Lichtfunktion E 0    0    560
IDE05145-ENG115903-Light configuration-Lichtfunktion E 1    0    560
IDE05145-ENG116073-Light configuration-Lichtfunktion E 10    0    560
IDE05145-ENG116092-Light configuration-Lichtfunktion E 11    0    560
IDE05145-ENG116111-Light configuration-Lichtfunktion E 12    0    560
IDE05145-ENG116130-Light configuration-Lichtfunktion E 13    0    560
IDE05145-ENG116149-Light configuration-Lichtfunktion E 14    0    560
IDE05145-ENG116168-Light configuration-Lichtfunktion E 15    0    560
IDE05145-ENG116187-Light configuration-Lichtfunktion E 16    0    560
IDE05145-ENG116206-Light configuration-Lichtfunktion E 17    0    560
IDE05145-ENG116225-Light configuration-Lichtfunktion E 18    0    560
IDE05145-ENG116244-Light configuration-Lichtfunktion E 19    0    560
IDE05145-ENG115921-Light configuration-Lichtfunktion E 2    8    560
IDE05145-ENG116263-Light configuration-Lichtfunktion E 20    8    560
IDE05145-ENG116282-Light configuration-Lichtfunktion E 21    8    560
IDE05145-ENG116301-Light configuration-Lichtfunktion E 22    0    560
IDE05145-ENG116320-Light configuration-Lichtfunktion E 23    0    560
IDE05145-ENG116339-Light configuration-Lichtfunktion E 24    0    560
IDE05145-ENG116358-Light configuration-Lichtfunktion E 25    0    560
IDE05145-ENG116377-Light configuration-Lichtfunktion E 26    0    560
IDE05145-ENG116396-Light configuration-Lichtfunktion E 27    0    560
IDE05145-ENG116415-Light configuration-Lichtfunktion E 28    0    560
IDE05145-ENG116434-Light configuration-Lichtfunktion E 29    0    560
IDE05145-ENG115940-Light configuration-Lichtfunktion E 3    8    560
IDE05145-ENG116453-Light configuration-Lichtfunktion E 30    0    560
IDE05145-ENG116472-Light configuration-Lichtfunktion E 31    0    560
IDE05145-ENG116491-Light configuration-Lichtfunktion E 32    0    560
IDE05145-ENG116510-Light configuration-Lichtfunktion E 33    0    560
IDE05145-ENG116529-Light configuration-Lichtfunktion E 34    0    560
IDE05145-ENG115959-Light configuration-Lichtfunktion E 4    8    560
IDE05145-ENG115978-Light configuration-Lichtfunktion E 5    8    560
IDE05145-ENG115997-Light configuration-Lichtfunktion E 6    0    560
IDE05145-ENG116016-Light configuration-Lichtfunktion E 7    0    560
IDE05145-ENG116035-Light configuration-Lichtfunktion E 8    0    560
IDE05145-ENG116054-Light configuration-Lichtfunktion E 9    0    560
IDE05145-ENG115885-Light configuration-Lichtfunktion F 0    0    560
IDE05145-ENG115904-Light configuration-Lichtfunktion F 1    0    560
IDE05145-ENG116074-Light configuration-Lichtfunktion F 10    0    560
IDE05145-ENG116093-Light configuration-Lichtfunktion F 11    0    560
IDE05145-ENG116112-Light configuration-Lichtfunktion F 12    0    560
IDE05145-ENG116131-Light configuration-Lichtfunktion F 13    0    560
IDE05145-ENG116150-Light configuration-Lichtfunktion F 14    0    560
IDE05145-ENG116169-Light configuration-Lichtfunktion F 15    0    560
IDE05145-ENG116188-Light configuration-Lichtfunktion F 16    0    560
IDE05145-ENG116207-Light configuration-Lichtfunktion F 17    0    560
IDE05145-ENG116226-Light configuration-Lichtfunktion F 18    0    560
IDE05145-ENG116245-Light configuration-Lichtfunktion F 19    0    560
IDE05145-ENG115922-Light configuration-Lichtfunktion F 2    9    560
IDE05145-ENG116264-Light configuration-Lichtfunktion F 20    0    560
IDE05145-ENG116283-Light configuration-Lichtfunktion F 21    0    560
IDE05145-ENG116302-Light configuration-Lichtfunktion F 22    0    560
IDE05145-ENG116321-Light configuration-Lichtfunktion F 23    0    560
IDE05145-ENG116340-Light configuration-Lichtfunktion F 24    0    560
IDE05145-ENG116359-Light configuration-Lichtfunktion F 25    0    560
IDE05145-ENG116378-Light configuration-Lichtfunktion F 26    0    560
IDE05145-ENG116397-Light configuration-Lichtfunktion F 27    0    560
IDE05145-ENG116416-Light configuration-Lichtfunktion F 28    0    560
IDE05145-ENG116435-Light configuration-Lichtfunktion F 29    0    560
IDE05145-ENG116454-Light configuration-Lichtfunktion F 30    0    560
IDE05145-ENG116473-Light configuration-Lichtfunktion F 31    0    560
IDE05145-ENG116492-Light configuration-Lichtfunktion F 32    0    560
IDE05145-ENG116511-Light configuration-Lichtfunktion F 33    0    560
IDE05145-ENG116530-Light configuration-Lichtfunktion F 34    0    560
IDE05145-ENG115960-Light configuration-Lichtfunktion F 4    9    560
IDE05145-ENG115998-Light configuration-Lichtfunktion F 6    0    560
IDE05145-ENG116017-Light configuration-Lichtfunktion F 7    0    560
IDE05145-ENG116036-Light configuration-Lichtfunktion F 8    0    560
IDE05145-ENG116055-Light configuration-Lichtfunktion F 9    0    560
IDE05145-ENG115941-Light configuration-Lichtfunktion F3    10    560
IDE05145-ENG115979-Light configuration-Lichtfunktion F5    10    560
IDE05145-ENG115888-Light configuration-Lichtfunktion G 0    0    560
IDE05145-ENG115907-Light configuration-Lichtfunktion G 1    0    560
IDE05145-ENG116077-Light configuration-Lichtfunktion G 10    0    560
IDE05145-ENG116096-Light configuration-Lichtfunktion G 11    0    560
IDE05145-ENG116115-Light configuration-Lichtfunktion G 12    0    560
IDE05145-ENG116134-Light configuration-Lichtfunktion G 13    0    560
IDE05145-ENG116153-Light configuration-Lichtfunktion G 14    0    560
IDE05145-ENG116172-Light configuration-Lichtfunktion G 15    0    560
IDE05145-ENG116191-Light configuration-Lichtfunktion G 16    0    560
IDE05145-ENG116210-Light configuration-Lichtfunktion G 17    0    560
IDE05145-ENG116229-Light configuration-Lichtfunktion G 18    0    560
IDE05145-ENG116248-Light configuration-Lichtfunktion G 19    0    560
IDE05145-ENG115925-Light configuration-Lichtfunktion G 2    0    560
IDE05145-ENG116267-Light configuration-Lichtfunktion G 20    0    560
IDE05145-ENG116286-Light configuration-Lichtfunktion G 21    0    560
IDE05145-ENG116305-Light configuration-Lichtfunktion G 22    0    560
IDE05145-ENG116324-Light configuration-Lichtfunktion G 23    0    560
IDE05145-ENG116343-Light configuration-Lichtfunktion G 24    0    560
IDE05145-ENG116362-Light configuration-Lichtfunktion G 25    0    560
IDE05145-ENG116381-Light configuration-Lichtfunktion G 26    0    560
IDE05145-ENG116400-Light configuration-Lichtfunktion G 27    0    560
IDE05145-ENG116419-Light configuration-Lichtfunktion G 28    0    560
IDE05145-ENG116438-Light configuration-Lichtfunktion G 29    0    560
IDE05145-ENG115944-Light configuration-Lichtfunktion G 3    0    560
IDE05145-ENG116457-Light configuration-Lichtfunktion G 30    0    560
IDE05145-ENG116476-Light configuration-Lichtfunktion G 31    0    560
IDE05145-ENG116495-Light configuration-Lichtfunktion G 32    0    560
IDE05145-ENG116514-Light configuration-Lichtfunktion G 33    0    560
IDE05145-ENG116533-Light configuration-Lichtfunktion G 34    0    560
IDE05145-ENG115963-Light configuration-Lichtfunktion G 4    0    560
IDE05145-ENG115982-Light configuration-Lichtfunktion G 5    0    560
IDE05145-ENG116001-Light configuration-Lichtfunktion G 6    0    560
IDE05145-ENG116020-Light configuration-Lichtfunktion G 7    0    560
IDE05145-ENG116039-Light configuration-Lichtfunktion G 8    0    560
IDE05145-ENG116058-Light configuration-Lichtfunktion G 9    0    560
IDE05145-ENG115889-Light configuration-Lichtfunktion H 0    0    560
IDE05145-ENG116549-Light configuration-Lichtfunktion H 1    0    560
IDE05145-ENG116078-Light configuration-Lichtfunktion H 10    0    560
IDE05145-ENG116097-Light configuration-Lichtfunktion H 11    0    560
IDE05145-ENG116116-Light configuration-Lichtfunktion H 12    0    560
IDE05145-ENG116135-Light configuration-Lichtfunktion H 13    0    560
IDE05145-ENG116154-Light configuration-Lichtfunktion H 14    0    560
IDE05145-ENG116173-Light configuration-Lichtfunktion H 15    0    560
IDE05145-ENG116192-Light configuration-Lichtfunktion H 16    0    560
IDE05145-ENG116211-Light configuration-Lichtfunktion H 17    0    560
IDE05145-ENG116230-Light configuration-Lichtfunktion H 18    0    560
IDE05145-ENG116249-Light configuration-Lichtfunktion H 19    0    560
IDE05145-ENG115926-Light configuration-Lichtfunktion H 2    0    560
IDE05145-ENG116268-Light configuration-Lichtfunktion H 20    0    560
IDE05145-ENG116287-Light configuration-Lichtfunktion H 21    0    560
IDE05145-ENG116306-Light configuration-Lichtfunktion H 22    0    560
IDE05145-ENG116325-Light configuration-Lichtfunktion H 23    0    560
IDE05145-ENG116344-Light configuration-Lichtfunktion H 24    0    560
IDE05145-ENG116363-Light configuration-Lichtfunktion H 25    0    560
IDE05145-ENG116382-Light configuration-Lichtfunktion H 26    0    560
IDE05145-ENG116401-Light configuration-Lichtfunktion H 27    0    560
IDE05145-ENG116420-Light configuration-Lichtfunktion H 28    0    560
IDE05145-ENG116439-Light configuration-Lichtfunktion H 29    0    560
IDE05145-ENG115945-Light configuration-Lichtfunktion H 3    0    560
IDE05145-ENG116458-Light configuration-Lichtfunktion H 30    0    560
IDE05145-ENG116477-Light configuration-Lichtfunktion H 31    0    560
IDE05145-ENG116496-Light configuration-Lichtfunktion H 32    0    560
IDE05145-ENG116515-Light configuration-Lichtfunktion H 33    0    560
IDE05145-ENG116534-Light configuration-Lichtfunktion H 34    0    560
IDE05145-ENG115964-Light configuration-Lichtfunktion H 4    0    560
IDE05145-ENG115983-Light configuration-Lichtfunktion H 5    0    560
IDE05145-ENG116002-Light configuration-Lichtfunktion H 6    0    560
IDE05145-ENG116021-Light configuration-Lichtfunktion H 7    0    560
IDE05145-ENG116040-Light configuration-Lichtfunktion H 8    0    560
IDE05145-ENG116059-Light configuration-Lichtfunktion H 9    0    560
IDE05145-ENG154438-Light configuration-Reserved 0    0    560
IDE05145-ENG99841-Light configuration-Reserved 1    0    560
IDE05145-ENG154357-Light configuration-Reserved 10    0    560
IDE05145-ENG154352-Light configuration-Reserved 11    0    560
IDE05145-ENG154182-Light configuration-Reserved 12    0    560
IDE05145-ENG154265-Light configuration-Reserved 13    0    560
IDE05145-ENG154334-Light configuration-Reserved 14    0    560
IDE05145-ENG154340-Light configuration-Reserved 15    0    560
IDE05145-ENG154204-Light configuration-Reserved 16    0    560
IDE05145-ENG154344-Light configuration-Reserved 17    0    560
IDE05145-ENG154195-Light configuration-Reserved 18    0    560
IDE05145-ENG154190-Light configuration-Reserved 19    0    560
IDE05145-ENG99862-Light configuration-Reserved 2    0    560
IDE05145-ENG154300-Light configuration-Reserved 20    0    560
IDE05145-ENG154439-Light configuration-Reserved 21    0    560
IDE05145-ENG154440-Light configuration-Reserved 22    0    560
IDE05145-ENG154441-Light configuration-Reserved 23    0    560
IDE05145-ENG154442-Light configuration-Reserved 24    0    560
IDE05145-ENG154443-Light configuration-Reserved 25    0    560
IDE05145-ENG154444-Light configuration-Reserved 26    0    560
IDE05145-ENG154445-Light configuration-Reserved 27    0    560
IDE05145-ENG154446-Light configuration-Reserved 28    0    560
IDE05145-ENG154447-Light configuration-Reserved 29    0    560
IDE05145-ENG101107-Light configuration-Reserved 3    0    560
IDE05145-ENG154448-Light configuration-Reserved 30    0    560
IDE05145-ENG154449-Light configuration-Reserved 31    0    560
IDE05145-ENG154450-Light configuration-Reserved 32    0    560
IDE05145-ENG154451-Light configuration-Reserved 33    0    560
IDE05145-ENG154452-Light configuration-Reserved 34    0    560
IDE05145-ENG154267-Light configuration-Reserved 4    0    560
IDE05145-ENG154291-Light configuration-Reserved 5    0    560
IDE05145-ENG154239-Light configuration-Reserved 6    0    560
IDE05145-ENG154308-Light configuration-Reserved 7    0    560
IDE05145-ENG154184-Light configuration-Reserved 8    0    560
IDE05145-ENG154255-Light configuration-Reserved 9    0    560
IDE06089-ENG116683-Seat heater level current consumption allocation-Sitzheizung Filterkonstante fuer Waermefluss    1 s    24
IDE06089-ENG116684-Seat heater level current consumption allocation-Sitzheizung Regeltemperaturkorrektur bei Waermefluss    0.00 °C    24
IDE06089-ENG115738-Seat heater level current consumption allocation-Sitzheizung Stufe 1 obere Schaltschwelle    24.50 °C    24
IDE06089-ENG115737-Seat heater level current consumption allocation-Sitzheizung Stufe 1 untere Schaltschwelle    23.50 °C    24
IDE06089-ENG115740-Seat heater level current consumption allocation-Sitzheizung Stufe 2 obere Schaltschwelle    24.50 °C    24
IDE06089-ENG115739-Seat heater level current consumption allocation-Sitzheizung Stufe 2 untere Schaltschwelle    23.50 °C    24
IDE06089-ENG115742-Seat heater level current consumption allocation-Sitzheizung Stufe 3 obere Schaltschwelle    38.00 °C    24
IDE06089-ENG115741-Seat heater level current consumption allocation-Sitzheizung Stufe 3 untere Schaltschwelle    37.00 °C    24
IDE06089-ENG115744-Seat heater level current consumption allocation-Sitzheizung Stufe 4 obere Schaltschwelle    38.00 °C    24
IDE06089-ENG115743-Seat heater level current consumption allocation-Sitzheizung Stufe 4 untere Schaltschwelle    37.00 °C    24
IDE06089-ENG115746-Seat heater level current consumption allocation-Sitzheizung Stufe 5 obere Schaltschwelle    55.50 °C    24
IDE06089-ENG115745-Seat heater level current consumption allocation-Sitzheizung Stufe 5 untere Schaltschwelle    54.50 °C    24
IDE06089-ENG115748-Seat heater level current consumption allocation-Sitzheizung Stufe 6 obere Schaltschwelle    55.50 °C    24
IDE06089-ENG115747-Seat heater level current consumption allocation-Sitzheizung Stufe 6 untere Schaltschwelle    54.50 °C    24
IDE06096-ENG116596-Interior lights-Innenlicht bei offenem Heckdeckel einschalten    active     8
IDE06096-ENG116597-Interior lights-KL30G ohne PWM    not active     8
IDE06096-ENG116598-Interior lights-KL58 Einschalten mit Rampe    not active     8
IDE06096-ENG116599-Interior lights-KL58 Verriegelungsausschalten    not active     8
IDE06096-ENG116600-Interior lights-Lichtsensor wirkt auf Suchbeleuchtung    active     8
IDE06096-ENG115631-Interior lights-Suchbeleuchtung Festwert    100%    8
IDE06425-Dynamometer mode: functional    not active     1
IDE06864-ENG115833-Daytime running lamps-Fahrlicht bei Tag    Daytime running lamps     4
IDE06864-ENG115832-Daytime running lamps-Scheinwerferferreinigungsansteuerung und Abblendlichtanzeige bei Dauerfahrlicht    not active     4
IDE06864-ENG116592-Daytime running lamps-Standlicht aktiviert zusaetzlich Tagfahrlicht    active     4
IDE06864-ENG116594-Daytime running lamps-Tagfahrlicht Aktivierung durch BAP oder Bedienfolge moeglich    active     4
IDE06864-ENG122184-Daytime running lamps-Tagfahrlicht Dauerfahrlicht bei Handbremse abschalten    active     4
IDE06864-ENG115734-Daytime running lamps-Tagfahrlicht nur in Schalterstellung AUTO    not active     4
IDE06864-ENG116593-Daytime running lamps-Tagfahrlicht-Dauerfahrlicht aktiviert zusaetzlich Standlicht    not active     4
IDE06864-ENG115733-Daytime running lamps-Tagfahrlichtkontrollleuchte    not active     4
IDE06864-ENG116591-Daytime running lamps-Werkseinstellung fuer Tagfahrlicht Freischaltung BAP / Bedienfolge    active     4
IDE07356-Position during interval mode    31.49 °    2
IDE07470-ENG116719-After-run for park light-Bedingungen zur Beendigung des Standlichtnachlaufs    abschalten nach der Nachlaufzeit     12
IDE07470-ENG116720-After-run for park light-Standlicht-Nachlaufzeit    30 min    12
IDE08542-IDE02021-Access control 2-Comfort closing    active     8
IDE08542-IDE02022-Access control 2-Comfort opening    active     8
IDE08542-ENG116663-Access control 2-Fahrertuerbedienung Fensterheber oeffnen    active     8
IDE08542-ENG116664-Access control 2-Fahrertuerbedienung Fensterheber schliessen    active     8
IDE08542-ENG116662-Access control 2-FH SAD Kl15Aus Freigabezeit    600 s    8
IDE08542-ENG116648-Access control 2-Freigabenachlauf FH bei Kl 15 aus    active     8
IDE08542-ENG122993-Access control 2-Freigabenachlauf FH bei Tueroeffnen abbrechen    active     8
IDE08542-ENG116652-Access control 2-Funk Komfort oeffnen    active     8
IDE08542-ENG116651-Access control 2-Funk Komfort schliessen    active     8
IDE08542-ENG116658-Access control 2-Funk Spiegelanklappen    not active     8
IDE08542-ENG116665-Access control 2-Funk Spiegelanklappung Modus    by convenience operation via remote control key     8
IDE08542-ENG116653-Access control 2-Kessy Komfort oeffnen    not active     8
IDE08542-ENG116654-Access control 2-Kessy Komfort schliessen    active     8
IDE08542-ENG116655-Access control 2-Kessy Komfortbedienung Reichweitenbegrenzung    not active     8
IDE08542-ENG115670-Access control 2-Komfortbedienung global    active     8
IDE08542-ENG116642-Access control 2-Komfortoeffnen nur FH Fahrertuer    not active     8
IDE08542-ENG116660-Access control 2-Menuesteuerung Funk Spiegel anklappen    not active     8
IDE08542-ENG122994-Access control 2-Menuesteuerung Komfortbedienung einstellbar    adjustable     8
IDE08542-ENG122186-Access control 2-Menuesteuerung Regenschliessen    not active     8
IDE08542-ENG116657-Access control 2-Menuesteuerung Spiegelabsenkung    active     8
IDE08542-ENG116659-Access control 2-Menuesteuerung synchrone Spiegelverstellung    not active     8
IDE08542-ENG125654-Access control 2-Nachsaven_nach_Verdecklauf    not active     8
IDE08542-ENG126841-Access control 2-Profilfunktion fuer Anklappung der Aussenspiegel    active     8
IDE08542-ENG125656-Access control 2-Regenschliessen_art    once     8
IDE08542-ENG125655-Access control 2-Regenschliessen_ein_aus    not active     8
IDE08542-ENG125657-Access control 2-Remote_Unlock_Lock    not active     8
IDE08542-ENG154261-Access control 2-Reserved_4    not active     8
IDE08542-ENG116647-Access control 2-SAD Komfort oeffnen    active     8
IDE08542-ENG116646-Access control 2-SAD Komfort schliessen    active     8
IDE08542-ENG116661-Access control 2-SAD PreCrash Konturschliessen    not active     8
IDE08542-ENG116645-Access control 2-SAD Richtung Komfortoeffnen    tilting     8
IDE08542-ENG116643-Access control 2-Schliesszylinder Komfort oeffnen    not active     8
IDE08542-ENG116644-Access control 2-Schliesszylinder Komfort schliessen    not active     8
IDE08542-ENG126610-Access control 2-Signalisierung_Spiegelanklappung    active     8
IDE08542-ENG116650-Access control 2-Spiegelabsenkung bei Rueckwaertsfahrt    not active     8
IDE08542-ENG116656-Access control 2-Spiegelverstellung Synchron    not active     8
IDE08542-ENG115869-Access control 2-Virtuelles_Pedal    not active     8
IDE08542-ENG126611-Access control 2-virtuelles_pedal_HMI_einstellbar    not active     8
IDE08786-ENG116640-Assistance light functions-AFL Zeitverzoegerung    2000 ms    8
IDE08786-ENG115723-Assistance light functions-Assistenzfahrlicht bei Regen    active     8
IDE08786-ENG130581-Assistance light functions-Fahrlicht_Hinweis_mehrfach    not active     8
IDE08786-ENG126818-Assistance light functions-Fahrlichtwarnung_Hinweis_Konfig    kein_Hinweis     8
IDE08786-ENG116639-Assistance light functions-Fernlichtassistent Reset    active     8
IDE08786-ENG116638-Assistance light functions-Fernlichtassistent Zeitverzoegerungswert    0 ms    8
IDE08786-ENG115724-Assistance light functions-Lichtsensorempfindlichkeit    normal     8
IDE08786-ENG126628-Assistance light functions-LS_Error_Ausgabe    not active     8
IDE08786-ENG116637-Assistance light functions-Menuesteuerung Fernlichtassistent    not installed     8
IDE08786-ENG116641-Assistance light functions-Menuesteuerung Fernlichtassistent Werkseinstellung    present     8
IDE08786-ENG116636-Assistance light functions-Notbremsanzeige NBA    not active     8
IDE08786-ENG126817-Assistance light functions-Umfeldleuchte als Manoevrierleuchte    not active     8
IDE08787-ENG115810-Auxiliary functions-Klemmenfehler auf CAN ausgeben    active     2
IDE08787-ENG101416-Auxiliary functions-Reserved_1    not active     2
IDE08787-ENG99458-Auxiliary functions-Reserved_2    not active     2
IDE08787-ENG115809-Auxiliary functions-Signalhorn ohne KL15    active     2
IDE08787-ENG116672-Auxiliary functions-Spoiler Einfahrunterdrueckung nach manuellem Ausfahren    not active     2
IDE08787-ENG116671-Auxiliary functions-Spoiler Komfortsenken des Spoiler ueber Schliesszylinder FT    not active     2
IDE08788-ENG122212-Dyn. turn signal modes-ABBA_Blinken    not active     4
IDE08788-ENG121966-Dyn. turn signal modes-Crash flashing    not active     4
IDE08788-ENG122207-Dyn. turn signal modes-DWA_Alarm_Blinken    not active     4
IDE08788-ENG122206-Dyn. turn signal modes-DWA_Schaerfungsquittung    not active     4
IDE08788-ENG126819-Dyn. turn signal modes-Emergency_alert_blinken    not active     4
IDE08788-ENG122208-Dyn. turn signal modes-Multi_kollisions_Blinken    not active     4
IDE08788-ENG122209-Dyn. turn signal modes-Notwarn_blinken_NBA_Phase_2    not active     4
IDE08788-ENG121967-Dyn. turn signal modes-Panic flashing    not active     4
IDE08788-ENG122211-Dyn. turn signal modes-Richtungs_blinken_links    not active     4
IDE08788-ENG122210-Dyn. turn signal modes-Richtungs_blinken_rechts    not active     4
IDE08788-ENG122201-Dyn. turn signal modes-Schluessel_Anlern_Blinken    not active     4
IDE08788-ENG121968-Dyn. turn signal modes-Taxi alarm flashing    not active     4
IDE08788-ENG126629-Dyn. turn signal modes-Telematikblinken1_STS_Blinken Telematikblinken2_OCU_Blinken    not active     4
IDE08788-ENG122202-Dyn. turn signal modes-UGDO_ Anlern_Blinken    not active     4
IDE08788-ENG122214-Dyn. turn signal modes-Warnblinken_Zuendung_AUS    not active     4
IDE08788-ENG122213-Dyn. turn signal modes-Warnblinken_Zuendung_EIN    not active     4
IDE08788-ENG122204-Dyn. turn signal modes-ZV_Blinken_auf    not active     4
IDE08788-ENG122203-Dyn. turn signal modes-ZV_Blinken_zu    not active     4
IDE09595-ENG115658-Characteristic curve-x0    0 lx    18
IDE09595-ENG101574-Characteristic curve-X1    2000 lx    18
IDE09595-ENG99557-Characteristic curve-X2    4000 lx    18
IDE09595-ENG102140-Characteristic curve-X3    6000 lx    18
IDE09595-ENG102936-Characteristic curve-X4    8000 lx    18
IDE09595-ENG103548-Characteristic curve-X5    10200 lx    18
IDE09595-ENG148955-Characteristic curve-y1_0    0    18
IDE09595-ENG148956-Characteristic curve-y1_1    40    18
IDE09595-ENG148957-Characteristic curve-y1_2    90    18
IDE09595-ENG148958-Characteristic curve-y1_3    140    18
IDE09595-ENG148959-Characteristic curve-y1_4    190    18
IDE09595-ENG148960-Characteristic curve-y1_5    245    18
IDE09595-ENG148961-Characteristic curve-y2_0    0    18
IDE09595-ENG148962-Characteristic curve-y2_1    60    18
IDE09595-ENG148963-Characteristic curve-y2_2    110    18
IDE09595-ENG148964-Characteristic curve-y2_3    160    18
IDE09595-ENG148965-Characteristic curve-y2_4    210    18
IDE09595-ENG148966-Characteristic curve-y2_5    255    18
IDE09731-ENG125014-Int. light: 2nd generation-Aufloesung Dimmzeit    0.10 s    20
IDE09731-ENG125024-Int. light: 2nd generation-BAP Farbwert Farbe 1    2    20
IDE09731-ENG125025-Int. light: 2nd generation-BAP Farbwert Farbe 2    3    20
IDE09731-ENG125026-Int. light: 2nd generation-BAP Farbwert Farbe 3    1    20
IDE09731-ENG126827-Int. light: 2nd generation-Blauwert Farbe 1    225    20
IDE09731-ENG126830-Int. light: 2nd generation-Blauwert Farbe 2    225    20
IDE09731-ENG126833-Int. light: 2nd generation-Blauwert Farbe 3    225    20
IDE09731-ENG125018-Int. light: 2nd generation-Cockpitbeleuchtung mehrfarbig    not active     20
IDE09731-ENG125021-Int. light: 2nd generation-Dachbeleuchtung mehrfarbig    not active     20
IDE09731-ENG125028-Int. light: 2nd generation-Defaultwert Ambienteprofil Dach    80%    20
IDE09731-ENG125029-Int. light: 2nd generation-Defaultwert Ambienteprofil Farbe    2    20
IDE09731-ENG125027-Int. light: 2nd generation-Defaultwert Ambienteprofil Mittelkonsole    80%    20
IDE09731-ENG125641-Int. light: 2nd generation-Farbausgabe Cockpitbeleuchtung nicht berechnen    active     20
IDE09731-ENG125644-Int. light: 2nd generation-Farbausgabe Dachbeleuchtung nicht berechnen    active     20
IDE09731-ENG125640-Int. light: 2nd generation-Farbausgabe Instrumententafelbeleuchtung nicht berechnen    active     20
IDE09731-ENG125642-Int. light: 2nd generation-Farbausgabe Lautsprecherbeleuchtung nicht berechnen    active     20
IDE09731-ENG125643-Int. light: 2nd generation-Farbausgabe Mittelkonsolenbeleuchtung nicht berechnen    active     20
IDE09731-ENG125645-Int. light: 2nd generation-Farbausgabe Panoramaschiebedachbeleuchtung nicht berechnen    active     20
IDE09731-ENG125639-Int. light: 2nd generation-Farbausgabe Tuertafelbeleuchtung nicht berechnen    not active     20
IDE09731-ENG126826-Int. light: 2nd generation-Gruenwert Farbe 1    225    20
IDE09731-ENG126829-Int. light: 2nd generation-Gruenwert Farbe 2    225    20
IDE09731-ENG126832-Int. light: 2nd generation-Gruenwert Farbe 3    225    20
IDE09731-ENG125634-Int. light: 2nd generation-Helligkeit Cockpitbeleuchtung nicht berechnen    not active     20
IDE09731-ENG125637-Int. light: 2nd generation-Helligkeit Dachbeleuchtung nicht berechnen    active     20
IDE09731-ENG125633-Int. light: 2nd generation-Helligkeit Instrumententafelbeleuchtung nicht berechnen    not active     20
IDE09731-ENG125635-Int. light: 2nd generation-Helligkeit Lautsprecherbeleuchtung nicht berechnen    not active     20
IDE09731-ENG125636-Int. light: 2nd generation-Helligkeit Mittelkonsolenbeleuchtung nicht berechnen    active     20
IDE09731-ENG125638-Int. light: 2nd generation-Helligkeit Panoramaschiebedachbeleuchtung nicht berechnen    active     20
IDE09731-ENG126824-Int. light: 2nd generation-Helligkeit Tuertafelbeleuchtung nicht berechnen    not active     20
IDE09731-ENG125017-Int. light: 2nd generation-Instrumententafelbeleuchtung mehrfarbig    not active     20
IDE09731-ENG125019-Int. light: 2nd generation-Lautsprecherbeleuchtung mehrfarbig    not active     20
IDE09731-ENG125020-Int. light: 2nd generation-Mittelkonsolenbeleuchtung mehrfarbig    not active     20
IDE09731-ENG125023-Int. light: 2nd generation-Panoramaschiebedachbeleuchtung bei geoeffnetem Rollo deaktivieren    not active     20
IDE09731-ENG125022-Int. light: 2nd generation-Panoramaschiebedachbeleuchtung mehrfarbig    not active     20
IDE09731-ENG126825-Int. light: 2nd generation-Rotwert Farbe 1    225    20
IDE09731-ENG126828-Int. light: 2nd generation-Rotwert Farbe 2    225    20
IDE09731-ENG126831-Int. light: 2nd generation-Rotwert Farbe 3    225    20
IDE09731-ENG125016-Int. light: 2nd generation-Tuertafelbeleuchtung mehrfarbig    active     20
IDE09731-ENG125015-Int. light: 2nd generation-weicher Farbwechsel    not active     20
IDE09732-ENG115870-Interior light: light configuration-Ambiente_Applikationsleisten_in_Instrumententafel    not installed     2
IDE09732-ENG115871-Interior light: light configuration-Ambiente_Applikationsleisten_in_Tuertafel    installed     2
IDE09732-ENG115872-Interior light: light configuration-Ambiente_Lautsprecher    not installed     2
IDE09732-ENG126836-Interior light: light configuration-Ambientemenue mit alle Zonen    not active     2
IDE09732-ENG126835-Interior light: light configuration-Ambientemenue mit globalem aus    not active     2
IDE09732-ENG125646-Interior light: light configuration-Cockpitbeleuchtung    not installed     2
IDE09732-ENG125648-Interior light: light configuration-Dachbeleuchtung    not installed     2
IDE09732-ENG125651-Interior light: light configuration-Farbwahl ueber Fahrprofil    not installed     2
IDE09732-ENG125650-Interior light: light configuration-Farbwahl ueber HMI    not installed     2
IDE09732-ENG114629-Interior light: light configuration-Footwell lighting    installed     2
IDE09732-ENG126834-Interior light: light configuration-LIN-Dachkonsole lokal aktivierbar    not active     2
IDE09732-ENG125647-Interior light: light configuration-Mittelkonsolenbeleuchtung    not installed     2
IDE09732-ENG125649-Interior light: light configuration-Panoramaschiebedachbeleuchtung    not installed     2
IDE09733-ENG147407-LED bar setting values-Filterzeit Anpassung    3000 ms    10
IDE09733-ENG147406-LED bar setting values-Filterzeit Umgebungshelligkeit    1000 ms    10
IDE09733-ENG147405-LED bar setting values-Lockout time    0 s    10
IDE09733-ENG148967-LED bar setting values-Maximale Dauer fuer konstante Anzeige    0 s    10
IDE09733-ENG148968-LED bar setting values-Maximale Helligkeitsdifferenz    25    10
IDE09733-ENG148971-LED bar setting values-Schwellwert Plausibilisierung Kombi-Fototransistor    0    10
IDE09733-ENG148969-LED bar setting values-Schwellwert Plausibilisierung RLS    393210 lx    10
IDE09733-ENG148970-LED bar setting values-Schwellwert Plausibilisierung SLS    393210 lx    10
IDE09761-ENG126617-Seat fan charac. curve-Level_1_Lehne    30%    12
IDE09761-ENG126616-Seat fan charac. curve-Level_1_Sitz    25%    12
IDE09761-ENG126619-Seat fan charac. curve-Level_2_Lehne    30%    12
IDE09761-ENG126618-Seat fan charac. curve-Level_2_Sitz    25%    12
IDE09761-ENG126621-Seat fan charac. curve-Level_3_Lehne    58%    12
IDE09761-ENG126620-Seat fan charac. curve-Level_3_Sitz    53%    12
IDE09761-ENG126623-Seat fan charac. curve-Level_4_Lehne    58%    12
IDE09761-ENG126622-Seat fan charac. curve-Level_4_Sitz    53%    12
IDE09761-ENG126625-Seat fan charac. curve-Level_5_Lehne    85%    12
IDE09761-ENG126624-Seat fan charac. curve-Level_5_Sitz    80%    12
IDE09761-ENG126627-Seat fan charac. curve-Level_6_Lehne    85%    12
IDE09761-ENG126626-Seat fan charac. curve-Level_6_Sitz    80%    12
IDE10298-Alternating park position 1    7.49 °    2
IDE10299-Alternating park position 2    29.49 °    2
MAS01490-Energy management    active     1
MAS05055-lower turn position    31.49 °    2
MAS05056-upper turn position    170.49 °    2
MAS05934-ENG116716-Convert. top oper.-Doppelpuls nur Verdeck    active     8
MAS05934-ENG116718-Convert. top oper.-Heckdeckel sperren bei Verdeckbetrieb    not active     8
MAS05934-ENG122193-Convert. top oper.-Heckschloss oeffnen durch Verdeck-SG    not active     8
MAS05934-ENG116711-Convert. top oper.-Komfortbedienung Verdeck global    active     8
MAS05934-ENG122189-Convert. top oper.-Komfortbedienung Verdeck oeffnen    active     8
MAS05934-ENG116712-Convert. top oper.-Komfortbedienung Verdeck schließen    active     8
MAS05934-ENG126630-Convert. top oper.-Reichweitenbegrenzung fuer Servoheck schliessen    not active     8
MAS05934-ENG116717-Convert. top oper.-Verdeck mit Schiebedach    not active     8
MAS05934-ENG122191-Convert. top oper.-Verdeck oeffnen via Funkfernbedienung    active     8
MAS05934-ENG122192-Convert. top oper.-Verdeck oeffnen via Kessy    active     8
MAS05934-ENG122190-Convert. top oper.-Verdeck oeffnen via Schliesszylinder    active     8
MAS05934-ENG116714-Convert. top oper.-Verdeck schließen via Funkfernbedienung    active     8
MAS05934-ENG116715-Convert. top oper.-Verdeck schließen via Kessy    active     8
MAS05934-ENG116713-Convert. top oper.-Verdeck schließen via Schließzylinder    active     8
MAS05934-ENG126843-Convert. top oper.-ZV verriegeln bei Klemme 15 Ein    not active     8
ENG126649-ENG126874-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_1    1    30
ENG126649-ENG126901-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_10    1    30
ENG126649-ENG126904-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_11    1    30
ENG126649-ENG126907-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_12    1    30
ENG126649-ENG126910-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_13    1    30
ENG126649-ENG126913-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_14    1    30
ENG126649-ENG126916-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_15    1    30
ENG126649-ENG126877-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_2    1    30
ENG126649-ENG126880-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_3    1    30
ENG126649-ENG126883-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_4    1    30
ENG126649-ENG126886-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_5    1    30
ENG126649-ENG126889-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_6    1    30
ENG126649-ENG126892-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_7    1    30
ENG126649-ENG126895-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_8    1    30
ENG126649-ENG126898-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_9    1    30
ENG126649-ENG126873-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_1    door     30
ENG126649-ENG126900-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_10    door     30
ENG126649-ENG126903-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_11    door     30
ENG126649-ENG126906-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_12    door     30
ENG126649-ENG126909-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_13    door     30
ENG126649-ENG126912-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_14    door     30
ENG126649-ENG126915-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_15    door     30
ENG126649-ENG126876-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_2    door     30
ENG126649-ENG126879-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_3    door     30
ENG126649-ENG126882-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_4    door     30
ENG126649-ENG126885-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_5    door     30
ENG126649-ENG126888-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_6    door     30
ENG126649-ENG126891-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_7    door     30
ENG126649-ENG126894-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_8    door     30
ENG126649-ENG126897-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_9    door     30
ENG126649-ENG126872-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_1    not installed     30
ENG126649-ENG126899-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_10    not installed     30
ENG126649-ENG126902-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_11    not installed     30
ENG126649-ENG126905-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_12    not installed     30
ENG126649-ENG126908-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_13    not installed     30
ENG126649-ENG126911-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_14    not installed     30
ENG126649-ENG126914-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_15    not installed     30
ENG126649-ENG126875-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_2    not installed     30
ENG126649-ENG126878-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_3    not installed     30
ENG126649-ENG126881-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_4    not installed     30
ENG126649-ENG126884-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_5    not installed     30
ENG126649-ENG126887-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_6    not installed     30
ENG126649-ENG126890-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_7    not installed     30
ENG126649-ENG126893-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_8    not installed     30
ENG126649-ENG126896-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_9    not installed     30
ENG128379-ENG128424-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_:12    0    60
ENG128379-ENG128391-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_1    0    60
ENG128379-ENG128418-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_10    0    60
ENG128379-ENG128421-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_11    0    60
ENG128379-ENG128427-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_13    0    60
ENG128379-ENG128430-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_14    0    60
ENG128379-ENG128433-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_15    0    60
ENG128379-ENG128436-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_16    0    60
ENG128379-ENG128439-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_17    0    60
ENG128379-ENG128442-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_18    0    60
ENG128379-ENG128445-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_19    0    60
ENG128379-ENG128394-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_2    0    60
ENG128379-ENG128448-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_20    0    60
ENG128379-ENG128397-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_3    0    60
ENG128379-ENG128400-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_4    0    60
ENG128379-ENG128403-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_5    0    60
ENG128379-ENG128406-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_6    0    60
ENG128379-ENG128409-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_7    0    60
ENG128379-ENG128412-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_8    0    60
ENG128379-ENG128415-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_9    0    60
ENG128379-ENG128393-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_1    0    60
ENG128379-ENG128420-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_10    0    60
ENG128379-ENG128423-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_11    0    60
ENG128379-ENG128426-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_12    0    60
ENG128379-ENG128429-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_13    0    60
ENG128379-ENG128432-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_14    0    60
ENG128379-ENG128435-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_15    0    60
ENG128379-ENG128438-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_16    0    60
ENG128379-ENG128441-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_17    0    60
ENG128379-ENG128444-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_18    0    60
ENG128379-ENG128447-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_19    0    60
ENG128379-ENG128396-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_2    0    60
ENG128379-ENG128450-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_20    0    60
ENG128379-ENG128399-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_3    0    60
ENG128379-ENG128402-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_4    0    60
ENG128379-ENG128405-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_5    0    60
ENG128379-ENG128408-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_6    0    60
ENG128379-ENG128411-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_7    0    60
ENG128379-ENG128417-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_9    0    60
ENG128379-ENG128414-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave8    0    60
ENG128379-ENG128392-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_1    not installed     60
ENG128379-ENG128419-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_10    not installed     60
ENG128379-ENG128422-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_11    not installed     60
ENG128379-ENG128425-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_12    not installed     60
ENG128379-ENG128428-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_13    not installed     60
ENG128379-ENG128431-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_14    not installed     60
ENG128379-ENG128434-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_15    not installed     60
ENG128379-ENG128437-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_16    not installed     60
ENG128379-ENG128440-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_17    not installed     60
ENG128379-ENG128443-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_18    not installed     60
ENG128379-ENG128446-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_19    not installed     60
ENG128379-ENG128395-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_2    not installed     60
ENG128379-ENG128449-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_20    not installed     60
ENG128379-ENG128398-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_3    not installed     60
ENG128379-ENG128401-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_4    not installed     60
ENG128379-ENG128404-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_5    not installed     60
ENG128379-ENG128407-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_6    not installed     60
ENG128379-ENG128410-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_7    not installed     60
ENG128379-ENG128416-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_9    not installed     60
ENG128379-ENG128413-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave8    not installed     60
ENG126647-ENG98399-debug_light_function-Activation    0    11
ENG126647-ENG101417-debug_light_function-Adresse    0    11
ENG126647-ENG126820-debug_light_function-Bitmask    0    11
ENG126647-ENG126821-debug_light_function-Divisor    0    11
ENG126647-ENG98827-debug_light_function-Offset    0    11
ENG126647-ENG126822-debug_light_function-Polaritaet    0    11
ENG126647-ENG126823-debug_light_function-WBT-Ausgabe    0    11
ENG99457-ENG117394-Head area heater-blower_speed    1    2
ENG99457-ENG98971-Head area heater-Temperature    -2    2
ENG116836-ENG115658-Innenbeleuchtung Abdimmen-x0    0 ms    22
ENG116836-ENG101574-Innenbeleuchtung Abdimmen-X1    200 ms    22
ENG116836-ENG115664-Innenbeleuchtung Abdimmen-x10    2000 ms    22
ENG116836-ENG99557-Innenbeleuchtung Abdimmen-X2    400 ms    22
ENG116836-ENG102140-Innenbeleuchtung Abdimmen-X3    600 ms    22
ENG116836-ENG102936-Innenbeleuchtung Abdimmen-X4    800 ms    22
ENG116836-ENG103548-Innenbeleuchtung Abdimmen-X5    1000 ms    22
ENG116836-ENG113992-Innenbeleuchtung Abdimmen-X6    1200 ms    22
ENG116836-ENG115661-Innenbeleuchtung Abdimmen-x7    1400 ms    22
ENG116836-ENG115662-Innenbeleuchtung Abdimmen-x8    1600 ms    22
ENG116836-ENG115663-Innenbeleuchtung Abdimmen-x9    1800 ms    22
ENG116836-ENG115659-Innenbeleuchtung Abdimmen-y0    100.00%    22
ENG116836-ENG99777-Innenbeleuchtung Abdimmen-Y1    72.00%    22
ENG116836-ENG115668-Innenbeleuchtung Abdimmen-y10    0.00%    22
ENG116836-ENG100480-Innenbeleuchtung Abdimmen-Y2    48.00%    22
ENG116836-ENG100773-Innenbeleuchtung Abdimmen-Y3    33.00%    22
ENG116836-ENG100631-Innenbeleuchtung Abdimmen-Y4    18.00%    22
ENG116836-ENG102174-Innenbeleuchtung Abdimmen-Y5    12.00%    22
ENG116836-ENG113993-Innenbeleuchtung Abdimmen-Y6    8.00%    22
ENG116836-ENG115665-Innenbeleuchtung Abdimmen-y7    6.00%    22
ENG116836-ENG115666-Innenbeleuchtung Abdimmen-y8    4.00%    22
ENG116836-ENG115667-Innenbeleuchtung Abdimmen-y9    2.00%    22
ENG116831-ENG115658-Innenbeleuchtung Fotosensor-x0    0    22
ENG116831-ENG101574-Innenbeleuchtung Fotosensor-X1    50    22
ENG116831-ENG115664-Innenbeleuchtung Fotosensor-x10    0    22
ENG116831-ENG99557-Innenbeleuchtung Fotosensor-X2    100    22
ENG116831-ENG102140-Innenbeleuchtung Fotosensor-X3    200    22
ENG116831-ENG102936-Innenbeleuchtung Fotosensor-X4    253    22
ENG116831-ENG103548-Innenbeleuchtung Fotosensor-X5    0    22
ENG116831-ENG113992-Innenbeleuchtung Fotosensor-X6    0    22
ENG116831-ENG115661-Innenbeleuchtung Fotosensor-x7    0    22
ENG116831-ENG115662-Innenbeleuchtung Fotosensor-x8    0    22
ENG116831-ENG115663-Innenbeleuchtung Fotosensor-x9    0    22
ENG116831-ENG115659-Innenbeleuchtung Fotosensor-y0    0 lx    22
ENG116831-ENG99777-Innenbeleuchtung Fotosensor-Y1    50 lx    22
ENG116831-ENG115668-Innenbeleuchtung Fotosensor-y10    0 lx    22
ENG116831-ENG100480-Innenbeleuchtung Fotosensor-Y2    100 lx    22
ENG116831-ENG100773-Innenbeleuchtung Fotosensor-Y3    200    22
ENG116831-ENG100631-Innenbeleuchtung Fotosensor-Y4    500    22
ENG116831-ENG102174-Innenbeleuchtung Fotosensor-Y5    0    22
ENG116831-ENG113993-Innenbeleuchtung Fotosensor-Y6    0 lx    22
ENG116831-ENG115665-Innenbeleuchtung Fotosensor-y7    0 lx    22
ENG116831-ENG115666-Innenbeleuchtung Fotosensor-y8    0 lx    22
ENG116831-ENG115667-Innenbeleuchtung Fotosensor-y9    0 lx    22
ENG116835-ENG115658-Innenbeleuchtung Hochdimmen-x0    0 ms    22
ENG116835-ENG101574-Innenbeleuchtung Hochdimmen-X1    200 ms    22
ENG116835-ENG115664-Innenbeleuchtung Hochdimmen-x10    2000 ms    22
ENG116835-ENG99557-Innenbeleuchtung Hochdimmen-X2    400 ms    22
ENG116835-ENG102140-Innenbeleuchtung Hochdimmen-X3    600 ms    22
ENG116835-ENG102936-Innenbeleuchtung Hochdimmen-X4    800 ms    22
ENG116835-ENG103548-Innenbeleuchtung Hochdimmen-X5    1000 ms    22
ENG116835-ENG113992-Innenbeleuchtung Hochdimmen-X6    1200 ms    22
ENG116835-ENG115661-Innenbeleuchtung Hochdimmen-x7    1400 ms    22
ENG116835-ENG115662-Innenbeleuchtung Hochdimmen-x8    1600 ms    22
ENG116835-ENG115663-Innenbeleuchtung Hochdimmen-x9    1800 ms    22
ENG116835-ENG115659-Innenbeleuchtung Hochdimmen-y0    0.00%    22
ENG116835-ENG99777-Innenbeleuchtung Hochdimmen-Y1    1.00%    22
ENG116835-ENG115668-Innenbeleuchtung Hochdimmen-y10    100.00%    22
ENG116835-ENG100480-Innenbeleuchtung Hochdimmen-Y2    3.00%    22
ENG116835-ENG100773-Innenbeleuchtung Hochdimmen-Y3    5.00%    22
ENG116835-ENG100631-Innenbeleuchtung Hochdimmen-Y4    11.00%    22
ENG116835-ENG102174-Innenbeleuchtung Hochdimmen-Y5    22.00%    22
ENG116835-ENG113993-Innenbeleuchtung Hochdimmen-Y6    40.00%    22
ENG116835-ENG115665-Innenbeleuchtung Hochdimmen-y7    80.00%    22
ENG116835-ENG115666-Innenbeleuchtung Hochdimmen-y8    95.00%    22
ENG116835-ENG115667-Innenbeleuchtung Hochdimmen-y9    100.00%    22
ENG116975-ENG115658-Innenbeleuchtung KL 58xd log Bus-x0    0.00%    12
ENG116975-ENG101574-Innenbeleuchtung KL 58xd log Bus-X1    6.00%    12
ENG116975-ENG99557-Innenbeleuchtung KL 58xd log Bus-X2    16.00%    12
ENG116975-ENG102140-Innenbeleuchtung KL 58xd log Bus-X3    30.00%    12
ENG116975-ENG102936-Innenbeleuchtung KL 58xd log Bus-X4    60.00%    12
ENG116975-ENG103548-Innenbeleuchtung KL 58xd log Bus-X5    100.00%    12
ENG116975-ENG115659-Innenbeleuchtung KL 58xd log Bus-y0    10    12
ENG116975-ENG99777-Innenbeleuchtung KL 58xd log Bus-Y1    10    12
ENG116975-ENG100480-Innenbeleuchtung KL 58xd log Bus-Y2    100    12
ENG116975-ENG100773-Innenbeleuchtung KL 58xd log Bus-Y3    150    12
ENG116975-ENG100631-Innenbeleuchtung KL 58xd log Bus-Y4    220    12
ENG116975-ENG102174-Innenbeleuchtung KL 58xd log Bus-Y5    253    12
ENG116976-ENG115658-Innenbeleuchtung KL 58xd max-x0    0 lx    10
ENG116976-ENG101574-Innenbeleuchtung KL 58xd max-X1    8 lx    10
ENG116976-ENG99557-Innenbeleuchtung KL 58xd max-X2    200 lx    10
ENG116976-ENG102140-Innenbeleuchtung KL 58xd max-X3    300 lx    10
ENG116976-ENG102936-Innenbeleuchtung KL 58xd max-X4    500 lx    10
ENG116976-ENG115659-Innenbeleuchtung KL 58xd max-y0    16    10
ENG116976-ENG99777-Innenbeleuchtung KL 58xd max-Y1    16    10
ENG116976-ENG100480-Innenbeleuchtung KL 58xd max-Y2    100    10
ENG116976-ENG100773-Innenbeleuchtung KL 58xd max-Y3    100    10
ENG116976-ENG100631-Innenbeleuchtung KL 58xd max-Y4    100    10
ENG116980-ENG115658-Innenbeleuchtung KL 58xd min-x0    0 lx    10
ENG116980-ENG101574-Innenbeleuchtung KL 58xd min-X1    8 lx    10
ENG116980-ENG99557-Innenbeleuchtung KL 58xd min-X2    220 lx    10
ENG116980-ENG102140-Innenbeleuchtung KL 58xd min-X3    300 lx    10
ENG116980-ENG102936-Innenbeleuchtung KL 58xd min-X4    500 lx    10
ENG116980-ENG115659-Innenbeleuchtung KL 58xd min-y0    6    10
ENG116980-ENG99777-Innenbeleuchtung KL 58xd min-Y1    6    10
ENG116980-ENG100480-Innenbeleuchtung KL 58xd min-Y2    100    10
ENG116980-ENG100773-Innenbeleuchtung KL 58xd min-Y3    100    10
ENG116980-ENG100631-Innenbeleuchtung KL 58xd min-Y4    100    10
ENG116979-ENG115658-Innenbeleuchtung KL 58xd PWM-x0    0    12
ENG116979-ENG101574-Innenbeleuchtung KL 58xd PWM-X1    10    12
ENG116979-ENG99557-Innenbeleuchtung KL 58xd PWM-X2    50    12
ENG116979-ENG102140-Innenbeleuchtung KL 58xd PWM-X3    100    12
ENG116979-ENG102936-Innenbeleuchtung KL 58xd PWM-X4    220    12
ENG116979-ENG103548-Innenbeleuchtung KL 58xd PWM-X5    253    12
ENG116979-ENG115659-Innenbeleuchtung KL 58xd PWM-y0    2.00%    12
ENG116979-ENG99777-Innenbeleuchtung KL 58xd PWM-Y1    2.00%    12
ENG116979-ENG100480-Innenbeleuchtung KL 58xd PWM-Y2    6.00%    12
ENG116979-ENG100773-Innenbeleuchtung KL 58xd PWM-Y3    10.00%    12
ENG116979-ENG100631-Innenbeleuchtung KL 58xd PWM-Y4    80.00%    12
ENG116979-ENG102174-Innenbeleuchtung KL 58xd PWM-Y5    100.00%    12
ENG116972-ENG115658-Innenbeleuchtung KL 58xs max-x0    0 lx    8
ENG116972-ENG101574-Innenbeleuchtung KL 58xs max-X1    8 lx    8
ENG116972-ENG99557-Innenbeleuchtung KL 58xs max-X2    50 lx    8
ENG116972-ENG102140-Innenbeleuchtung KL 58xs max-X3    500 lx    8
ENG116972-ENG115659-Innenbeleuchtung KL 58xs max-y0    100    8
ENG116972-ENG99777-Innenbeleuchtung KL 58xs max-Y1    100    8
ENG116972-ENG100480-Innenbeleuchtung KL 58xs max-Y2    100    8
ENG116972-ENG100773-Innenbeleuchtung KL 58xs max-Y3    100    8
ENG126561-ENG115658-Innenbeleuchtung KL 58xs min-x0    0 lx    8
ENG126561-ENG101574-Innenbeleuchtung KL 58xs min-X1    8 lx    8
ENG126561-ENG99557-Innenbeleuchtung KL 58xs min-X2    50 lx    8
ENG126561-ENG102140-Innenbeleuchtung KL 58xs min-X3    500 lx    8
ENG126561-ENG115659-Innenbeleuchtung KL 58xs min-y0    6    8
ENG126561-ENG99777-Innenbeleuchtung KL 58xs min-Y1    6    8
ENG126561-ENG100480-Innenbeleuchtung KL 58xs min-Y2    100    8
ENG126561-ENG100773-Innenbeleuchtung KL 58xs min-Y3    100    8
ENG116977-ENG115658-Innenbeleuchtung KL 58xs PWM-x0    0.00%    6
ENG116977-ENG101574-Innenbeleuchtung KL 58xs PWM-X1    50.00%    6
ENG116977-ENG99557-Innenbeleuchtung KL 58xs PWM-X2    100.00%    6
ENG116977-ENG115659-Innenbeleuchtung KL 58xs PWM-y0    0.00%    6
ENG116977-ENG99777-Innenbeleuchtung KL 58xs PWM-Y1    50.00%    6
ENG116977-ENG100480-Innenbeleuchtung KL 58xs PWM-Y2    100.00%    6
ENG116974-ENG115658-Innenbeleuchtung KL 58xt max-x0    0 lx    8
ENG116974-ENG101574-Innenbeleuchtung KL 58xt max-X1    8 lx    8
ENG116974-ENG99557-Innenbeleuchtung KL 58xt max-X2    50 lx    8
ENG116974-ENG102140-Innenbeleuchtung KL 58xt max-X3    500 lx    8
ENG116974-ENG115659-Innenbeleuchtung KL 58xt max-y0    100    8
ENG116974-ENG99777-Innenbeleuchtung KL 58xt max-Y1    100    8
ENG116974-ENG100480-Innenbeleuchtung KL 58xt max-Y2    100    8
ENG116974-ENG100773-Innenbeleuchtung KL 58xt max-Y3    100    8
ENG116973-ENG115658-Innenbeleuchtung KL 58xt min-x0    0 lx    8
ENG116973-ENG101574-Innenbeleuchtung KL 58xt min-X1    8 lx    8
ENG116973-ENG99557-Innenbeleuchtung KL 58xt min-X2    50 lx    8
ENG116973-ENG102140-Innenbeleuchtung KL 58xt min-X3    500 lx    8
ENG116973-ENG115659-Innenbeleuchtung KL 58xt min-y0    6    8
ENG116973-ENG99777-Innenbeleuchtung KL 58xt min-Y1    6    8
ENG116973-ENG100480-Innenbeleuchtung KL 58xt min-Y2    100    8
ENG116973-ENG100773-Innenbeleuchtung KL 58xt min-Y3    100    8
ENG116978-ENG115658-Innenbeleuchtung KL 58xt PWM-x0    0.00%    6
ENG116978-ENG101574-Innenbeleuchtung KL 58xt PWM-X1    50.00%    6
ENG116978-ENG99557-Innenbeleuchtung KL 58xt PWM-X2    100.00%    6
ENG116978-ENG115659-Innenbeleuchtung KL 58xt PWM-y0    0.00%    6
ENG116978-ENG99777-Innenbeleuchtung KL 58xt PWM-Y1    50.00%    6
ENG116978-ENG100480-Innenbeleuchtung KL 58xt PWM-Y2    100.00%    6
ENG116834-ENG115633-Innenbeleuchtung Tasterdimmung-Tasterdimmung x0    0 ms    10
ENG116834-ENG115634-Innenbeleuchtung Tasterdimmung-Tasterdimmung x1    100 ms    10
ENG116834-ENG115635-Innenbeleuchtung Tasterdimmung-Tasterdimmung x2    160 ms    10
ENG116834-ENG115636-Innenbeleuchtung Tasterdimmung-Tasterdimmung x3    200 ms    10
ENG116834-ENG115637-Innenbeleuchtung Tasterdimmung-Tasterdimmung x4    260 ms    10
ENG116834-ENG115638-Innenbeleuchtung Tasterdimmung-Tasterdimmung y0    1.00%    10
ENG116834-ENG115639-Innenbeleuchtung Tasterdimmung-Tasterdimmung y1    5    10
ENG116834-ENG115640-Innenbeleuchtung Tasterdimmung-Tasterdimmung y2    15    10
ENG116834-ENG115641-Innenbeleuchtung Tasterdimmung-Tasterdimmung y3    10    10
ENG116834-ENG115642-Innenbeleuchtung Tasterdimmung-Tasterdimmung y4    100    10
ENG116936-ENG115883-Leuchte 0 BLK VL B36-Dimming Direction CD 0    maximize     16
ENG116936-ENG115887-Leuchte 0 BLK VL B36-Dimming Direction EF 0    maximize     16
ENG116936-ENG115891-Leuchte 0 BLK VL B36-Dimming Direction GH 0    maximize     16
ENG116936-ENG115878-Leuchte 0 BLK VL B36-Dimmwert AB 0    100    16
ENG116936-ENG115882-Leuchte 0 BLK VL B36-Dimmwert CD 0    0    16
ENG116936-ENG115886-Leuchte 0 BLK VL B36-Dimmwert EF 0    0    16
ENG116936-ENG115890-Leuchte 0 BLK VL B36-Dimmwert GH 0    0    16
ENG116936-ENG115875-Leuchte 0 BLK VL B36-Fehlerort mittleres Byte DTC-DFCC 0    14    16
ENG116936-ENG116547-Leuchte 0 BLK VL B36-Lampendefektbit Position 0    34    16
ENG116936-ENG115873-Leuchte 0 BLK VL B36-Lasttyp 0    12 - Blinkleuchten     16
ENG116936-ENG115879-Leuchte 0 BLK VL B36-Lichtansteuerung HD AB 0    Always     16
ENG116936-ENG115876-Leuchte 0 BLK VL B36-Lichtfunktion A 0    Blinken links Hellphase     16
ENG116936-ENG115877-Leuchte 0 BLK VL B36-Lichtfunktion B 0    not active     16
ENG116936-ENG115880-Leuchte 0 BLK VL B36-Lichtfunktion C 0    not active     16
ENG116936-ENG115881-Leuchte 0 BLK VL B36-Lichtfunktion D 0    not active     16
ENG116936-ENG115884-Leuchte 0 BLK VL B36-Lichtfunktion E 0    not active     16
ENG116936-ENG115885-Leuchte 0 BLK VL B36-Lichtfunktion F 0    not active     16
ENG116936-ENG115888-Leuchte 0 BLK VL B36-Lichtfunktion G 0    not active     16
ENG116936-ENG115889-Leuchte 0 BLK VL B36-Lichtfunktion H 0    not active     16
ENG116946-ENG116072-Leuchte10SHUTTER LB23-Dimming Direction CD 10    maximize     16
ENG116946-ENG116076-Leuchte10SHUTTER LB23-Dimming Direction EF 10    maximize     16
ENG116946-ENG116080-Leuchte10SHUTTER LB23-Dimming Direction GH 10    maximize     16
ENG116946-ENG116067-Leuchte10SHUTTER LB23-Dimmwert AB 10    127    16
ENG116946-ENG116071-Leuchte10SHUTTER LB23-Dimmwert CD 10    0    16
ENG116946-ENG116075-Leuchte10SHUTTER LB23-Dimmwert EF 10    0    16
ENG116946-ENG116079-Leuchte10SHUTTER LB23-Dimmwert GH 10    0    16
ENG116946-ENG116064-Leuchte10SHUTTER LB23-Fehlerort mittleres Byte DTC-DFCC 10    1E     16
ENG116946-ENG116560-Leuchte10SHUTTER LB23-Lampendefektbitposition 10    37    16
ENG116946-ENG116062-Leuchte10SHUTTER LB23-Lasttyp 10    2 - Shutter: Diagnosesensierung für 'LED low'     16
ENG116946-ENG116068-Leuchte10SHUTTER LB23-Lichtansteuerung HD AB 10    Always     16
ENG116946-ENG116065-Leuchte10SHUTTER LB23-Lichtfunktion A 10    Left high beam     16
ENG116946-ENG116066-Leuchte10SHUTTER LB23-Lichtfunktion B 10    Lichthupe generell     16
ENG116946-ENG116069-Leuchte10SHUTTER LB23-Lichtfunktion C 10    not active     16
ENG116946-ENG116070-Leuchte10SHUTTER LB23-Lichtfunktion D 10    not active     16
ENG116946-ENG116073-Leuchte10SHUTTER LB23-Lichtfunktion E 10    not active     16
ENG116946-ENG116074-Leuchte10SHUTTER LB23-Lichtfunktion F 10    not active     16
ENG116946-ENG116077-Leuchte10SHUTTER LB23-Lichtfunktion G 10    not active     16
ENG116946-ENG116078-Leuchte10SHUTTER LB23-Lichtfunktion H 10    not active     16
ENG116947-ENG116091-Leuchte11SHUTTER RB22-Dimming Direction CD 11    maximize     16
ENG116947-ENG116095-Leuchte11SHUTTER RB22-Dimming Direction EF 11    maximize     16
ENG116947-ENG116099-Leuchte11SHUTTER RB22-Dimming Direction GH 11    maximize     16
ENG116947-ENG116086-Leuchte11SHUTTER RB22-Dimmwert AB 11    127    16
ENG116947-ENG116090-Leuchte11SHUTTER RB22-Dimmwert CD 11    0    16
ENG116947-ENG116094-Leuchte11SHUTTER RB22-Dimmwert EF 11    0    16
ENG116947-ENG116098-Leuchte11SHUTTER RB22-Dimmwert GH 11    0    16
ENG116947-ENG116083-Leuchte11SHUTTER RB22-Fehlerort mittleres Byte DTC-DFCC 11    1F     16
ENG116947-ENG116561-Leuchte11SHUTTER RB22-Lampendefektbitposition 11    41    16
ENG116947-ENG116081-Leuchte11SHUTTER RB22-Lasttyp 11    2 - Shutter: Diagnosesensierung für 'LED low'     16
ENG116947-ENG116087-Leuchte11SHUTTER RB22-Lichtansteuerung HD AB 11    Always     16
ENG116947-ENG116084-Leuchte11SHUTTER RB22-Lichtfunktion A 11    Right high beam     16
ENG116947-ENG116085-Leuchte11SHUTTER RB22-Lichtfunktion B 11    Lichthupe generell     16
ENG116947-ENG116088-Leuchte11SHUTTER RB22-Lichtfunktion C 11    not active     16
ENG116947-ENG116089-Leuchte11SHUTTER RB22-Lichtfunktion D 11    not active     16
ENG116947-ENG116092-Leuchte11SHUTTER RB22-Lichtfunktion E 11    not active     16
ENG116947-ENG116093-Leuchte11SHUTTER RB22-Lichtfunktion F 11    not active     16
ENG116947-ENG116096-Leuchte11SHUTTER RB22-Lichtfunktion G 11    not active     16
ENG116947-ENG116097-Leuchte11SHUTTER RB22-Lichtfunktion H 11    not active     16
ENG116948-ENG116110-Leuchte12NL LB45-Dimming Direction CD 12    maximize     16
ENG116948-ENG116114-Leuchte12NL LB45-Dimming Direction EF 12    maximize     16
ENG116948-ENG116118-Leuchte12NL LB45-Dimming Direction GH 12    maximize     16
ENG116948-ENG116105-Leuchte12NL LB45-Dimmwert AB 12    100    16
ENG116948-ENG116109-Leuchte12NL LB45-Dimmwert CD 12    0    16
ENG116948-ENG116113-Leuchte12NL LB45-Dimmwert EF 12    0    16
ENG116948-ENG116117-Leuchte12NL LB45-Dimmwert GH 12    0    16
ENG116948-ENG116102-Leuchte12NL LB45-Fehlerort mittleres Byte DTC-DFCC 12    22    16
ENG116948-ENG116562-Leuchte12NL LB45-Lampendefektbitposition 12    38    16
ENG116948-ENG116100-Leuchte12NL LB45-Lasttyp 12    10 - allgemeine Scheinwerfer     16
ENG116948-ENG116106-Leuchte12NL LB45-Lichtansteuerung HD AB 12    Always     16
ENG116948-ENG116103-Leuchte12NL LB45-Lichtfunktion A 12    Nebellicht links     16
ENG116948-ENG116104-Leuchte12NL LB45-Lichtfunktion B 12    not active     16
ENG116948-ENG116107-Leuchte12NL LB45-Lichtfunktion C 12    not active     16
ENG116948-ENG116108-Leuchte12NL LB45-Lichtfunktion D 12    not active     16
ENG116948-ENG116111-Leuchte12NL LB45-Lichtfunktion E 12    not active     16
ENG116948-ENG116112-Leuchte12NL LB45-Lichtfunktion F 12    not active     16
ENG116948-ENG116115-Leuchte12NL LB45-Lichtfunktion G 12    not active     16
ENG116948-ENG116116-Leuchte12NL LB45-Lichtfunktion H 12    not active     16
ENG116949-ENG116129-Leuchte13NL RB5-Dimming Direction CD 13    maximize     16
ENG116949-ENG116133-Leuchte13NL RB5-Dimming Direction EF 13    maximize     16
ENG116949-ENG116137-Leuchte13NL RB5-Dimming Direction GH 13    maximize     16
ENG116949-ENG116124-Leuchte13NL RB5-Dimmwert AB 13    100    16
ENG116949-ENG116128-Leuchte13NL RB5-Dimmwert CD 13    0    16
ENG116949-ENG116132-Leuchte13NL RB5-Dimmwert EF 13    0    16
ENG116949-ENG116136-Leuchte13NL RB5-Dimmwert GH 13    0    16
ENG116949-ENG116121-Leuchte13NL RB5-Fehlerort mittleres Byte DTC-DFCC 13    23    16
ENG116949-ENG116563-Leuchte13NL RB5-Lampendefektbitposition 13    42    16
ENG116949-ENG116119-Leuchte13NL RB5-Lasttyp 13    10 - allgemeine Scheinwerfer     16
ENG116949-ENG116125-Leuchte13NL RB5-Lichtansteuerung HD AB 13    Always     16
ENG116949-ENG116122-Leuchte13NL RB5-Lichtfunktion A 13    Nebellicht rechts     16
ENG116949-ENG116123-Leuchte13NL RB5-Lichtfunktion B 13    not active     16
ENG116949-ENG116564-Leuchte13NL RB5-Lichtfunktion C 13    not active     16
ENG116949-ENG116127-Leuchte13NL RB5-Lichtfunktion D 13    not active     16
ENG116949-ENG116130-Leuchte13NL RB5-Lichtfunktion E 13    not active     16
ENG116949-ENG116131-Leuchte13NL RB5-Lichtfunktion F 13    not active     16
ENG116949-ENG116134-Leuchte13NL RB5-Lichtfunktion G 13    not active     16
ENG116949-ENG116135-Leuchte13NL RB5-Lichtfunktion H 13    not active     16
ENG116951-ENG116167-Leuchte15AL RB44-Dimming Direction CD 15    maximize     16
ENG116951-ENG116171-Leuchte15AL RB44-Dimming Direction EF 15    maximize     16
ENG116951-ENG116175-Leuchte15AL RB44-Dimming Direction GH 15    maximize     16
ENG116951-ENG116162-Leuchte15AL RB44-Dimmwert AB 15    0    16
ENG116951-ENG116166-Leuchte15AL RB44-Dimmwert CD 15    0    16
ENG116951-ENG116170-Leuchte15AL RB44-Dimmwert EF 15    0    16
ENG116951-ENG116174-Leuchte15AL RB44-Dimmwert GH 15    0    16
ENG116951-ENG116159-Leuchte15AL RB44-Fehlerort mittleres Byte DTC-DFCC 15    0    16
ENG116951-ENG116566-Leuchte15AL RB44-Lampendefektbitposition 15    0    16
ENG116951-ENG116157-Leuchte15AL RB44-Lasttyp 15    not active     16
ENG116951-ENG116163-Leuchte15AL RB44-Lichtansteuerung HD AB 15    Always     16
ENG116951-ENG116160-Leuchte15AL RB44-Lichtfunktion A 15    not active     16
ENG116951-ENG116161-Leuchte15AL RB44-Lichtfunktion B 15    not active     16
ENG116951-ENG116164-Leuchte15AL RB44-Lichtfunktion C 15    not active     16
ENG116951-ENG116165-Leuchte15AL RB44-Lichtfunktion D 15    not active     16
ENG116951-ENG116168-Leuchte15AL RB44-Lichtfunktion E 15    not active     16
ENG116951-ENG116169-Leuchte15AL RB44-Lichtfunktion F 15    not active     16
ENG116951-ENG116172-Leuchte15AL RB44-Lichtfunktion G 15    not active     16
ENG116951-ENG116173-Leuchte15AL RB44-Lichtfunktion H 15    not active     16
ENG116952-ENG116186-Leuchte16BLK SLB35BLK SL KC9-Dimming Direction CD 16    maximize     16
ENG116952-ENG116190-Leuchte16BLK SLB35BLK SL KC9-Dimming Direction EF 16    maximize     16
ENG116952-ENG116194-Leuchte16BLK SLB35BLK SL KC9-Dimming Direction GH 16    maximize     16
ENG116952-ENG116181-Leuchte16BLK SLB35BLK SL KC9-Dimmwert AB 16    0    16
ENG116952-ENG116185-Leuchte16BLK SLB35BLK SL KC9-Dimmwert CD 16    0    16
ENG116952-ENG116189-Leuchte16BLK SLB35BLK SL KC9-Dimmwert EF 16    0    16
ENG116952-ENG116193-Leuchte16BLK SLB35BLK SL KC9-Dimmwert GH 16    0    16
ENG116952-ENG116178-Leuchte16BLK SLB35BLK SL KC9-Fehlerort mittleres Byte DTC-DFCC 16    0    16
ENG116952-ENG116567-Leuchte16BLK SLB35BLK SL KC9-Lampendefektbitposition 16    0    16
ENG116952-ENG116176-Leuchte16BLK SLB35BLK SL KC9-Lasttyp 16    not active     16
ENG116952-ENG116182-Leuchte16BLK SLB35BLK SL KC9-Lichtansteuerung HD AB 16    Always     16
ENG116952-ENG116179-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion A 16    not active     16
ENG116952-ENG116180-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion B 16    not active     16
ENG116952-ENG116183-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion C 16    not active     16
ENG116952-ENG116184-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion D 16    not active     16
ENG116952-ENG116187-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion E 16    not active     16
ENG116952-ENG116188-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion F 16    not active     16
ENG116952-ENG116191-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion G 16    not active     16
ENG116952-ENG116192-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion H 16    not active     16
ENG116953-ENG116205-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimming Direction CD 17    maximize     16
ENG116953-ENG116209-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimming Direction EF 17    maximize     16
ENG116953-ENG116213-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimming Direction GH 17    maximize     16
ENG116953-ENG116200-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimmwert AB 17    0    16
ENG116953-ENG116204-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimmwert CD 17    0    16
ENG116953-ENG116208-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimmwert EF 17    0    16
ENG116953-ENG116212-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimmwert GH 17    0    16
ENG116953-ENG116197-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Fehlerort mittleres Byte DTC-DFCC 17    0    16
ENG116953-ENG116568-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lampendefektbitposition 17    0    16
ENG116953-ENG116195-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lasttyp 17    not active     16
ENG116953-ENG116201-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtansteuerung HD AB 17    Always     16
ENG116953-ENG116198-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion A 17    not active     16
ENG116953-ENG116569-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion B 17    not active     16
ENG116953-ENG116202-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion C 17    not active     16
ENG116953-ENG116203-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion D 17    not active     16
ENG116953-ENG116206-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion E 17    not active     16
ENG116953-ENG116207-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion F 17    not active     16
ENG116953-ENG116210-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion G 17    not active     16
ENG116953-ENG116211-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion H 17    not active     16
ENG116954-ENG116224-Leuchte18BLK HLA60-Dimming Direction CD 18    maximize     16
ENG116954-ENG116228-Leuchte18BLK HLA60-Dimming Direction EF 18    maximize     16
ENG116954-ENG116232-Leuchte18BLK HLA60-Dimming Direction GH 18    maximize     16
ENG116954-ENG116219-Leuchte18BLK HLA60-Dimmwert AB 18    0    16
ENG116954-ENG116223-Leuchte18BLK HLA60-Dimmwert CD 18    0    16
ENG116954-ENG116227-Leuchte18BLK HLA60-Dimmwert EF 18    0    16
ENG116954-ENG116231-Leuchte18BLK HLA60-Dimmwert GH 18    0    16
ENG116954-ENG116216-Leuchte18BLK HLA60-Fehlerort mittleres Byte DTC-DFCC 18    0    16
ENG116954-ENG116570-Leuchte18BLK HLA60-Lampendefektbitposition 18    0    16
ENG116954-ENG116214-Leuchte18BLK HLA60-Lasttyp 18    not active     16
ENG116954-ENG116220-Leuchte18BLK HLA60-Lichtansteuerung HD AB 18    Always     16
ENG116954-ENG116217-Leuchte18BLK HLA60-Lichtfunktion A 18    not active     16
ENG116954-ENG116218-Leuchte18BLK HLA60-Lichtfunktion B 18    not active     16
ENG116954-ENG116221-Leuchte18BLK HLA60-Lichtfunktion C 18    not active     16
ENG116954-ENG116222-Leuchte18BLK HLA60-Lichtfunktion D 18    not active     16
ENG116954-ENG116225-Leuchte18BLK HLA60-Lichtfunktion E 18    not active     16
ENG116954-ENG116226-Leuchte18BLK HLA60-Lichtfunktion F 18    not active     16
ENG116954-ENG116229-Leuchte18BLK HLA60-Lichtfunktion G 18    not active     16
ENG116954-ENG116230-Leuchte18BLK HLA60-Lichtfunktion H 18    not active     16
ENG116955-ENG116243-Leuchte19BLK HRC31-Dimming Direction CD 19    maximize     16
ENG116955-ENG116247-Leuchte19BLK HRC31-Dimming Direction EF 19    maximize     16
ENG116955-ENG116251-Leuchte19BLK HRC31-Dimming Direction GH 19    maximize     16
ENG116955-ENG116238-Leuchte19BLK HRC31-Dimmwert AB 19    0    16
ENG116955-ENG116242-Leuchte19BLK HRC31-Dimmwert CD 19    0    16
ENG116955-ENG116246-Leuchte19BLK HRC31-Dimmwert EF 19    0    16
ENG116955-ENG116250-Leuchte19BLK HRC31-Dimmwert GH 19    0    16
ENG116955-ENG116235-Leuchte19BLK HRC31-Fehlerort mittleres Byte DTC-DFCC 19    0    16
ENG116955-ENG116571-Leuchte19BLK HRC31-Lampendefektbitposition 19    0    16
ENG116955-ENG116233-Leuchte19BLK HRC31-Lasttyp 19    not active     16
ENG116955-ENG116239-Leuchte19BLK HRC31-Lichtansteuerung HD AB 19    Always     16
ENG116955-ENG116236-Leuchte19BLK HRC31-Lichtfunktion A 19    not active     16
ENG116955-ENG116237-Leuchte19BLK HRC31-Lichtfunktion B 19    not active     16
ENG116955-ENG116240-Leuchte19BLK HRC31-Lichtfunktion C 19    not active     16
ENG116955-ENG116241-Leuchte19BLK HRC31-Lichtfunktion D 19    not active     16
ENG116955-ENG116244-Leuchte19BLK HRC31-Lichtfunktion E 19    not active     16
ENG116955-ENG116245-Leuchte19BLK HRC31-Lichtfunktion F 19    not active     16
ENG116955-ENG116248-Leuchte19BLK HRC31-Lichtfunktion G 19    not active     16
ENG116955-ENG116249-Leuchte19BLK HRC31-Lichtfunktion H 19    not active     16
ENG116937-ENG115902-Leuchte1BLK VRB20-Dimming Direction CD 1    maximize     16
ENG116937-ENG115906-Leuchte1BLK VRB20-Dimming Direction EF 1    maximize     16
ENG116937-ENG115909-Leuchte1BLK VRB20-Dimming Direction GH 1    maximize     16
ENG116937-ENG115897-Leuchte1BLK VRB20-Dimmwert AB 1    100    16
ENG116937-ENG115901-Leuchte1BLK VRB20-Dimmwert CD 1    0    16
ENG116937-ENG115905-Leuchte1BLK VRB20-Dimmwert EF 1    0    16
ENG116937-ENG115908-Leuchte1BLK VRB20-Dimmwert GH 1    0    16
ENG116937-ENG115894-Leuchte1BLK VRB20-Fehlerort mittleres Byte DTC-DFCC 1    15    16
ENG116937-ENG116548-Leuchte1BLK VRB20-Lampendefektbitposition 1    3E     16
ENG116937-ENG115892-Leuchte1BLK VRB20-Lasttyp 1    12 - Blinkleuchten     16
ENG116937-ENG115898-Leuchte1BLK VRB20-Lichtansteuerung HD AB 1    Always     16
ENG116937-ENG115895-Leuchte1BLK VRB20-Lichtfunktion A 1    Blinken rechts Hellphase     16
ENG116937-ENG115896-Leuchte1BLK VRB20-Lichtfunktion B 1    not active     16
ENG116937-ENG115899-Leuchte1BLK VRB20-Lichtfunktion C 1    not active     16
ENG116937-ENG115900-Leuchte1BLK VRB20-Lichtfunktion D 1    not active     16
ENG116937-ENG115903-Leuchte1BLK VRB20-Lichtfunktion E 1    not active     16
ENG116937-ENG115904-Leuchte1BLK VRB20-Lichtfunktion F 1    not active     16
ENG116937-ENG115907-Leuchte1BLK VRB20-Lichtfunktion G 1    not active     16
ENG116937-ENG116549-Leuchte1BLK VRB20-Lichtfunktion H 1    not active     16
ENG116956-ENG116262-Leuchte20BR LA71-Dimming Direction CD 20    minimize     16
ENG116956-ENG116266-Leuchte20BR LA71-Dimming Direction EF 20    maximize     16
ENG116956-ENG116270-Leuchte20BR LA71-Dimming Direction GH 20    maximize     16
ENG116956-ENG116257-Leuchte20BR LA71-Dimmwert AB 20    100    16
ENG116956-ENG116261-Leuchte20BR LA71-Dimmwert CD 20    0    16
ENG116956-ENG116265-Leuchte20BR LA71-Dimmwert EF 20    28    16
ENG116956-ENG116269-Leuchte20BR LA71-Dimmwert GH 20    0    16
ENG116956-ENG116254-Leuchte20BR LA71-Fehlerort mittleres Byte DTC-DFCC 20    3D     16
ENG116956-ENG116572-Leuchte20BR LA71-Lampendefektbitposition 20    13    16
ENG116956-ENG116252-Leuchte20BR LA71-Lasttyp 20    14 - kombinierte Blink- Bremsleuchten     16
ENG116956-ENG116258-Leuchte20BR LA71-Lichtansteuerung HD AB 20    Always     16
ENG116956-ENG116255-Leuchte20BR LA71-Lichtfunktion A 20    Brake lamp     16
ENG116956-ENG116256-Leuchte20BR LA71-Lichtfunktion B 20    Blinken links Hellphase     16
ENG116956-ENG116259-Leuchte20BR LA71-Lichtfunktion C 20    Blinken links Dunkelphase     16
ENG116956-ENG116260-Leuchte20BR LA71-Lichtfunktion D 20    not active     16
ENG116956-ENG116263-Leuchte20BR LA71-Lichtfunktion E 20    Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht)     16
ENG116956-ENG116264-Leuchte20BR LA71-Lichtfunktion F 20    not active     16
ENG116956-ENG116267-Leuchte20BR LA71-Lichtfunktion G 20    not active     16
ENG116956-ENG116268-Leuchte20BR LA71-Lichtfunktion H 20    not active     16
ENG116957-ENG116281-Leuchte21BR RC8-Dimming Direction CD 21    minimize     16
ENG116957-ENG116285-Leuchte21BR RC8-Dimming Direction EF 21    maximize     16
ENG116957-ENG116289-Leuchte21BR RC8-Dimming Direction GH 21    maximize     16
ENG116957-ENG116276-Leuchte21BR RC8-Dimmwert AB 21    100    16
ENG116957-ENG116280-Leuchte21BR RC8-Dimmwert CD 21    0    16
ENG116957-ENG116284-Leuchte21BR RC8-Dimmwert EF 21    28    16
ENG116957-ENG116288-Leuchte21BR RC8-Dimmwert GH 21    0    16
ENG116957-ENG116273-Leuchte21BR RC8-Fehlerort mittleres Byte DTC-DFCC 21    3E     16
ENG116957-ENG116573-Leuchte21BR RC8-Lampendefektbitposition 21    23    16
ENG116957-ENG116271-Leuchte21BR RC8-Lasttyp 21    14 - kombinierte Blink- Bremsleuchten     16
ENG116957-ENG116277-Leuchte21BR RC8-Lichtansteuerung HD AB 21    Always     16
ENG116957-ENG116274-Leuchte21BR RC8-Lichtfunktion A 21    Brake lamp     16
ENG116957-ENG116275-Leuchte21BR RC8-Lichtfunktion B 21    Blinken rechts Hellphase     16
ENG116957-ENG116278-Leuchte21BR RC8-Lichtfunktion C 21    Blinken rechts Dunkelphase     16
ENG116957-ENG116279-Leuchte21BR RC8-Lichtfunktion D 21    not active     16
ENG116957-ENG116282-Leuchte21BR RC8-Lichtfunktion E 21    Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht)     16
ENG116957-ENG116283-Leuchte21BR RC8-Lichtfunktion F 21    not active     16
ENG116957-ENG116286-Leuchte21BR RC8-Lichtfunktion G 21    not active     16
ENG116957-ENG116287-Leuchte21BR RC8-Lichtfunktion H 21    not active     16
ENG116958-ENG116300-Leuchte22BR MA57-Dimming Direction CD 22    maximize     16
ENG116958-ENG116304-Leuchte22BR MA57-Dimming Direction EF 22    maximize     16
ENG116958-ENG116308-Leuchte22BR MA57-Dimming Direction GH 22    maximize     16
ENG116958-ENG116295-Leuchte22BR MA57-Dimmwert AB 22    100    16
ENG116958-ENG116299-Leuchte22BR MA57-Dimmwert CD 22    0    16
ENG116958-ENG116303-Leuchte22BR MA57-Dimmwert EF 22    0    16
ENG116958-ENG116307-Leuchte22BR MA57-Dimmwert GH 22    0    16
ENG116958-ENG116292-Leuchte22BR MA57-Fehlerort mittleres Byte DTC-DFCC 22    2C     16
ENG116958-ENG116574-Leuchte22BR MA57-Lampendefektbitposition 22    29    16
ENG116958-ENG116290-Leuchte22BR MA57-Lasttyp 22    42 - LED dritte Bremsleuchte     16
ENG116958-ENG116296-Leuchte22BR MA57-Lichtansteuerung HD AB 22    Always     16
ENG116958-ENG116293-Leuchte22BR MA57-Lichtfunktion A 22    Brake lamp     16
ENG116958-ENG116294-Leuchte22BR MA57-Lichtfunktion B 22    not active     16
ENG116958-ENG116297-Leuchte22BR MA57-Lichtfunktion C 22    not active     16
ENG116958-ENG116298-Leuchte22BR MA57-Lichtfunktion D 22    not active     16
ENG116958-ENG116301-Leuchte22BR MA57-Lichtfunktion E 22    not active     16
ENG116958-ENG116302-Leuchte22BR MA57-Lichtfunktion F 22    not active     16
ENG116958-ENG116305-Leuchte22BR MA57-Lichtfunktion G 22    not active     16
ENG116958-ENG116306-Leuchte22BR MA57-Lichtfunktion H 22    not active     16
ENG116959-ENG116319-Leuchte23SL HLC10-Dimming Direction CD 23    maximize     16
ENG116959-ENG116323-Leuchte23SL HLC10-Dimming Direction EF 23    maximize     16
ENG116959-ENG116327-Leuchte23SL HLC10-Dimming Direction GH 23    maximize     16
ENG116959-ENG116314-Leuchte23SL HLC10-Dimmwert AB 23    28    16
ENG116959-ENG116318-Leuchte23SL HLC10-Dimmwert CD 23    100    16
ENG116959-ENG116322-Leuchte23SL HLC10-Dimmwert EF 23    0    16
ENG116959-ENG116326-Leuchte23SL HLC10-Dimmwert GH 23    0    16
ENG116959-ENG116311-Leuchte23SL HLC10-Fehlerort mittleres Byte DTC-DFCC 23    29    16
ENG116959-ENG116575-Leuchte23SL HLC10-Lampendefektbitposition 23    0A     16
ENG116959-ENG116309-Leuchte23SL HLC10-Lasttyp 23    9 - allgemeine Glühlampe 27W: auch H15     16
ENG116959-ENG116315-Leuchte23SL HLC10-Lichtansteuerung HD AB 23    Always     16
ENG116959-ENG116312-Leuchte23SL HLC10-Lichtfunktion A 23    Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht)     16
ENG116959-ENG116313-Leuchte23SL HLC10-Lichtfunktion B 23    not active     16
ENG116959-ENG116316-Leuchte23SL HLC10-Lichtfunktion C 23    Brake lamp     16
ENG116959-ENG116317-Leuchte23SL HLC10-Lichtfunktion D 23    not active     16
ENG116959-ENG116320-Leuchte23SL HLC10-Lichtfunktion E 23    not active     16
ENG116959-ENG116321-Leuchte23SL HLC10-Lichtfunktion F 23    not active     16
ENG116959-ENG116324-Leuchte23SL HLC10-Lichtfunktion G 23    not active     16
ENG116959-ENG116325-Leuchte23SL HLC10-Lichtfunktion H 23    not active     16
ENG116960-ENG116338-Leuchte24SL HRA65-Dimming Direction CD 24    maximize     16
ENG116960-ENG116342-Leuchte24SL HRA65-Dimming Direction EF 24    maximize     16
ENG116960-ENG116346-Leuchte24SL HRA65-Dimming Direction GH 24    maximize     16
ENG116960-ENG116333-Leuchte24SL HRA65-Dimmwert AB 24    28    16
ENG116960-ENG116337-Leuchte24SL HRA65-Dimmwert CD 24    100    16
ENG116960-ENG116341-Leuchte24SL HRA65-Dimmwert EF 24    0    16
ENG116960-ENG116345-Leuchte24SL HRA65-Dimmwert GH 24    0    16
ENG116960-ENG116330-Leuchte24SL HRA65-Fehlerort mittleres Byte DTC-DFCC 24    2A     16
ENG116960-ENG116576-Leuchte24SL HRA65-Lampendefektbitposition 24    1A     16
ENG116960-ENG116328-Leuchte24SL HRA65-Lasttyp 24    9 - allgemeine Glühlampe 27W: auch H15     16
ENG116960-ENG116334-Leuchte24SL HRA65-Lichtansteuerung HD AB 24    Always     16
ENG116960-ENG116331-Leuchte24SL HRA65-Lichtfunktion A 24    Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht)     16
ENG116960-ENG116332-Leuchte24SL HRA65-Lichtfunktion B 24    not active     16
ENG116960-ENG116335-Leuchte24SL HRA65-Lichtfunktion C 24    Brake lamp     16
ENG116960-ENG116336-Leuchte24SL HRA65-Lichtfunktion D 24    not active     16
ENG116960-ENG116339-Leuchte24SL HRA65-Lichtfunktion E 24    not active     16
ENG116960-ENG116340-Leuchte24SL HRA65-Lichtfunktion F 24    not active     16
ENG116960-ENG116343-Leuchte24SL HRA65-Lichtfunktion G 24    not active     16
ENG116960-ENG116344-Leuchte24SL HRA65-Lichtfunktion H 24    not active     16
ENG116961-ENG116357-Leuchte25KZL HA59-Dimming Direction CD 25    maximize     16
ENG116961-ENG116361-Leuchte25KZL HA59-Dimming Direction EF 25    maximize     16
ENG116961-ENG116365-Leuchte25KZL HA59-Dimming Direction GH 25    maximize     16
ENG116961-ENG116352-Leuchte25KZL HA59-Dimmwert AB 25    100    16
ENG116961-ENG116356-Leuchte25KZL HA59-Dimmwert CD 25    0    16
ENG116961-ENG116360-Leuchte25KZL HA59-Dimmwert EF 25    0    16
ENG116961-ENG116364-Leuchte25KZL HA59-Dimmwert GH 25    0    16
ENG116961-ENG116349-Leuchte25KZL HA59-Fehlerort mittleres Byte DTC-DFCC 25    30    16
ENG116961-ENG116577-Leuchte25KZL HA59-Lampendefektbitposition 25    28    16
ENG116961-ENG116347-Leuchte25KZL HA59-Lasttyp 25    18 - 2* 5W     16
ENG116961-ENG116353-Leuchte25KZL HA59-Lichtansteuerung HD AB 25    Always     16
ENG116961-ENG116350-Leuchte25KZL HA59-Lichtfunktion A 25    Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht)     16
ENG116961-ENG116351-Leuchte25KZL HA59-Lichtfunktion B 25    not active     16
ENG116961-ENG116354-Leuchte25KZL HA59-Lichtfunktion C 25    not active     16
ENG116961-ENG116355-Leuchte25KZL HA59-Lichtfunktion D 25    not active     16
ENG116961-ENG116358-Leuchte25KZL HA59-Lichtfunktion E 25    not active     16
ENG116961-ENG116359-Leuchte25KZL HA59-Lichtfunktion F 25    not active     16
ENG116961-ENG116362-Leuchte25KZL HA59-Lichtfunktion G 25    not active     16
ENG116961-ENG116363-Leuchte25KZL HA59-Lichtfunktion H 25    not active     16
ENG116962-ENG116376-Leuchte26NSL LA72-Dimming Direction CD 26    maximize     16
ENG116962-ENG116380-Leuchte26NSL LA72-Dimming Direction EF 26    maximize     16
ENG116962-ENG116384-Leuchte26NSL LA72-Dimming Direction GH 26    maximize     16
ENG116962-ENG116371-Leuchte26NSL LA72-Dimmwert AB 26    0    16
ENG116962-ENG116375-Leuchte26NSL LA72-Dimmwert CD 26    0    16
ENG116962-ENG116379-Leuchte26NSL LA72-Dimmwert EF 26    0    16
ENG116962-ENG116383-Leuchte26NSL LA72-Dimmwert GH 26    0    16
ENG116962-ENG116368-Leuchte26NSL LA72-Fehlerort mittleres Byte DTC-DFCC 26    0    16
ENG116962-ENG116578-Leuchte26NSL LA72-Lampendefektbitposition 26    0    16
ENG116962-ENG116366-Leuchte26NSL LA72-Lasttyp 26    not active     16
ENG116962-ENG116372-Leuchte26NSL LA72-Lichtansteuerung HD AB 26    Always     16
ENG116962-ENG116369-Leuchte26NSL LA72-Lichtfunktion A 26    not active     16
ENG116962-ENG116370-Leuchte26NSL LA72-Lichtfunktion B 26    not active     16
ENG116962-ENG116373-Leuchte26NSL LA72-Lichtfunktion C 26    not active     16
ENG116962-ENG116374-Leuchte26NSL LA72-Lichtfunktion D 26    not active     16
ENG116962-ENG116377-Leuchte26NSL LA72-Lichtfunktion E 26    not active     16
ENG116962-ENG116378-Leuchte26NSL LA72-Lichtfunktion F 26    not active     16
ENG116962-ENG116381-Leuchte26NSL LA72-Lichtfunktion G 26    not active     16
ENG116962-ENG116382-Leuchte26NSL LA72-Lichtfunktion H 26    not active     16
ENG116963-ENG116395-Leuchte27NSL RC6-Dimming Direction CD 27    maximize     16
ENG116963-ENG116399-Leuchte27NSL RC6-Dimming Direction EF 27    maximize     16
ENG116963-ENG116403-Leuchte27NSL RC6-Dimming Direction GH 27    maximize     16
ENG116963-ENG116390-Leuchte27NSL RC6-Dimmwert AB 27    127    16
ENG116963-ENG116394-Leuchte27NSL RC6-Dimmwert CD 27    0    16
ENG116963-ENG116398-Leuchte27NSL RC6-Dimmwert EF 27    0    16
ENG116963-ENG116402-Leuchte27NSL RC6-Dimmwert GH 27    0    16
ENG116963-ENG116387-Leuchte27NSL RC6-Fehlerort mittleres Byte DTC-DFCC 27    47    16
ENG116963-ENG116579-Leuchte27NSL RC6-Lampendefektbitposition 27    0    16
ENG116963-ENG116385-Leuchte27NSL RC6-Lasttyp 27    1 - LED Tagfahrlichtmodul Versorgung     16
ENG116963-ENG116391-Leuchte27NSL RC6-Lichtansteuerung HD AB 27    Always     16
ENG116963-ENG116388-Leuchte27NSL RC6-Lichtfunktion A 27    Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht)     16
ENG116963-ENG116389-Leuchte27NSL RC6-Lichtfunktion B 27    not active     16
ENG116963-ENG116392-Leuchte27NSL RC6-Lichtfunktion C 27    Brake lamp     16
ENG116963-ENG116393-Leuchte27NSL RC6-Lichtfunktion D 27    not active     16
ENG116963-ENG116396-Leuchte27NSL RC6-Lichtfunktion E 27    not active     16
ENG116963-ENG116397-Leuchte27NSL RC6-Lichtfunktion F 27    not active     16
ENG116963-ENG116400-Leuchte27NSL RC6-Lichtfunktion G 27    not active     16
ENG116963-ENG116401-Leuchte27NSL RC6-Lichtfunktion H 27    not active     16
ENG116964-ENG116414-Leuchte28RFL LC11-Dimming Direction CD 28    maximize     16
ENG116964-ENG116418-Leuchte28RFL LC11-Dimming Direction EF 28    maximize     16
ENG116964-ENG116422-Leuchte28RFL LC11-Dimming Direction GH 28    maximize     16
ENG116964-ENG116409-Leuchte28RFL LC11-Dimmwert AB 28    100    16
ENG116964-ENG116413-Leuchte28RFL LC11-Dimmwert CD 28    0    16
ENG116964-ENG116417-Leuchte28RFL LC11-Dimmwert EF 28    0    16
ENG116964-ENG116421-Leuchte28RFL LC11-Dimmwert GH 28    0    16
ENG116964-ENG116406-Leuchte28RFL LC11-Fehlerort mittleres Byte DTC-DFCC 28    31    16
ENG116964-ENG116580-Leuchte28RFL LC11-Lampendefektbitposition 28    0B     16
ENG116964-ENG116404-Leuchte28RFL LC11-Lasttyp 28    43 - allgemeine LED     16
ENG116964-ENG116410-Leuchte28RFL LC11-Lichtansteuerung HD AB 28    Always     16
ENG116964-ENG116407-Leuchte28RFL LC11-Lichtfunktion A 28    Rueckfahrlicht     16
ENG116964-ENG116408-Leuchte28RFL LC11-Lichtfunktion B 28    not active     16
ENG116964-ENG116411-Leuchte28RFL LC11-Lichtfunktion C 28    not active     16
ENG116964-ENG116412-Leuchte28RFL LC11-Lichtfunktion D 28    not active     16
ENG116964-ENG116415-Leuchte28RFL LC11-Lichtfunktion E 28    not active     16
ENG116964-ENG116416-Leuchte28RFL LC11-Lichtfunktion F 28    not active     16
ENG116964-ENG116419-Leuchte28RFL LC11-Lichtfunktion G 28    not active     16
ENG116964-ENG116420-Leuchte28RFL LC11-Lichtfunktion H 28    not active     16
ENG116965-ENG116433-Leuchte29RFL RA64-Dimming Direction CD 29    maximize     16
ENG116965-ENG116437-Leuchte29RFL RA64-Dimming Direction EF 29    maximize     16
ENG116965-ENG116441-Leuchte29RFL RA64-Dimming Direction GH 29    maximize     16
ENG116965-ENG116428-Leuchte29RFL RA64-Dimmwert AB 29    100    16
ENG116965-ENG116432-Leuchte29RFL RA64-Dimmwert CD 29    0    16
ENG116965-ENG116436-Leuchte29RFL RA64-Dimmwert EF 29    0    16
ENG116965-ENG116440-Leuchte29RFL RA64-Dimmwert GH 29    0    16
ENG116965-ENG116425-Leuchte29RFL RA64-Fehlerort mittleres Byte DTC-DFCC 29    32    16
ENG116965-ENG116581-Leuchte29RFL RA64-Lampendefektbitposition 29    1B     16
ENG116965-ENG116423-Leuchte29RFL RA64-Lasttyp 29    43 - allgemeine LED     16
ENG116965-ENG116430-Leuchte29RFL RA64-Lichtansteuerung HD AB 29    Always     16
ENG116965-ENG116426-Leuchte29RFL RA64-Lichtfunktion A 29    Rueckfahrlicht     16
ENG116965-ENG116427-Leuchte29RFL RA64-Lichtfunktion B 29    not active     16
ENG116965-ENG116429-Leuchte29RFL RA64-Lichtfunktion C 29    not active     16
ENG116965-ENG116431-Leuchte29RFL RA64-Lichtfunktion D 29    not active     16
ENG116965-ENG116434-Leuchte29RFL RA64-Lichtfunktion E 29    not active     16
ENG116965-ENG116435-Leuchte29RFL RA64-Lichtfunktion F 29    not active     16
ENG116965-ENG116438-Leuchte29RFL RA64-Lichtfunktion G 29    not active     16
ENG116965-ENG116439-Leuchte29RFL RA64-Lichtfunktion H 29    not active     16
ENG116938-ENG115920-Leuchte2SL VLB10-Dimming Direction CD 2    minimize     16
ENG116938-ENG115924-Leuchte2SL VLB10-Dimming Direction EF 2    maximize     16
ENG116938-ENG115928-Leuchte2SL VLB10-Dimming Direction GH 2    maximize     16
ENG116938-ENG115915-Leuchte2SL VLB10-Dimmwert AB 2    100    16
ENG116938-ENG115919-Leuchte2SL VLB10-Dimmwert CD 2    0    16
ENG116938-ENG115923-Leuchte2SL VLB10-Dimmwert EF 2    26    16
ENG116938-ENG115927-Leuchte2SL VLB10-Dimmwert GH 2    0    16
ENG116938-ENG115912-Leuchte2SL VLB10-Fehlerort mittleres Byte DTC-DFCC 2    4A     16
ENG116938-ENG116550-Leuchte2SL VLB10-Lampendefektbitposition 2    48    16
ENG116938-ENG115910-Leuchte2SL VLB10-Lasttyp 2    4 - LED Tagfahrlichtmodul Signal     16
ENG116938-ENG115916-Leuchte2SL VLB10-Lichtansteuerung HD AB 2    Always     16
ENG116938-ENG115913-Leuchte2SL VLB10-Lichtfunktion A 2    Daytime running lamps     16
ENG116938-ENG115914-Leuchte2SL VLB10-Lichtfunktion B 2    not active     16
ENG116938-ENG115917-Leuchte2SL VLB10-Lichtfunktion C 2    Blinken links aktiv (beide Phasen)     16
ENG116938-ENG115918-Leuchte2SL VLB10-Lichtfunktion D 2    not active     16
ENG116938-ENG115921-Leuchte2SL VLB10-Lichtfunktion E 2    Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht)     16
ENG116938-ENG115922-Leuchte2SL VLB10-Lichtfunktion F 2    Parklicht links (beidseitiges Parklicht aktiviert li & re)     16
ENG116938-ENG115925-Leuchte2SL VLB10-Lichtfunktion G 2    not active     16
ENG116938-ENG115926-Leuchte2SL VLB10-Lichtfunktion H 2    not active     16
ENG116966-ENG116452-Leuchte30FR LC72-Dimming Direction CD 30    maximize     16
ENG116966-ENG116456-Leuchte30FR LC72-Dimming Direction EF 30    maximize     16
ENG116966-ENG116460-Leuchte30FR LC72-Dimming Direction GH 30    maximize     16
ENG116966-ENG116447-Leuchte30FR LC72-Dimmwert AB 30    89    16
ENG116966-ENG116451-Leuchte30FR LC72-Dimmwert CD 30    0    16
ENG116966-ENG116455-Leuchte30FR LC72-Dimmwert EF 30    0    16
ENG116966-ENG116459-Leuchte30FR LC72-Dimmwert GH 30    0    16
ENG116966-ENG116444-Leuchte30FR LC72-Fehlerort mittleres Byte DTC-DFCC 30    2    16
ENG116966-ENG116582-Leuchte30FR LC72-Lampendefektbitposition 30    0    16
ENG116966-ENG116442-Leuchte30FR LC72-Lasttyp 30    36 - LED Kleinleistung     16
ENG116966-ENG116448-Leuchte30FR LC72-Lichtansteuerung HD AB 30    Always     16
ENG116966-ENG116445-Leuchte30FR LC72-Lichtfunktion A 30    Footwell lamp     16
ENG116966-ENG116446-Leuchte30FR LC72-Lichtfunktion B 30    not active     16
ENG116966-ENG116449-Leuchte30FR LC72-Lichtfunktion C 30    not active     16
ENG116966-ENG116450-Leuchte30FR LC72-Lichtfunktion D 30    not active     16
ENG116966-ENG116453-Leuchte30FR LC72-Lichtfunktion E 30    not active     16
ENG116966-ENG116454-Leuchte30FR LC72-Lichtfunktion F 30    not active     16
ENG116966-ENG116457-Leuchte30FR LC72-Lichtfunktion G 30    not active     16
ENG116966-ENG116458-Leuchte30FR LC72-Lichtfunktion H 30    not active     16
ENG116967-ENG116471-Leuchte31AMBL 1C61-Dimming Direction CD 31    maximize     16
ENG116967-ENG116475-Leuchte31AMBL 1C61-Dimming Direction EF 31    maximize     16
ENG116967-ENG116479-Leuchte31AMBL 1C61-Dimming Direction GH 31    maximize     16
ENG116967-ENG116466-Leuchte31AMBL 1C61-Dimmwert AB 31    0    16
ENG116967-ENG116470-Leuchte31AMBL 1C61-Dimmwert CD 31    0    16
ENG116967-ENG116474-Leuchte31AMBL 1C61-Dimmwert EF 31    0    16
ENG116967-ENG116478-Leuchte31AMBL 1C61-Dimmwert GH 31    0    16
ENG116967-ENG116463-Leuchte31AMBL 1C61-Fehlerort mittleres Byte DTC-DFCC 31    0    16
ENG116967-ENG116583-Leuchte31AMBL 1C61-Lampendefektbitposition 31    0    16
ENG116967-ENG116461-Leuchte31AMBL 1C61-Lasttyp 31    not active     16
ENG116967-ENG116467-Leuchte31AMBL 1C61-Lichtansteuerung HD AB 31    Always     16
ENG116967-ENG116464-Leuchte31AMBL 1C61-Lichtfunktion A 31    not active     16
ENG116967-ENG116465-Leuchte31AMBL 1C61-Lichtfunktion B 31    not active     16
ENG116967-ENG116468-Leuchte31AMBL 1C61-Lichtfunktion C 31    not active     16
ENG116967-ENG116469-Leuchte31AMBL 1C61-Lichtfunktion D 31    not active     16
ENG116967-ENG116472-Leuchte31AMBL 1C61-Lichtfunktion E 31    not active     16
ENG116967-ENG116473-Leuchte31AMBL 1C61-Lichtfunktion F 31    not active     16
ENG116967-ENG116476-Leuchte31AMBL 1C61-Lichtfunktion G 31    not active     16
ENG116967-ENG116477-Leuchte31AMBL 1C61-Lichtfunktion H 31    not active     16
ENG116968-ENG116490-Leuchte32AMBL 2C35-Dimming Direction CD 32    maximize     16
ENG116968-ENG116494-Leuchte32AMBL 2C35-Dimming Direction EF 32    maximize     16
ENG116968-ENG116498-Leuchte32AMBL 2C35-Dimming Direction GH 32    maximize     16
ENG116968-ENG116485-Leuchte32AMBL 2C35-Dimmwert AB 32    0    16
ENG116968-ENG116489-Leuchte32AMBL 2C35-Dimmwert CD 32    0    16
ENG116968-ENG116493-Leuchte32AMBL 2C35-Dimmwert EF 32    0    16
ENG116968-ENG116497-Leuchte32AMBL 2C35-Dimmwert GH 32    0    16
ENG116968-ENG116482-Leuchte32AMBL 2C35-Fehlerort mittleres Byte DTC-DFCC 32    0    16
ENG116968-ENG116584-Leuchte32AMBL 2C35-Lampendefektbitposition 32    0    16
ENG116968-ENG116480-Leuchte32AMBL 2C35-Lasttyp 32    not active     16
ENG116968-ENG116486-Leuchte32AMBL 2C35-Lichtansteuerung HD AB 32    Always     16
ENG116968-ENG116483-Leuchte32AMBL 2C35-Lichtfunktion A 32    not active     16
ENG116968-ENG116484-Leuchte32AMBL 2C35-Lichtfunktion B 32    not active     16
ENG116968-ENG116487-Leuchte32AMBL 2C35-Lichtfunktion C 32    not active     16
ENG116968-ENG116488-Leuchte32AMBL 2C35-Lichtfunktion D 32    not active     16
ENG116968-ENG116491-Leuchte32AMBL 2C35-Lichtfunktion E 32    not active     16
ENG116968-ENG116492-Leuchte32AMBL 2C35-Lichtfunktion F 32    not active     16
ENG116968-ENG116495-Leuchte32AMBL 2C35-Lichtfunktion G 32    not active     16
ENG116968-ENG116496-Leuchte32AMBL 2C35-Lichtfunktion H 32    not active     16
ENG116969-ENG116509-Leuchte33AMBL 3C36-Dimming Direction CD 33    maximize     16
ENG116969-ENG116513-Leuchte33AMBL 3C36-Dimming Direction EF 33    maximize     16
ENG116969-ENG116517-Leuchte33AMBL 3C36-Dimming Direction GH 33    maximize     16
ENG116969-ENG116504-Leuchte33AMBL 3C36-Dimmwert AB 33    0    16
ENG116969-ENG116508-Leuchte33AMBL 3C36-Dimmwert CD 33    0    16
ENG116969-ENG116512-Leuchte33AMBL 3C36-Dimmwert EF 33    0    16
ENG116969-ENG116516-Leuchte33AMBL 3C36-Dimmwert GH 33    0    16
ENG116969-ENG116501-Leuchte33AMBL 3C36-Fehlerort mittleres Byte DTC-DFCC 33    0    16
ENG116969-ENG116585-Leuchte33AMBL 3C36-Lampendefektbitposition 33    0    16
ENG116969-ENG116499-Leuchte33AMBL 3C36-Lasttyp 33    not active     16
ENG116969-ENG116505-Leuchte33AMBL 3C36-Lichtansteuerung HD AB 33    Always     16
ENG116969-ENG116502-Leuchte33AMBL 3C36-Lichtfunktion A 33    not active     16
ENG116969-ENG116503-Leuchte33AMBL 3C36-Lichtfunktion B 33    not active     16
ENG116969-ENG116506-Leuchte33AMBL 3C36-Lichtfunktion C 33    not active     16
ENG116969-ENG116507-Leuchte33AMBL 3C36-Lichtfunktion D 33    not active     16
ENG116969-ENG116510-Leuchte33AMBL 3C36-Lichtfunktion E 33    not active     16
ENG116969-ENG116511-Leuchte33AMBL 3C36-Lichtfunktion F 33    not active     16
ENG116969-ENG116514-Leuchte33AMBL 3C36-Lichtfunktion G 33    not active     16
ENG116969-ENG116515-Leuchte33AMBL 3C36-Lichtfunktion H 33    not active     16
ENG116970-ENG116528-Leuchte34AMBL 4C37-Dimming Direction CD 34    maximize     16
ENG116970-ENG116532-Leuchte34AMBL 4C37-Dimming Direction EF 34    maximize     16
ENG116970-ENG116536-Leuchte34AMBL 4C37-Dimming Direction GH 34    maximize     16
ENG116970-ENG116523-Leuchte34AMBL 4C37-Dimmwert AB 34    0    16
ENG116970-ENG116527-Leuchte34AMBL 4C37-Dimmwert CD 34    0    16
ENG116970-ENG116531-Leuchte34AMBL 4C37-Dimmwert EF 34    0    16
ENG116970-ENG116535-Leuchte34AMBL 4C37-Dimmwert GH 34    0    16
ENG116970-ENG116520-Leuchte34AMBL 4C37-Fehlerort mittleres Byte DTC-DFCC 34    0    16
ENG116970-ENG116586-Leuchte34AMBL 4C37-Lampendefektbitposition 34    0    16
ENG116970-ENG116518-Leuchte34AMBL 4C37-Lasttyp 34    not active     16
ENG116970-ENG116524-Leuchte34AMBL 4C37-Lichtansteuerung HD AB 34    Always     16
ENG116970-ENG116521-Leuchte34AMBL 4C37-Lichtfunktion A 34    not active     16
ENG116970-ENG116522-Leuchte34AMBL 4C37-Lichtfunktion B 34    not active     16
ENG116970-ENG116525-Leuchte34AMBL 4C37-Lichtfunktion C 34    not active     16
ENG116970-ENG116526-Leuchte34AMBL 4C37-Lichtfunktion D 34    not active     16
ENG116970-ENG116529-Leuchte34AMBL 4C37-Lichtfunktion E 34    not active     16
ENG116970-ENG116530-Leuchte34AMBL 4C37-Lichtfunktion F 34    not active     16
ENG116970-ENG116533-Leuchte34AMBL 4C37-Lichtfunktion G 34    not active     16
ENG116970-ENG116534-Leuchte34AMBL 4C37-Lichtfunktion H 34    not active     16
ENG116939-ENG115939-Leuchte3SL VRB21-Dimming Direction CD 3    minimize     16
ENG116939-ENG115943-Leuchte3SL VRB21-Dimming Direction EF 3    maximize     16
ENG116939-ENG115947-Leuchte3SL VRB21-Dimming Direction GH 3    maximize     16
ENG116939-ENG115934-Leuchte3SL VRB21-Dimmwert AB 3    100    16
ENG116939-ENG115938-Leuchte3SL VRB21-Dimmwert CD 3    0    16
ENG116939-ENG115942-Leuchte3SL VRB21-Dimmwert EF 3    26    16
ENG116939-ENG115946-Leuchte3SL VRB21-Dimmwert GH 3    0    16
ENG116939-ENG115931-Leuchte3SL VRB21-Fehlerort mittleres Byte DTC-DFCC 3    4C     16
ENG116939-ENG116551-Leuchte3SL VRB21-Lampendefektbitposition 3    4C     16
ENG116939-ENG115929-Leuchte3SL VRB21-Lasttyp 3    4 - LED Tagfahrlichtmodul Signal     16
ENG116939-ENG115935-Leuchte3SL VRB21-Lichtansteuerung HD AB 3    Always     16
ENG116939-ENG115932-Leuchte3SL VRB21-Lichtfunktion A 3    Daytime running lamps     16
ENG116939-ENG115933-Leuchte3SL VRB21-Lichtfunktion B 3    not active     16
ENG116939-ENG115936-Leuchte3SL VRB21-Lichtfunktion C 3    Blinken rechts aktiv (beide Phasen)     16
ENG116939-ENG115937-Leuchte3SL VRB21-Lichtfunktion D 3    not active     16
ENG116939-ENG115940-Leuchte3SL VRB21-Lichtfunktion E 3    Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht)     16
ENG116939-ENG116552-Leuchte3SL VRB21-Lichtfunktion F 3    Parking light right     16
ENG116939-ENG115944-Leuchte3SL VRB21-Lichtfunktion G 3    not active     16
ENG116939-ENG115945-Leuchte3SL VRB21-Lichtfunktion H 3    not active     16
ENG116940-ENG115958-Leuchte4TFL LB4-Dimming Direction CD 4    minimize     16
ENG116940-ENG115962-Leuchte4TFL LB4-Dimming Direction EF 4    maximize     16
ENG116940-ENG115966-Leuchte4TFL LB4-Dimming Direction GH 4    maximize     16
ENG116940-ENG115953-Leuchte4TFL LB4-Dimmwert AB 4    127    16
ENG116940-ENG115957-Leuchte4TFL LB4-Dimmwert CD 4    0    16
ENG116940-ENG115961-Leuchte4TFL LB4-Dimmwert EF 4    127    16
ENG116940-ENG115965-Leuchte4TFL LB4-Dimmwert GH 4    0    16
ENG116940-ENG115950-Leuchte4TFL LB4-Fehlerort mittleres Byte DTC-DFCC 4    49    16
ENG116940-ENG116553-Leuchte4TFL LB4-Lampendefektbitposition 4    3A     16
ENG116940-ENG115948-Leuchte4TFL LB4-Lasttyp 4    1 - LED Tagfahrlichtmodul Versorgung     16
ENG116940-ENG115954-Leuchte4TFL LB4-Lichtansteuerung HD AB 4    Always     16
ENG116940-ENG115951-Leuchte4TFL LB4-Lichtfunktion A 4    Daytime running lamps     16
ENG116940-ENG115952-Leuchte4TFL LB4-Lichtfunktion B 4    not active     16
ENG116940-ENG115955-Leuchte4TFL LB4-Lichtfunktion C 4    Blinken links aktiv (beide Phasen)     16
ENG116940-ENG115956-Leuchte4TFL LB4-Lichtfunktion D 4    not active     16
ENG116940-ENG115959-Leuchte4TFL LB4-Lichtfunktion E 4    Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht)     16
ENG116940-ENG115960-Leuchte4TFL LB4-Lichtfunktion F 4    Parklicht links (beidseitiges Parklicht aktiviert li & re)     16
ENG116940-ENG115963-Leuchte4TFL LB4-Lichtfunktion G 4    not active     16
ENG116940-ENG115964-Leuchte4TFL LB4-Lichtfunktion H 4    not active     16
ENG116941-ENG115977-Leuchte5 TFL RB32-Dimming Direction CD 5    minimize     16
ENG116941-ENG115981-Leuchte5 TFL RB32-Dimming Direction EF 5    maximize     16
ENG116941-ENG115985-Leuchte5 TFL RB32-Dimming Direction GH 5    maximize     16
ENG116941-ENG115972-Leuchte5 TFL RB32-Dimmwert AB 5    127    16
ENG116941-ENG115976-Leuchte5 TFL RB32-Dimmwert CD 5    0    16
ENG116941-ENG115980-Leuchte5 TFL RB32-Dimmwert EF 5    127    16
ENG116941-ENG115984-Leuchte5 TFL RB32-Dimmwert GH 5    0    16
ENG116941-ENG115969-Leuchte5 TFL RB32-Fehlerort mittleres Byte DTC-DFCC 5    4B     16
ENG116941-ENG116554-Leuchte5 TFL RB32-Lampendefektbitposition 5    44    16
ENG116941-ENG115967-Leuchte5 TFL RB32-Lasttyp 5    1 - LED Tagfahrlichtmodul Versorgung     16
ENG116941-ENG115973-Leuchte5 TFL RB32-Lichtansteuerung HD AB 5    Always     16
ENG116941-ENG115970-Leuchte5 TFL RB32-Lichtfunktion A 5    Daytime running lamps     16
ENG116941-ENG115971-Leuchte5 TFL RB32-Lichtfunktion B 5    not active     16
ENG116941-ENG115974-Leuchte5 TFL RB32-Lichtfunktion C 5    Blinken rechts aktiv (beide Phasen)     16
ENG116941-ENG115975-Leuchte5 TFL RB32-Lichtfunktion D 5    not active     16
ENG116941-ENG115978-Leuchte5 TFL RB32-Lichtfunktion E 5    Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht)     16
ENG116941-ENG116555-Leuchte5 TFL RB32-Lichtfunktion F 5    Parking light right     16
ENG116941-ENG115982-Leuchte5 TFL RB32-Lichtfunktion G 5    not active     16
ENG116941-ENG115983-Leuchte5 TFL RB32-Lichtfunktion H 5    not active     16
ENG116942-ENG115996-Leuchte6ABL LC5-Dimming Direction CD 6    maximize     16
ENG116942-ENG116000-Leuchte6ABL LC5-Dimming Direction EF 6    maximize     16
ENG116942-ENG116004-Leuchte6ABL LC5-Dimming Direction GH 6    maximize     16
ENG116942-ENG115991-Leuchte6ABL LC5-Dimmwert AB 6    127    16
ENG116942-ENG115995-Leuchte6ABL LC5-Dimmwert CD 6    0    16
ENG116942-ENG115999-Leuchte6ABL LC5-Dimmwert EF 6    0    16
ENG116942-ENG116003-Leuchte6ABL LC5-Dimmwert GH 6    0    16
ENG116942-ENG115988-Leuchte6ABL LC5-Fehlerort mittleres Byte DTC-DFCC 6    1A     16
ENG116942-ENG116556-Leuchte6ABL LC5-Lampendefektbitposition 6    36    16
ENG116942-ENG115986-Leuchte6ABL LC5-Lasttyp 6    3 - Xenon Abblendlicht     16
ENG116942-ENG115992-Leuchte6ABL LC5-Lichtansteuerung HD AB 6    Always     16
ENG116942-ENG115989-Leuchte6ABL LC5-Lichtfunktion A 6    Abblendlicht links     16
ENG116942-ENG115990-Leuchte6ABL LC5-Lichtfunktion B 6    Lichthupe generell     16
ENG116942-ENG115993-Leuchte6ABL LC5-Lichtfunktion C 6    not active     16
ENG116942-ENG115994-Leuchte6ABL LC5-Lichtfunktion D 6    not active     16
ENG116942-ENG115997-Leuchte6ABL LC5-Lichtfunktion E 6    not active     16
ENG116942-ENG115998-Leuchte6ABL LC5-Lichtfunktion F 6    not active     16
ENG116942-ENG116001-Leuchte6ABL LC5-Lichtfunktion G 6    not active     16
ENG116942-ENG116002-Leuchte6ABL LC5-Lichtfunktion H 6    not active     16
ENG116943-ENG116015-Leuchte7ABL RB1-Dimming Direction CD 7    maximize     16
ENG116943-ENG116019-Leuchte7ABL RB1-Dimming Direction EF 7    maximize     16
ENG116943-ENG116023-Leuchte7ABL RB1-Dimming Direction GH 7    maximize     16
ENG116943-ENG116010-Leuchte7ABL RB1-Dimmwert AB 7    127    16
ENG116943-ENG116014-Leuchte7ABL RB1-Dimmwert CD 7    0    16
ENG116943-ENG116018-Leuchte7ABL RB1-Dimmwert EF 7    0    16
ENG116943-ENG116022-Leuchte7ABL RB1-Dimmwert GH 7    0    16
ENG116943-ENG116007-Leuchte7ABL RB1-Fehlerort mittleres Byte DTC-DFCC 7    1B     16
ENG116943-ENG116557-Leuchte7ABL RB1-Lampendefektbitposition 7    40    16
ENG116943-ENG116005-Leuchte7ABL RB1-Lasttyp 7    3 - Xenon Abblendlicht     16
ENG116943-ENG116011-Leuchte7ABL RB1-Lichtansteuerung HD AB 7    Always     16
ENG116943-ENG116008-Leuchte7ABL RB1-Lichtfunktion A 7    Abblendlicht rechts     16
ENG116943-ENG116009-Leuchte7ABL RB1-Lichtfunktion B 7    Lichthupe generell     16
ENG116943-ENG116012-Leuchte7ABL RB1-Lichtfunktion C 7    not active     16
ENG116943-ENG116013-Leuchte7ABL RB1-Lichtfunktion D 7    not active     16
ENG116943-ENG116016-Leuchte7ABL RB1-Lichtfunktion E 7    not active     16
ENG116943-ENG116017-Leuchte7ABL RB1-Lichtfunktion F 7    not active     16
ENG116943-ENG116020-Leuchte7ABL RB1-Lichtfunktion G 7    not active     16
ENG116943-ENG116021-Leuchte7ABL RB1-Lichtfunktion H 7    not active     16
ENG116944-ENG116034-Leuchte8FL LB39-Dimming Direction CD 8    maximize     16
ENG116944-ENG116038-Leuchte8FL LB39-Dimming Direction EF 8    maximize     16
ENG116944-ENG116042-Leuchte8FL LB39-Dimming Direction GH 8    maximize     16
ENG116944-ENG116029-Leuchte8FL LB39-Dimmwert AB 8    127    16
ENG116944-ENG116033-Leuchte8FL LB39-Dimmwert CD 8    0    16
ENG116944-ENG116037-Leuchte8FL LB39-Dimmwert EF 8    0    16
ENG116944-ENG116041-Leuchte8FL LB39-Dimmwert GH 8    0    16
ENG116944-ENG116026-Leuchte8FL LB39-Fehlerort mittleres Byte DTC-DFCC 8    26    16
ENG116944-ENG116558-Leuchte8FL LB39-Lampendefektbitposition 8    35    16
ENG116944-ENG116024-Leuchte8FL LB39-Lasttyp 8    36 - LED Kleinleistung     16
ENG116944-ENG116030-Leuchte8FL LB39-Lichtansteuerung HD AB 8    Always     16
ENG116944-ENG116027-Leuchte8FL LB39-Lichtfunktion A 8    Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht)     16
ENG116944-ENG116028-Leuchte8FL LB39-Lichtfunktion B 8    Parklicht links (beidseitiges Parklicht aktiviert li & re)     16
ENG116944-ENG116031-Leuchte8FL LB39-Lichtfunktion C 8    not active     16
ENG116944-ENG116032-Leuchte8FL LB39-Lichtfunktion D 8    not active     16
ENG116944-ENG116035-Leuchte8FL LB39-Lichtfunktion E 8    not active     16
ENG116944-ENG116036-Leuchte8FL LB39-Lichtfunktion F 8    not active     16
ENG116944-ENG116039-Leuchte8FL LB39-Lichtfunktion G 8    not active     16
ENG116944-ENG116040-Leuchte8FL LB39-Lichtfunktion H 8    not active     16
ENG116945-ENG116053-Leuchte9FL RB2-Dimming Direction CD 9    maximize     16
ENG116945-ENG116057-Leuchte9FL RB2-Dimming Direction EF 9    maximize     16
ENG116945-ENG116061-Leuchte9FL RB2-Dimming Direction GH 9    maximize     16
ENG116945-ENG116048-Leuchte9FL RB2-Dimmwert AB 9    127    16
ENG116945-ENG116052-Leuchte9FL RB2-Dimmwert CD 9    0    16
ENG116945-ENG116056-Leuchte9FL RB2-Dimmwert EF 9    0    16
ENG116945-ENG116060-Leuchte9FL RB2-Dimmwert GH 9    0    16
ENG116945-ENG116045-Leuchte9FL RB2-Fehlerort mittleres Byte DTC-DFCC 9    27    16
ENG116945-ENG116559-Leuchte9FL RB2-Lampendefektbitposition 9    3F     16
ENG116945-ENG116043-Leuchte9FL RB2-Lasttyp 9    36 - LED Kleinleistung     16
ENG116945-ENG116049-Leuchte9FL RB2-Lichtansteuerung HD AB 9    Always     16
ENG116945-ENG116046-Leuchte9FL RB2-Lichtfunktion A 9    Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht)     16
ENG116945-ENG116047-Leuchte9FL RB2-Lichtfunktion B 9    Parking light right     16
ENG116945-ENG116050-Leuchte9FL RB2-Lichtfunktion C 9    not active     16
ENG116945-ENG116051-Leuchte9FL RB2-Lichtfunktion D 9    not active     16
ENG116945-ENG116054-Leuchte9FL RB2-Lichtfunktion E 9    not active     16
ENG116945-ENG116055-Leuchte9FL RB2-Lichtfunktion F 9    not active     16
ENG116945-ENG116058-Leuchte9FL RB2-Lichtfunktion G 9    not active     16
ENG116945-ENG116059-Leuchte9FL RB2-Lichtfunktion H 9    not active     16
ENG116950-ENG116148-Leuchten14AL LB6-Dimming Direction CD 14    maximize     16
ENG116950-ENG116152-Leuchten14AL LB6-Dimming Direction EF 14    maximize     16
ENG116950-ENG116156-Leuchten14AL LB6-Dimming Direction GH 14    maximize     16
ENG116950-ENG116143-Leuchten14AL LB6-Dimmwert AB 14    0    16
ENG116950-ENG116147-Leuchten14AL LB6-Dimmwert CD 14    0    16
ENG116950-ENG116151-Leuchten14AL LB6-Dimmwert EF 14    0    16
ENG116950-ENG116155-Leuchten14AL LB6-Dimmwert GH 14    0    16
ENG116950-ENG116140-Leuchten14AL LB6-Fehlerort mittleres Byte DTC-DFCC 14    0    16
ENG116950-ENG116565-Leuchten14AL LB6-Lampendefektbitposition 14    0    16
ENG116950-ENG116138-Leuchten14AL LB6-Lasttyp 14    not active     16
ENG116950-ENG116144-Leuchten14AL LB6-Lichtansteuerung HD AB 14    Always     16
ENG116950-ENG116141-Leuchten14AL LB6-Lichtfunktion A 14    not active     16
ENG116950-ENG116142-Leuchten14AL LB6-Lichtfunktion B 14    not active     16
ENG116950-ENG116145-Leuchten14AL LB6-Lichtfunktion C 14    not active     16
ENG116950-ENG116146-Leuchten14AL LB6-Lichtfunktion D 14    not active     16
ENG116950-ENG116149-Leuchten14AL LB6-Lichtfunktion E 14    not active     16
ENG116950-ENG116150-Leuchten14AL LB6-Lichtfunktion F 14    not active     16
ENG116950-ENG116153-Leuchten14AL LB6-Lichtfunktion G 14    not active     16
ENG116950-ENG116154-Leuchten14AL LB6-Lichtfunktion H 14    not active     16
ENG126648-ENG149012-LIN-Mirrormode-Bitmaske    63    1
ENG126648-ENG148864-LIN-Mirrormode-Stage    0    1
ENG117284-ENG115658-LuB Lichtrouter Kennlinie 1-x0    0.00%    12
ENG117284-ENG101574-LuB Lichtrouter Kennlinie 1-X1    5.00%    12
ENG117284-ENG99557-LuB Lichtrouter Kennlinie 1-X2    50.00%    12
ENG117284-ENG102140-LuB Lichtrouter Kennlinie 1-X3    75.00%    12
ENG117284-ENG102936-LuB Lichtrouter Kennlinie 1-X4    110    12
ENG117284-ENG103548-LuB Lichtrouter Kennlinie 1-X5    126.5    12
ENG117284-ENG115659-LuB Lichtrouter Kennlinie 1-y0    0.00%    12
ENG117284-ENG99777-LuB Lichtrouter Kennlinie 1-Y1    6.00%    12
ENG117284-ENG100480-LuB Lichtrouter Kennlinie 1-Y2    16.00%    12
ENG117284-ENG100773-LuB Lichtrouter Kennlinie 1-Y3    30.00%    12
ENG117284-ENG100631-LuB Lichtrouter Kennlinie 1-Y4    60.00%    12
ENG117284-ENG102174-LuB Lichtrouter Kennlinie 1-Y5    100.00%    12
ENG98831-ENG126849-Personalization-Aktivierungsoption_im_HMI-Menue_sichtbar    not active     16
ENG98831-ENG126850-Personalization-Benutzerkontenverwaltung_in_HMI-Menue_sichtbar    not active     16
ENG98831-ENG126848-Personalization-Personalisierung_aktiv    not active     16
ENG98831-ENG126851-Personalization-Personalisierungsfunktionen_in_HMI-Menue_sichtbar    not active     16
ENG122976-ENG148891-Remote_Start_Adaption-Anzahl zulaessiger Remotestarts    2    8
ENG122976-ENG148876-Remote_Start_Adaption-RemoteStart Betrieb Dauer    10 min    8
ENG116971-ENG116537-Vernetzungs- Diagnosefunktionen-can msg 1    00 00     20
ENG116971-ENG116538-Vernetzungs- Diagnosefunktionen-can msg 2    00 00     20
ENG116971-ENG116539-Vernetzungs- Diagnosefunktionen-can msg 3    00 00     20
ENG116971-ENG116540-Vernetzungs- Diagnosefunktionen-can msg 4    00 00     20
ENG116971-ENG116541-Vernetzungs- Diagnosefunktionen-lin msg 1    00 00     20
ENG116971-ENG116542-Vernetzungs- Diagnosefunktionen-lin msg 2    00 00     20
ENG116971-ENG116543-Vernetzungs- Diagnosefunktionen-lin msg 3    00 00     20
ENG116971-ENG116544-Vernetzungs- Diagnosefunktionen-lin msg 4    00 00     20
ENG116971-ENG116545-Vernetzungs- Diagnosefunktionen-lin msg 5    00 00     20
ENG116971-ENG116546-Vernetzungs- Diagnosefunktionen-lin msg 6    00 00     20
