Nissanskylinen1
- Toronto
- '16 R w/DCC & Nav
Okay so I've been doing this install a number of times now for other people and here are some additional notes/tips:
1) I would highly recommend buying repinning "keys"/tool from Amazon instead of the sewing needles. The wires will come out on the first try this way and save you time and a lot of swearing.
2) When wiring the driver side reverse light, you will need the repair wire as mentioned in my original post. However, most of the sellers do not sell a wire that is long enough to go from one end to another. You'll need around 150cm of wire to do so. If you cannot find a wire that long, you can instead splice the reverse signal wire that goes to the camera near the rear camera. That way you can use a slightly shorter wire that you can find easily.
3) I would highly recommend buying a panel removal tool with a clip removal tool as well. It makes quick work of removing the tail lights and panels, not to mention the clip removal tool is a lifesaver when those asshole A clips get stuck in the car and you don't want to damage them.
