@Cuzoe @doctor @AWD4416
DCC fun begins next week. Blind Spot Monitor, TPMS and a memory seat took forever and a day.
DCC module is plumbed into the CANs and Body Control and all fused up (without fuse in - risking parasitic draw)
Need to do a pokey hole through a few of the grommets to get the wires to the shocks. Any hints on this one? especially to avoid rainwater? All I've found so far is this :
https://www.autoinstruct.com.au/man...mk7-golf/running-cables-through-the-firewall/
Coding attempt will be as follows:
Add Electronic Dampening 14 from gateway list.
Module 01 Engine
Operating Mode Selection
Module 03 Brakes/ABS Long Coding
ABS module Byte 27 Bit 7 is the "
DCC Installed" bit.
Module 4b Long Coding
Chassis Unit
Eco Mode - > Enabled ( perhaps get around the FPA by getting eco as a bonus mode here?)
Source Height Value ->BCM -> DCC
LWR Sensors
Steering Curve
Module 4b Adaptation
Presentation Mode
Installation List -> Specified Installations -> ??
Module 5f Adaptations
P damping display
Car Func List BAP Gen2 -> ENG122229-ENG117736-Car_Function_List_BAP_Gen2-charisma_0x17" >> Active
Car Func Adaptations Gen2 -> tbc
Car Func List CAN Gen2 -> tbc
DISPLAY 5F – Adaptation 10 – Air Suspension – ?? think this is only for super Audi's and bentley's.
Module 5f Long Coding?
TBC
Module 09 Central Electrics (Suspected but not confirmed)
The options in here are mainly in German but I’m pretty sure there may be an option in here to at least check.
Module 13 ACC Adaptations (Suspected but not confirmed)
There are some modes in here for Race and Comfort. Don’t know if there is something to be changed in here?
Module 17 Dashboard
Wheel Dampening Electronics - >Yes
Module 17 Dashboard Long Coding
Adaptive Chassis Control -> Installed
Module 19 Gateway Adaptation
Byte 12 Bit 7 and now
DCC is visible in Individual selection.
Module 19 Gateway Long Coding
FPA FunktionStuffenDCC -> Active
FahrProfilAuswahl ->Driving profile Selection
BCME Komforte Reichweite -> Comfort range
Module 44 Steering Assistance
Wheel Dampening Electronics ->Active
Module 20 High Beam + 55 Xenon Headlights
The headlights will have previously been getting their positioning exclusively based on the rear level sensor G76 so we’ll need to code it so that they get their message from DCC from now on. This will be done in Module 4B . 20 or 55 which I don’t seem to have but definitely have bi-xenons ??
55 - Headlight range control unit, disable byte 1 bit 3, this makes the leveling sensor info to come through CAN and not via direct sensor connection
19 CANT GATEWAY - BINGO! Byte 12 Bit 7 and now
@doctor So i came across a 19 Gateway blockmap which I think re-enforces your theory on FPA profiles ! see below from another vehicle online:
IDE07873-MAS06193 | FPA enabled profiles-Profile 1 | Comfort |
IDE07873-MAS06194 | FPA enabled profiles-Profile 2 | AUTO |
IDE07873-MAS06195 | FPA enabled profiles-Profile 3 | Not Used |
IDE07873-MAS06196 | FPA enabled profiles-Profile 4 | Not Used |
IDE07873-MAS06197 | FPA enabled profiles-Profile 5 | ECONOMY |
IDE07873-MAS06198 | FPA enabled profiles-Profile 6 | RACE |
IDE07873-MAS06199 | FPA enabled profiles-Profile 7 | INDIVIDUAL |
IDE07873-MAS06200 | FPA enabled profiles-Profile 8 | Not Used |
IDE07873-MAS08875 | FPA enabled profiles-Profile 9 | Not Used |
IDE07873-MAS08876 | FPA enabled profiles-Profile 10 | Not Used |
IDE07873-MAS08877 | FPA enabled profiles-Profile 11 | Not Used |
IDE07873-MAS08878 | FPA enabled profiles-Profile 12 | Not Used |
