DSC808
HI State
2016 GTI SE MT
Stupid question: Was trying to swap pads and it seemed like the pistons were slightly out and I couldn't get the new pads in. The backing came off and I figured I should stop there and put the old pads back in. Is there a setting in VCDS that retracts the pistons all the way? Only thing I find is for the rear brake retraction.
scrllock
MI
No, you need to use a piston spreader. I use a knockoff version of this:
https://www.amazon.com/Lisle-29100-Quick-Quad-Spreader/dp/B005GLQCKA
PatMc
Long beach
Depends on the day
I just pull the old pad out the top, turn it 90° and stick it back in halfway over the pistons and use it a prybar to push the pistons back....do one pad at a time, then install the new pad and do the other pad.
GTIfan99
This is what I do also. Don't need no fancy spreader.
I actually want a spreader, I've just never got around to buying one.
Bryans12v
Hudson Valley, NY
19 GTI, 22 Tig Rline
Anyone else have issues with the DB-45HT silicone dust boots not seating on the outer dia? Cleaned really well, they just pop right out.
Video for reference:
The standard black rubber ones seem to fit fine. But these are only lasting about 6 months or so before drying up ans cracking, even with the RRG. Was really hoping silicone would get me through a year but cant get them to fit properly.
PatMc
Long beach
Depends on the day
Have you considered running a titanium heat shield shim between the pads and the pistons? Let me know if you'd like to try it
Bryans12v
Hudson Valley, NY
Ive been running titanium shims since ive installed these calipers. Considering trying the pyroclast shims offered by evo corsa. The car is not a daily and only track car and im not nice to the brakes. Lol
nono0044
Toronto
