I installed the powerflex hybrid bushing/insert this last Friday. Had a 034 lower insert I'd installed a year ago and it in that year it had damaged the bushing. Damage turned out to be minor, almost cosmetic, but couldn't tell extent until I'd (destructively) removed it... so instead of new OEM bushing and insert, I went with the powerflex.
I rented a garage bay with lift, tools, etc, and took just at an hour for this non-mechanically talented guy to install. Pliers and yanking got the 034 insert out, then used a reciprocating saw to make one cut in the side of the puck (almost all the way through... stopped as soon as I heard I'd touched metal). That provided enough strain relief to let me pry the old bushing out. Torqued the new bolt to 130 Nm + ~70 degrees (not enough traction with my shoes on dusty slick concrete to get to 90
Initial impression was that I'd made a mistake due to the strong vibration at idle (esp. with AC on!).
That said, I haven't done that much driving yet, but it does seem to be breaking in. I can still notice vibration at idle if looking for it, but it's definitely lessened and becoming quite tolerable.
Hoping as I get more miles on it that it loosens up a bit more.
When the 034 insert broke-in (i.e., bent
) it allowed my pretty much stock mk7 a small amount of wheel hop in some conditions. I've noticed zero wheelhop with the powerflex. Here's hoping that stays the same!
