Hotfart
- LFK Kansas
Also, what ft lb are people using 74 or 96?
Buried in post #15:
"I used a new dogbone bolt (OEM p/n N91201001, costs about $7), and if I remember correctly this is torque to yield, so a brand new bolt gets torqued to 100nm (74 ft-lbs) plus 1/4 turn. I didn't feel comfortable doing the full 1/4 turn as it got really tight, so I ended up going a little more than 1/8 turn. Note, if you're reusing the stock bolt, just torque to the 100nm spec (74 ft-lb) *without* the extra 1/4 turn. After driving it for a bit, I loosened the bolt then re-torqued to spec."
Couple thoughts for your situation: Might be a long shot, but you're sure you got the right version (Type A or Type B)? Also, if you're able to torque it to 75, is it able to be driven? If so, maybe drive it around a bit, then come back and loosen the bolt then re-torque it again.
If you're concerned about NVH, try out the RocEuro stabilizer arm. It's relatively cheap (~$85), and it all but eliminated NVH on mine (6MT, so I can't speak from firsthand experience for DSGs).
