Snowmanmk7
- Singapore
How is this Yellow Powerflex Hybrid compare with the Yellow Powerflex insert which also fill the upper puck? I would presume the hybrid should be stiffer
How is this Yellow Powerflex Hybrid compare time the Yellow Powerflex insert which also fill the upper puck? I would presume the hybrid should be stiffer
Didn't mention above ... I was running the metal insert (upper and lower also) before I went with the spulen also, lol.Damn I'm gonna have to buy one of these. Been running 034 upper and lower for a while now, got the itch to see what the other side of the fence is like.
Glad to see another convert who came from a different mounting solution. Myself coming straight from stock, I thought it was the best thing ever but I didn’t have anything else to compare it to. I’ve thought about switching to the black “race” one which is supposed to be even stiffer... My thought process was if this one is that good would the stiffer one be even better?
If you’re looking for “even better” replace the full subframe bushing.
Thanks, was looking for this comparison. Do you have upgraded motor/trans mounts?I installed the hybrid lower puck replacement in place of 034 inserts. Before I used to have a very noticeable vibration/shudder when taking off from a standstill. It was bearable, but still... I get absolutely none of that with the Powerflex hybrid puck. I do, however, get a little bit of vibration in reverse, something I did not have with the 034 inserts. Then again, I take off from standstill more often than I go in reverse. Overall I am satisfied with the Powerflex puck. I am planning on giving the ECS pendulum arm a try.
The answer is yes - it is better, at limiting movement and maximizing power to the ground. It is also higher NVH and is advertised as not advised for street driven cars.I’ve thought about switching to the black “race” one which is supposed to be even stiffer... My thought process was if this one is that good would the stiffer one be even better?
You also have stock motor/trans mounts so they are eating up some of that NVH.It's pretty sweet. I daily my car and I think it's perfect but I came from a pretty stiff setup in my old car.
